Question about Panasonic Viera TH-50PZ85U Plasma TV
MODEL: TH-50PZ85U I HAVE A VERTICAL 3" WIDE BLACK BAR IN THE CENTER OF THE SCREEN RUNNING FROM TOP TO BOTTOM. THE REST OF THE SCREEN DISPLAYS A PERFECT PICTURE TO THE LEFT AND RIGHT OF THE 3" BAR. '
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. As Plasma TV is a very hard working device so it produces lots of heat and around 75% issues in Plasmas are caused due to overheating. To start with you'll have to open the back of the unit and check for any bulged/bad capacitors on Y and Z-sus boards. As the sound is working fine so it seems that the power supply is fine, also check the control board for any bulged capacitors. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 28, 2010
2" wide bar in center of Panasonic plasma TH-C42FD18 TV
The C5 board is bad. It is replaceable. Warning. always disconnect power cables from power board to y main on left and x main on the rt before ever messing with fat cables on boards across the bottom . The are created if power power is not isolated will vaporize these flat cable destroying the plasm panel. thes boars across the bottom are the c boards. If one of the connectors is loose it will create an vertical black bar in proximity to that connector. If the connector is not loose then replace that board. Also panel could be bad if c board does not fix. But remember to never connect or dissconnect these flat without disconnecting the power board from the sustain boards.
May 31, 2013 | Televison & Video
Black vertical bar starts 11" from left, approx 3" wide and goes from top to bottom. Replaced TNPA4441 board, no fix. Disconnected ribbon to that section of plasma screen and bar turns white with color...
Since you've replaced the C2 buffer board and didn't fix it. It's very unlikely but possible that the D board is defective. Visually inspect the solder joints on the D connector or try to press slightly on it; if pressing the connector works then there is a loose or cold solder joint on the D connector.
The screen should be replace since still under warranty. The price for a new screen might exceed the price of the plasma, even if you pay for labour still something to decide whether to fix or not.
Try contacting panasonic and ask them nicely if they would be willing to cover the labour cost as well.
Good Luck.
Aug 26, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Black line going vertical through portion of
Connections on c boards, c board bad or bad panel. Disconnect power supply from sus boards on sides before attemting to disaconnect connectors from c board to flex cables. arc from stored energy on power board will burn cables. reseat the connector closest to the bar . reconnect power supply. Next replace that c board by strip. next replace plasma panel.
Dec 03, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
I have a vertical black line on the left side of my TH-50pz85u.
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Oct 11, 2009 | Panasonic Viera TH-50PZ85U Plasma TV
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Vertical black bar down the middle of hitachi plasma tv
Ok if your hitachi TV dies with no power anywhere try this:
Some models have a kill switch under the bottom edge. It's like a gray switch like a small light switch press it back in and voila let there be LIGHT. Saves you at least a $200 trip to repair shop!!
Jan 05, 2009 | Televison & Video
Black bar running from top to bottom in the screen.
There are horizontal and vertical relays in plazmas that go out over time and cause this to happen , You can get an estimate from a local tv repair service in some cases they can give it to you over the phone. Good luck.
Dec 30, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Panasonic th-50pz85u problem
My problem turned out to be silly but simple. I recently took my TV off the wall and mounted it on a stand alone platform. I snaked the power plug through the back tube and left too much tension at the entry point for power. If you leave the slightest tension the female connector will jiggle and it will shut off. It normally takes 3 minutes before you can retry and then the problem persists. Try allowing more slack and/or buying a new power connector to make sure the plug connects correctly. Good Luck!
Jun 24, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Panasonic Viera TH-50PZ85U Plasma TV Logo
250 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
