Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
Oven model JJW9530BAW. When on: sometimes when closing door, light does not go off and fan does not restart. Usually a good hit with the fist against door at 'door switch' area, with it shut, gets it going again. It has stopped on its own with out opening and closing door. Is it the switch at the door, can it be cleaned? please and thank you
  • Jenn-Air Master
  • 2,330 Answers
You have a bad door switch and needs to be changed out part number 71001129
Posted on Oct 02, 2010
  • Sal DeAngelo Oct 03, 2010
    open the door and push on the door switch with your finger and see if the light goes out when you push it in.if it's sticking it's internal and the switch needs to be replaced.let me know what you find
I have an Indesit oven FI 31 KB. It is 3 years old but never used as it is in a house I have just renovated. I turned the oven on, but the fan did not come on as it is expected to do. Oven and light seem...
sometimes there is a switch that operates when the door is opened or closed causes the fan to stop when the door opens. The switch is normally mounted at a door hinge, or hinge bracket.might have to remove a panal to get to it
Oct 19, 2013 | Belling XOU492 Electric Double Oven
Oven door on lock
is the light oven on??? can you see the switch/button that the door would hit against to turn light off?? if so depress button so the lifht goes off, and start a clean cycle.This should make the lock mechanism engage fully. then cancel cycle and should fully disengage lock/latch (you need to depress light switch to trick unit into thinkin the door is closed)
Mar 08, 2008 | Kenmore 30169 Electric Single Oven
Power lose what button to press to restart
A microwave can be dead for many reasons.
You can find a wiring diagram for model R1471 at our site:
http://207.234.249.73/mwd/r1470_wiring.jpg
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 07, 2010 | Ovens
Ge oven turns off by itself, and sometimes gives
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Nov 11, 2009 | GE Profile JTP18 Electric Single Oven
Re Neff B1451 oven door not sealing against oven body at top
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Dec 30, 2008 | Neff B1451 Single circotherm plus Electric...
How do I clean my frigidaire self clean gas oven
after the three hour prompt comes up hit start while the door lock light is blinking and let me know what it does
Jan 09, 2008 | Frigidaire FGB24S5A Gas Single Oven
Electrolux EOC6690X Pyrolytic Door won't close properly
if the door lock engagement rod is sticking out then with the door open hold the switch down with your finger then hit start then cancel lock rod should go back letting door close if engagement hook is not sticking out may have to replace switch some are bad about breaking but have been impooved
Dec 28, 2007 | Electrolux EOC6690X Pyrolytic Electric...
AMANA CONVECTION OVEN
Try this it worked for me:
Spray the hinge assy including the springs with WD40 work the door back and forth.
Look at the interface of the door gasket to the oven chamber mine was pulled away slightly away from the frame on the bottom I used a hammer and a piece of wood to pound it back tight against the oven frame.
I changed the light switch and that did it good luck
steven199@hotmail.com
Dec 23, 2007 | Amana AOCS3040 Electric Single Oven
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
Smeg electric oven
your neighbour is probably right. fan should work but if the element has disintegrated, bits of the element could be jamming the fan. take the rear panel off inside the oven and check
Jun 01, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
217 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
