Question about Toshiba MK2103MAV 2.1 GB Hard Drive
Toshiba HDD I need to wipe clean my toshiba Tecra 730XCDT laptop HDD. Please advice
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 77 Answers
Preparation Step1When you format a computer hard drive you will lose everything that is on the drive. Therefore, it is very important to back up anything you might want later. Additionally, if you are going to be formatting and installing XP you need to make sure you have the discs for any applications or third party hardware you use since you will need to re-install your programs and drivers after re-installing Windows. Step2Take a moment to think of anything that you have on the computer that you wouldn't want to lose. Generally, you probably want everything in your My Documents folder, and you also want to save things like your favorites or bookmarks from your Web browser. Remember that each user on the computer has his or her own My Documents folder, Desktop items and Favorites/Bookmarks. Step3Save everything to a CD, DVD or a hard drive that you won't be formatting. Formatting and Installing from the Windows XP CD Step1This section explains how to reformat a drive from the Windows XP installation CD. This can be used when installing a fresh copy of Windows onto a computer. Here it is especially important to backup all of your important information because upon formatting you will lose EVERYTHING that used to be on the drive. This includes all applications and device drivers, so you must back up everything you can. Step2Insert your Windows XP installation disc into your CD drive (Home or Pro--it does not matter). Step3Now as you computer boots a little more it will say “Press any key to boot from CD..” press a key to do so. Step4The CD will load up a blue screen and then spend a while loading files it needs. When it is finished it will list a few options, mainly “Press ENTER to set up Windows XP.” Press Enter or Return. Step5Now you will be at a screen to select where to install Windows to. This is where you can delete old partitions and format drives. The box in the bottom half of the screen shows all your drives and the partitions that exist on them. Use the Up and Down arrow keys to highlight your “C:” partition and press the 'D' key (if all that shows up is “Unpartitioned space” and you have no C: or D: partitions, skip this step). On the next screen press the 'L' key to finalize deleting the partition. Step6Now you are back on the screen to choose where to install Windows. The box on the lower half of the screen should no longer show a partition but simply have an entry “Unpartitioned space xxxxxMB.” Select this with the arrow keys and press the 'C' key to create a partition on the drive. The next screen tells you the minimum and maximum sizes the partition can be and lets you pick the size. The default size is the maximum, but double check that the number entered is the maximum and hit enter. Step7Now you will again be back at the choose where to install Windows screen. But this time you will have a partition that looks something like this “C: Partition1 [New (Raw)]xxxxxxMB.” Highlight this entry and press enter. Step8The next screen lets you choose which file system to format the drive with. Choose NTFS as it is faster and more secure. If the drive is brand new and has never been used before then use one of the options that ends in “(Quick).” Or, choose one of the lower down options. Use the arrow keys to select the proper one and press Enter or Return. Step9From here you are all set and the installation of Windows will proceed starting with a format of your drive. This will take a while (over half an hour) so you can take a little break
Posted on Jun 17, 2008
How do i recover toshiba tecra 730xcdt windows password?
If a user account needs to be reset, logon as the administrator or as a user with administrative access, and then follow these steps:
Click Start, point to Programs, click Control Panel, double-click Administrative Tools, and then double-click Computer Management.
Expand the Local Users And Groups object under System Tools, and then click the Users folder.
In the right pane, right-click the appropriate user object, and then click Set Password.
Type the appropriate password, and then click OK.
Click OK to acknowledge that the password change succeeded.
Close the Computer Management console and Administrative Tools windows.
The user can log on with the new password.
To Reset the Administrator's Password
Log on to the computer as a user with administrative privileges, and perform the steps
listed above for the Administrator account.
If the Administrator password needs to be reset, and there are no other users with administrative access, there is no way to recover the password and the operating system will need to be reinstalled.
or if you have not set a bios password
restart your computer you will see on your screen to press a certain key to enter bios usually the Delete or the F2 key
press and hold that key to enter set up BIOS where you can set or remove your password
this will differ depending on you computer and bios
hope this helps
Aug 08, 2012 | Toshiba Tecra 730XCDT Laptop AC Power...
Toshiba Tecra M1 HDD failure
no you just put new hdd and run recovery
Dec 15, 2009 | Toshiba Tecra M1 PC Laptops
Hi - I've got a Toshiba Tecra S1 which at the moment is refusing to boot up. There is no output to the screen, and the caps lock light is on. I've swapped the HDD and memory out for another but this has...
Have You Checked The Fan/Heatsink Assembly???
Your Heatsink Cooling Fins Might Be Clogged
If So, The Fan Blades, The Heatsink Fins And Assembly Need To Be Cleaned Thouroughly... DO NOT USE COMPRESSED AIR
You Must Disassemble Laptop And Physically Clean these parts
It would be a good idea at this point to also add new Arctic Silver Thermal Paste or Thermal Pads To The CPU/GPU..
Nov 28, 2009 | Toshiba Tecra S1 Laptop Notebook
FN key not working on Toshiba Tecra A2
You can enable/Disable Fn key in System Setup.
to access system setup press F2 when you see the Toshiba logo
Mar 14, 2009 | Toshiba Tecra A2-S316 (0032017250819) PC...
Have a used Tecra 730XCDT
I might have an owner's manual in pdf format but it's on floppy. I'll be working on my broken Tecra 730XCDT which means transferring data from the hard drive. The manual should be in those files too. I'll contact you and send you a copy. Bear with me for a few days on this.
Dec 02, 2008 | Toshiba 730XCDT Notebook
Toshiba Tecra A3 wont boot
yes if u can connect it wd the a server wd a port thn there is no need of hdd ..the main thing is u sould have a server near by
May 22, 2008 | Toshiba Tecra A3 Notebook
SCHEMATIC OF HDD CONNECTOR Toshiba Tecra 730CDT
Which part of the connector is broken? on the drive? on the system board?
Nov 26, 2007 | Toshiba Tecra 730CDT Notebook
Toshiba MK2103MAV 2.1 GB Hard Drive Logo
195 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
