Question about Kenmore 67082 Electric Dryer
Ihave a Kenmore dryer model 110 85091 400. It displays a code "PF" after a few minutes of normal operation. we have checked the breakers, but it still shows 'PF"...this happens every time I try to dry anything!! can you help?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. PF means power failure and it seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. If that is fine then the issue is with the Control going bad and should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 28, 2010
Why does kenmore dryer model 417.8804277 keep beeping when not in use?
If you have the 417.88042700 dryer, this is often a symptom of a control panel failure. First though, try resetting the dryer. Unplug the unit (or flip the circuit breaker to off). After 30 seconds to one minute, plug the dryer back in. Press Cancel twice to clear the PF message. Try running a short cycle and see if the unit beeps after the cycle is over.
Also check if you are getting brief power failures. Really short ones might cause beeping without the PF message on the display.
If neither of the above explain the issue, you probably need to check the control board or wiring for a short. A replacement control board is available here: http://www.repairclinic.com/PartDetail/b6p8/Kenmore-Dryer-Main-Control-Board/137008010/1472768?modelNumber=417.88042700 .
I hope this helps.
Aug 09, 2014 | Kenmore Dryers
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Have kenmore 61951 dryer PF comes on go thru the steps it turns on and then shuts off what could be the problem
PF is a power failure error meaning electricity has been interrupted to the machine. Any electrical interruption to the machine such as a circuit breaker being reset or weather related power outage can cause a PF error code. Try resetting the appliance by disconnecting it from the outlet or switching off the circuit breaker for 20-30 minutes, then restore the power. If the reset doesn't work I suspect the control board has failed.
Jan 12, 2011 | Kenmore Dryers
We just replaced the power cord and outlet for a Kenmore Elite HE3 dryer and now it will not go on. I flipped the circuit breaker on and it said PF and now I get nothing.
PF error = Power Failure - error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Here is a site to double check the wiring:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Good Luck Tim
Nov 28, 2010 | Kenmore Elite HE4 Electric Dryer
Power Failure without tripping breaker
Sounds like an overheat code tripped due to obstruction in the exhaust. There is also a vent tube on the bottom of the dryer that could be loose.
Jul 27, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Digital display
PF means Power Failure. Check the breaker in your breaker box. The dryer uses 2 breakers that are put together. Reset the breakers to see if the problem gets fixed.
May 13, 2010 | Kenmore Elite HE4 Electric Dryer
The dryer runs for a couple seconds and then give a PF code which I think means power Failure. brand Frigidaire
that is a power failure code. check the main cisuit breaker and the cord to the dryer and make sure the connections are tight.unplug the unit for a few minutes and plug it back in this should clear the pf code out.
Feb 22, 2010 | Frigidaire AEQ6000ES Electric Dryer
Kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Dec 24, 2007 | Kenmore 67082 Electric Dryer
Kenmore dryer 417.84072300
Check you circuit breaker. Even if it doesn't look tripped reset it anyhow. This is a power interrupt code.
Dec 04, 2007 | Kenmore 84072 Electric Dryer
Kenmore 67082 Electric Dryer Logo
66 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
