Question about Maytag Dishwashers
Started making grinding noise when filling. I forgot to run the disposal before this load. It has always run very quiet until this load.
  • 4,350 Answers
Filling is only using an electric valve, unlikely the disposal issue is related.
Posted on Sep 28, 2010
Excesive grinding noise during operation, blades rotate freely and over current protyection is not tripping.
there may be some debris in the unit try running water and alot of ice through the unit while running this may help clean it and quiet it
Oct 04, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My kenmore HE 2 Plus washing machine makes a loud grinding noise when it enters the pre-wash/wash cycle (worse on this cycle) then continues on through the rest of the cycles. Washer fills, rinses, spins...
Unfortunately, I don't think you will be able to fix this issue, some mechanical parts are breaking. If your appliance still under warranty, you may need to contact the appliance manufacturer for assistance. This kind of repair can be expensive and is difficult enough so a service technician may need to fix it.
Aug 31, 2009 | Kenmore HE2 Plus Front Load Washer
Maytag Performa top loader is making grinding noises
The agitators are a pop-on fit. Make sure that the agitator is firmly seated on the shaft. Lift it up and if it moves easily adjust it to the splines on the shaft and press it back into place.
Jul 29, 2009 | Maytag Performa PAV3200
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Garbage disposal...won't drain
There should be a reset switch on the bottom of the disposal.
When using a disposal, always run water first, then turn on disposal. Then dispose food. Then keep water running until it all sounds clear before turning it off.
Mar 11, 2009 | GE 24 in. Profile PDW7800 Built-in...
Roper RAS7233KQ0 NO SPIN
chek the water elctrovalvles and replace it , this most be 1 solution another will the hyperstatic hose or sensor of load size
Mar 04, 2009 | Roper RAS8244KQ Top Load Washer
Loud grinding noise when the shredder is on.
Your gears may be stripped - mine were. Time to get a new shredder
Jul 09, 2008 | Tech Solution TS-8000 Cross-Cut Shredder
Grinding noise for maytag quietseries 200 usually when it first starts up
I had the same problem with my Maytag Quiet Series 1 dishwasher until I read the comment left by the guest on June 1, 2008. I tried his suggestion about the rinse cap adjustment and WOW it WORKED. No more growling noise. Thanks you saved me a service call.
Apr 06, 2008 | Dishwashers
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Dishwashers Logo
47 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
