Question about Garmin Quest GPS Receiver
Garmin Quest I installed a route from Florida to Chocago yesterday Since then the display shows me only the sign "DRAWING"...
  • maxkrammel May 24, 2008
    ...and all the buttons seems to be frozen
  • 4 Answers
This happened to me twice, and both times it was after I had loaded the route for a long trip. Both times, the total map memory required (as indicated in the Quest) was much less than 115 MB - in one file the maps required 63 MB, and in the other the maps required 59 MB. And both times, I was able to "hard-boot" the Quest by simultaneously pressing page-OK-power and selecting "yes". This action also erased the route, the downloaded maps, and all of my preselected options.
My experiences suggest that the actual working memory in the Quest is less than the advertised 115 MB, but I haven't yet determined whether that's true and, if so, what the actual limit is.
Posted on Aug 22, 2008
Hello, I currently own a Garmin quest myself, and some time ago I had some strange problems myself, I am a electronics technician, and I do have a work around for you. I will explain the problems and a cure for you to try, none of the work arounds depend on any parts to be removed.
1. NO RECEIVING SATELLITE TELEMETRY. I beleieve this could be due to a number of reasons, but more so at sometime corrupted telemetry was the problem to fix this,
a turn GPS on
b. depress menu
select settings
select Time Setup
when in Time Setup depress MENU
Depress OK button
Depress OK button again on the numberic keypad that appears on the screen (DONE)
what this seems to do is resets the internal date/time clock and the unit starts to work again.
the Second workaround is this but takes hours to perform.
Simply turn the Guest on and allow the battery to fully discharge, usually this works to TOTALLY flush the Memory again, but on my unit I have to setup all the maps again, this is easy to perform, but just takes time. I hope this helps you.
phil email
Posted on Jun 05, 2008
I have lost all my maps on my garmin nuvi 255W-
Do a hard reset on your GPS. Download and install Garmin Express from Garmin. Plug your GPS into your computer. The software will identify your GPS and allow you to download new maps to it.
Mar 19, 2017 | Garmin Nuvi 200 205 250 255 260 W
Cant get my quest to work with windows 7
your computer must have Garmin USB drivers installed. Go to Support at Download and install, then connect your Quest.
Nov 09, 2012 | Garmin Quest GPS Receiver
Will not show transferd maps will show routes that have been sent to it base map showing
Go to the SETTINGS menu and select the MAP INFO menu. Make sure that the check box by the uploaded map that you want to use is checked. If the map is not checked, then only the base map will appear. This allows different maps to be installed simultaneously.
Jul 29, 2010 | Garmin Quest GPS Receiver
My Garmin Quest displays...detail maps don't support routing.The position of my vehicle is shown slightly to the left of the roads I am driving on.
May be zoomed in to close, could be that the antenna is not receiving good satellite signals, some windshields have metal to lower sun energy and this can affect reception. Try external antenna.....
Feb 13, 2010 | Garmin Quest GPS Receiver
"Detail maps Don't Support Routing" in Garmin Quest
I too have a Garmin Quest and yesterday felt like throwing it against the wall because of the above problem. I found the solution eventually. When you download the maps from the Garmin Maps page, where you select the maps download, make sure that the checkbox to "Include route calculation data" is ticked before downloading your maps. Also make sure that the total memory required for the number of maps selected does not exceed the available memory on your Quest. If you try to fit more information into your Quest than it can receive then you are bound to have some problems. The Quests seems to have different memory specifications. According to the USA spec the memory is only 128mb, the Garmin site says 115mb and the box that my Quest came in says that it has 243mb.
Jul 10, 2009 | Garmin Quest GPS Receiver
Garmin Quest: Not able to upload detail maps
hi bud, just had the same problem. hard reset i.e turn off unit, hold down ok, page and then the power button at the same time. it should then ask you if you want to delete all data. select yes and then you should be able to upload your maps again, this worked for me good luck
Feb 18, 2009 | Garmin Quest GPS Receiver
Screen froze up
"If your Quest locks up....on rare occasions, your Quest may freeze or lock up. In this case, reset the Quest by pressing the unit's Power key and the IN key at the same time. This will turn off your Quest. The unit will operate normally when you turn it on again."
Aug 02, 2008 | Garmin Quest GPS Receiver
Garmin Quest
Press Power, Page and OK buttons.
This happened to me twice, and both times were after I had downloaded a long route. Both times, the only available fix was to do a "hard reboot" by selecting page-OK-power and then selecting "yes". That restored operation, but it also deleted the downloaded maps, routes, and waypoints, and forgot my preselected options.
(In MapSource, I had used the "Select maps around route" option, and both times the total memory associated with the selected maps was much less than 115MB - one was 59MB and the other was 63MB. And in three years this has never happened when fewer maps were loaded. My experiences therefore suggest that the actual working memory available for downloading is much less than 115MB - I don't yet know what the actual limit is.)
May 24, 2008 | Garmin Quest GPS Receiver
Garmin Quest GPS Receiver Logo
126 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
