Question about Whirlpool GS6SHEXMB / GS6SHEXMQ / GS6SHEXMT Side by Side Refrigerator
When i open the door on the refrigerator side, the light does not come on nor due the refrigerator and freezer setting led lights come on. I checked the light bulb and it works in a table lamp. Charlie
  • 1 more comment
  • dibelloc Sep 28, 2010
    where do i find the board and how do i get at it ?
    Thank You
    But will this solve the problem of the led lights for the temp. settings. They do not light up? but the refrig still keeps the food cold.
    Charlie
    President:
  • 2,047 Answers
Hello charlie, if you have checked the lamp and it comes on then this is what you should do trace the lamp switch in the fridge it is usually a small mechanism around the door which gets depressed as the door swings open. If this is located try ensuring that the door and the switch make proper contact or depress the switch manually. If the bulb comes on then the door should be checked as this means the door does not depress the switchproperly. If it doesnt come on then the switch of the lamp holder is faulty and should be examined by an expert.
Hope this solution has been helpful?
Posted on Sep 28, 2010
  • Rockme
    Rockme Sep 29, 2010
  • Rockme
    Rockme Sep 29, 2010
    Most times the switch just needs a little tap and it works right back. just like it was never faulty.
  • 944 Answers
The problem is with the main control board.You have to do continuity testing on the board.Check for the wiring connections from and to the board.When the main control board is defective usually this happens.Take it to the service centre to solve this issue.Because if you want to it you have to fully replace the board which costs 250$.If it is small defect in the board they will replace the capacitors or resistors based on which one is defective.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 28, 2010
    Back side of the Led follow the wiring.Shortly it will lead to control board.
    Natarajan Ramasamy Sep 29, 2010
    See the main control board takes care of working of the fridge and lights.I told only the light control int he main board is defective.We also have another board temperature control board.
Why won't interior lights go off
Bad door switch. Replace it or just ignore it. Use LED light so it will not produce heat in the frig.
May 03, 2014 | LG Refrigerators
LED linterior lighting
Could be your low voltage transformer PART NUMBER: WR55X10747
Mar 27, 2013 | General Electric Profile PFSF5PJX Bottom...
I have had fours Sears repairmen at my home trying to find put why the light doesn't come on when door is opened. Replaced LED light assembly, transformer, tested door switches. They have no idea. One year...
Have they checked the wiring to see if they have the correct voltage to the light. You could have a broken wire between the switch and the lite or power source......or it may not be it the power side you could have an open neutral wire which is alot harder to trace.....
Mar 17, 2011 | GE Profile 20.7 Cu. Ft. Side-by-Side...
The ice maker has stopped working , a red light is flashing.
according to the led flash cycle, you can figure this out. if you open the freezer door and the light flashes two times, that is normal. if you close the flapper on the left side of the freezer, the light should remain lit, and that means that the optic system is functioning correctly. there is a diagram behind the vent panel on the bottom front of the fridge.
Nov 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Inside LED and light on fridge do not work.
First check your light bulb to see if it's good, if it is replace the door sw( it's the switch the door hits when closing ), It can be a pain to remove but that's the only parts that make up the light circut hope this helps
Jan 08, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Kitchenaid # KSRA25C
Some precautions before diagnosing the icemaker optics system since there are two different sets of emitter-receiver optics boards and therefore two entirely different procedures for emitter-receiver optics board diagnosis. This could get really tricky especially when the appropriate tech sheet isn’t handily available. To determine which optics diagnostic procedure should be employed, open the freezer door and observe the right side (mullion or partition side) LED status light. If the red LED is NOT flashing two repeating pulses, this usually indicates the older style emitter-receiver optics boards are used and its specific diagnosis procedure should be employed. But then again, this could also mean that the new optics system IS used but the icemaker just happens to be in the harvest mode - OR - the LED (optics receiver) has failed in some bizarre twist of fate. However, keeping the above cautions in mind, we can assume that normally the older emitter-receiver optics system will NOT have its red LED status light flashing each time the freezer door is opened, while the NEW style optics WILL have its red LED status light double pulsing at each door opening.
Aug 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool Gs5shaxnb02 Ice maker
the most comon problem is the ice machine in the freezer actuates at low teperatures. actuation is when the unit goes into harvest the ice. if your freezer is not aciving low enough temperature the ice machine stops working ' check to ensure the condensor under the fridge is not pluged with dust .Also make shure there is adiquit air flow around the ice machine. hope this helped someone .
http://www.whirlpool.com/custserv/index.jsp
Jul 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GS6SHEXMB / GS6SHEXMQ / GS6SHEXMT Side by Side Refrigerator Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
