Question about Microwave Ovens
Jenn Air Model CVE4270B manual - Microwave Ovens
Manual for jenn air microwave model m166
Request the manual directly from Jenn-Air.
Jan 24, 2015 | Microwave Ovens
Manual for jenn air microwave jmc8130dds
Like most manufacturers these days, Jenn-Air offers manuals online. I did not see specific instructions for removing the panel, but here is a link to the parts diagram which may offer some hints. You can also call or chat online with Jenn-Air Customer Care.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20JMC8130DDS.pdf
Jan 01, 2015 | Jenn-Air JMC8130DDS Microwave Oven
Jenn air microwave model jmv820aas shut down completely, what do i do?
I'm guessing you might mean JMV8208AAS?
If so, then the service manual is at our site here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can order Jenn Air parts here.
Your problem will be either the line fuse, or one of the thermal cutouts / TCOs in the unit.
In case it needs circuit board repair, see this link.
Nov 27, 2012 | Jenn-Air JMV8208AAS Microwave Oven
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
May 08, 2011 | Jenn-Air Microwave Ovens
I need the wall template for a jenn air micro wave oven model no.jmv8208ds
That is part number W10188240 and you can order it here.
You can download the installation instructions free here.
The owner's manual is here.
Dec 18, 2010 | Jenn-Air Microwave Ovens
My JENN-AIR Microwave Oven stop working, no light is coming in front pennel, I checked power exist in wall outlet, I suspect some kind of fuse blown into microwave oven, my microwave oven make & model...
Hi, my name is Audrey and I am a Jenn-Air employee. I would appreciate the opportunity to assist you with your microwave. Please send me an email through our customer service address,
NAR_JennAir_CustomerExperience@JennAir.com
and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model/serial number, and I will look into the issue for you.
Oct 26, 2010 | Jenn-Air JMV8208A Microwave Oven
I have a Jenn-Air M170 & parts of the inner door have cracked and broken, exposing the interior metal. Can the door be repaired or do I need to replace the unit? Does Jenn-Air still make this model?
Yes you will have to replace it, and yes, i am fairly sure they still have that part in stock. please use the direct link below to ask and obtain the part you need.
Also please ask them for the service manual too, this will make the task ever so much easier.. However the replacement parts used to come with fitting instructions..
http://www.jennair.com/flash.cmd?/#/page/customerservice
Aug 19, 2010 | Jenn-Air M170 Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn-air microwave dead
I'm afraid since Jenn Air has become a division of Whirlpool (along with numerous others) the quality has suffered.
I was going to suggest that you purchase a service manual for your unit so you could 'reset' it yourself. Service manuals can cost from $12-$40 US and in many cases obviate the need for 'professional' service calls. However, I couldn't find one offered for your model number so your only choices are to continue to pay for 'service' or examine the guts visually to see if you can locate any reset feature. This is what I would do.
When microwaves fail, older ones generally need a diode, a big capacitor or the magnetron replaced. Newer units are suffering power supply failures as many have moved from the reliable but less efficient 'linear' power supplies to 'switched mode' types that are more efficient but more complex and prone to failure. These later types usually have the word 'inverter' in the model description.
Jan 04, 2009 | Jenn-Air JMC8130DD Microwave Oven
JMV8186AAB microwave oven
You can download Jenn-Air/Whirlpool owner's manuals and installation instructions here.
Dec 15, 2008 | Jenn-Air JMV8186AA Microwave Oven
Microwave Ovens Logo
139 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
