I need to replace a fuse on the main board and need the part number for it.
  • 85 Answers
Hi there.
fuses do not have part numbers,rather board reference numbers,for example,-F201-.
if it is a glass fuse,or white ceramic fuse,the rating is on one of the silver coloured end caps.
eg.t4a or t3.15a. the suffix t means time lag,or slow blow, and a f means fastblow. the rating numbers after the suffix relates to the amps the fuse is rated in.
remember fuses seldom fail without reason nowadays!!!
Posted on Sep 28, 2010
Rotor wont spin
make this tests and fix it. God bless you
Thermal Fuse
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Switch
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Door Latch
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Jul 24, 2013 | Fisher and Paykel Dishwashers
Ariston Dish Washer LSE620A
test this steps and fix it. God bless you
Thermal Fuse
Door Switch
Door Latch
Main Control Board
Touchpad
Timer
Jul 22, 2013 | Dishwashers
No power
test this steps and fix it.God bless you
Thermal Fuse
Door Switch
Door Latch
Main Control Board
Touchpad
Timer
Jul 22, 2013 | Westinghouse Dishwashers
Number one fuse on my main board is deadl vizio gv47l hd tv 10 amp
If fuse is dead, there must be some reason for that. Some short circuit or so. Without rectifying the fault, if you replace it with an other fuse, the fuse you insert will also blow out, and might make more faults to occur. The rating of fuse will be marked on the printed circuit board itself, very near to the fuse.
Aug 19, 2012 | Vizio Televison & Video
VIZIO LED TV MAIN BOARD FUSES
Check and replace the board. It will have some direct shorted component/s on it.
Aug 19, 2012 | Vizio GV47LF Television
MY PS3 WONT TURN BACK ON
Either power supply problem or blown surface mount fuse on the main board. First check all SMD fuses on the main board, and the fuse on the power supply board. If the power supply board fuse has blown replace it and try again, if it blows again you need to replace the power supply. If the power supply seems OK check all SMD fuses on the main board. There are 7 on the V3 and about a dozen on the V4 / V5 / V6.
Good luck...
May 30, 2010 | Sony Playstation 3 (PS3) Console
Maytag refrigerator
IF BOTH WATER AND ICE MAKER ARE NOT WORKING YOU MAIN NEED THE MAIN BOARD. THERE IS NO FUSE.
Apr 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Red light flashing, no picture/sound!!!!
HI, this unit has 3 main fuse links on the main board that may be blown. the fuse links should be check before you move further into the diagnosis stage. once you have checked the fuses and they are still in a working state, this will confirm a power supply board failure. this board provides and regulates the current flow and distribution of it throughout the entire unit. If the fuses are fine and the power supply board is damaged, the green light will come on briefly then, the main control will notice that the power supply is not functioning properly. Once the main control board senses an abnormal current, it will shut down the TV rendering the red light warning. The list of fuses to check are below. Remember, if they are fine and working, the issue will be the power supply board itself and, it will need to be replaced.
FUSE CHECK LIST--
3A 12v- fuse----(242208600623)
SM 3A 125v-fuse----(242208600657)
500 MA-fuse-----(242208611092)
PART NUMBER FOR POWER SUPPLY BOARD
(996500036816)
Please rate and god bless:)
Apr 13, 2009 | Philips 42PF9631D 42 in. Plasma Television
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
Electro Med Services...
