Question about Quinny Buzz Three Wheel Stroller
How do I put on the red sleeping bag onto my quinny seat? I am not sure how to remove straps? Thanks
  • 419 Answers
If you undo the shoulder pads, there is a clip to undo the strap, then you can slide this through the sleeping bag slits.
Hope this helps.
Posted on Sep 28, 2010
In need the instructions
This is a seat post mounted bag, with attachments for the rails (2) on the bottom of the seatpost.
1. The straps going over the top of the bag will have to come apart. Removing them from the loop they pass through before re-attaching with the velcro.
2. Undo the straps and then feed them over the metal seat rails.
3. Re-assemble the straps in the same manner they were before and loosely attach the velcro. You will later tighten up the tension on these straps to snug the bag up under the seat.
4. Attach the velcro strap on the posterior of the bag to the seatpost.
5. Now the bag should be supported by the seat post strap and the seat rail straps (2). Hanging loosely and oddly from the seat area.
6. Tighten/snug the straps from step three, so the bag is drawn up against the bottom of the seat. Try adjusting all the straps on the bag until the bag appears to sit well under the seat.
7. DONE
Jan 05, 2013 | Avenir Bigmouth Seat Bag
How do you put the straps through the coseytoes
In the cosy toes you should have little slits for all of the straps to go through, if you unclip all of the straps so they are all seperate then place the cosytoes onto the seat, the straps should slide through fuss free, once you have pulled them through the slits just attatch them all back together and you should be ready to go
Hope this helps
Mar 01, 2011 | Quinny Buzz Three Wheel Stroller
Dreami - Black Bassinet: I've just bought a Quinny Freestyle and would like...
Yes you can. You need a set of adaptors( the same ones as for attaching a maxi cosi car seat) You remove the seat unit by unbuckling all straps and taking it off. Then you then need to remove the 2covers above the quinny logo on the sides of the pushchair frame. You do this by pressing the silver buttons to release them and then they should slide off. You then replace these with the adaptors for the carrycot. These slide into position until you hear a click. They are marked left and right. The carrycot is then placed onto these(again it will click on) parent facing. To remove the carrycot you then press on the silver buttons on the carrycot unit and lift off using the handle in the carrycot hood. HTH
May 18, 2010 | Quinny Dreami - Black Bassinet
How do you put the cover on the seat?
If it's the new model then you need to follow this in reverse order for Cleaning the Quinny Buzz seats (comfort cushion and XL seat)
1. Open safety harness
2. Unfasten the shoulder belt snap and hook and remove the belt pad.
3. Loosen all snaps on the bottom of the seat
4. Loosen the Velcro straps on the bottom of the seat. Remove the belt buckle through the opening of the seat
5. Slide the cord of the seats out of the edges of the Quinny Buzz seat. Start with the foot section and work towards the head section
6. Pull the lap belt of the Quinny Buzz seat through the holes of the seats and remove the loops from the shoulder belts from the openings of the seat
May 19, 2010 | Quinny Buzz 3 - Juice Travel System...
I dont know how to attach the sleeping bag to the stroller? or how to losen the straps so that my baby can be straped in!?
If you undo the shoulder pads on the straps, you will see a metal hook, undo this hook and you will then be able to slide these through the holes in the footmuff. If you are finding the straps a little too short, I would suggest that you contact www.quinny.com who will be able to send you some harness extenders straps.
I hope this helps.
Oct 02, 2009 | Quinny Buzz 3 Sulphur Jogger
How do the straps go for the saddlebags on a 2003 Buell Blast?
I have a 2007 Blast. It really depends on the make of the saddle bags but assuming they are generic soft bags, here is the usual procedure.
Remove the seat. The connecting center straps for the bags will go under the seat and are held in place by the seat itself. Laying the straps over the top of the seat will allow them to shift and/or blow completely off the bike.
Adjust the straps so that the bags are as close to the edge of the seat while still hanging at a verticle angle. Too loose they hang too low. Too tight and they will compress around the bodywork of the tail section and reduce the usable space inside the bag or possibly damage the contents you fill it with. Once the seat is put back on that is usually enough to keep the straps secured from sliding front or back but depending on the placement of the bag straps you could place a strap behind a d-ring peg to keep the bag from sliding down towards the front of the bike.
Usually you need to nothing more to secure the bags but depending on the bag itself there may be a strap you can anchor the bottom of each bag to the passenger peg or a strap that connects the two bags across the bottom of the bags. Just remember to NEVER anchor the bags to the swingarm. It may seem like a no brainer but you'd be surprised at how many people don't think that far ahead and do it anyway. LOL.
Jun 21, 2009 | 2003 Buell Blast
Ever go camping with a speedy?
Couldn't find an image fulled loaded Triumph fabric saddle bags I bought off the classified section on this site Then I basically bungee sleeping pad and sleeping bag across the bags and pass seat. The bags and seat basically make a flat platform that is easy to stack stuff on. Bungee net is your friend. I did a 3 day 1000+ mile trip thru the CA Sierras this summer and Speedy toured very well.
Nov 10, 2008 | 2007 Triumph Speed triple
How to fit the quinny sleeping bag?
If you unstrap the harness at the shoulder pads, you can then pull the whole strap through sleeping bag and push the bottom part through the hole on the seat, then reclip through shoulder pads.
Oct 16, 2008 | Quinny Buzz Jogger
Quinny buzz, dont know how to attach the carrier bag
If you are talking about the quinny 'buzz box' bag, then it clips on underneath the seat chassis where the back wheels are. On the back of the frame you will see to litttle catches sticking out, one on either side, and the buzz bag hooks onto these.
Apr 23, 2008 | Quinny Buzz Jogger
Quinny Buzz Three Wheel Stroller Logo
106 people viewed this question
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Oloyede Monsuru
ray gallant
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
