Question about Cell Phones
Removing back cover from 6500 slide
Have lost my manual and cannot remove back from my phone please help
  • samosapowis Feb 19, 2009
    wow i am so glad to have found this solution the orange company told me to take it to a shop, its like after 5.30 everywhere is closed until tomorrow im not waiting that long and you fixed it the problem has been resolved love it so much thanks guys :)
At the top of your phone there is the two holes either side, (one being for the headphones, and other being for your charger) there is also the usb bit in between the two holes, and next to that is an arrown in a little square box, push down on the arrow, and the back should come off.
By the way i am haveing trouble with my phone, apparently there is a fault with the nokia 6500's, so beware, your phone may be ok anyway.
Posted on May 24, 2008
Thaks it help me
Posted on Oct 15, 2008
My nokia 6500 slide can not read the memory card, please help..
If the memory card is OK.then check the back cover,generally this phone has a pin on the back cover to press the mmc leap switch.Anyway You can try, first remove the back cover, open Gallery in your phone and press the switch which is located near the mmc slot.If there is no internal damage Memory will be shown when you press the leap switch.If mmc is shown put a piece of paper of something to block.Otherwise you need to contact mobile repairing shop.Good luck
Feb 24, 2012 | Nokia 6500 Slide Cellular Phone
Display is not working in nokia 6500. which is the lcd ic of 3 near lcd conector?
Firstly, remove the back cover. remove 4 nuts from the back too. carefully crack it open and then take off the flex from the panel. slide it up immediately. you'll see 4 other nuts. loose them and take the front off. carefully remove the screen from the clip and at the side of the clip you'll see an ic, that's it-take it off with your work station and then replace it with another ic.
Nov 04, 2011 | Nokia 6500 Slide Cellular Phone
Nokia 6500 camera on stand by problem so please help me how to solve this problem
Did you try to reset the phone by removing the battery and placing it back after some time? This normally resets the phone and correct any errors if there is any. Hope this helps.
Jul 10, 2010 | Nokia 6500 Slide Cellular Phone
Lost all data
you canno't retrieve it anymore.before restoring your phone you must back up all of your files.
Jul 25, 2009 | Nokia 6500 Slide Cellular Phone
Sir, how remove 1gb micro sd memory card password pls help me ME HAVING SAME PROBLEM 6500 PASSWARD OF MEMORY CARD LOST.......
place the card into a different machine ie computer, and format the card. then put it back in your phone
May 28, 2009 | Nokia 6500 Slide Cellular Phone
Nokia 6500 slide
Switch d phone off, press d following keys @ once;*,3 and d green key, den switch on your phone. This setting resets ur phone all data save on phone memory will be lost!
Apr 29, 2009 | Nokia 6500 Slide Cellular Phone
I want to remove my sim but dont know how
ure sim card should be located underneath your battery.. remove your battery cover (which is on the back of your phone), take out your battery, and you should be able to slide out your sim card..
Feb 23, 2009 | Nokia 6500 Slide Cellular Phone
I just purchased a nokia 6500 and cannot remove the battery can you help please
try hitting the back of it with a 10 pound sledgehammer. If THAT doesn't get your battery out, nothing will...
Jan 20, 2009 | Nokia 6500 Slide Cellular Phone
Nokia 6500 slide security code
NOKIA 6500 SLIDE ASKING FOR SECUIRTY CODE TRIED 12345 BUT DOES NOT WORK HELP
Aug 19, 2008 | Nokia 6500 Slide Cellular Phone
Cell Phones Logo
3,604 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
