Question about Oster 5965 Electric Kettle
It won't turn on when I push down the switch. It worked perfectly minutes before.
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 11 Answers
Ultimately, how I ended up fixing my Oster 5965 and Hamilton Beach Cool Touch Electric 40898 kettles that had the same problems as you (Nothing would work; no heat, no buttons would light up) was by taking apart the bottom screws (Be warned, for only one screw I needed a "Spanner Insert Bit"). I jiggled the connectors as I rang them out with my multimeter and everything seemed to work. Leaving the bottom off I retested the kettle and it just worked. I reassembled the parts and made my happy wife a cup of English Tea.
It won't turn on when I push down the switch. It - 06f483e8-b64b-46c6-8965-db6713dd9053.jpg
Posted on Aug 31, 2014
IMac G5 17" won't shut down
I have minor shutdown problem with mail, won't close or shut down. My ans top left APPLE drop down, force closure, turn of each programme listed. For me works a treat.
Jan 19, 2013 | Apple Computers & Internet
My computer i in sleep mode
Sounds like it is locked up. There should be a power switch on the back. Switch it off, leave it off for a few minutes, then turn the back power switch on again and push the front power switch. If no rear switch, pull the plug. Windows doesn't like hard power downs, but if your system won't recognize the keystrokes or mouse movement, tere is nothing else you can do.
Oct 31, 2012 | HP Computers & Internet
JennAir Microwave works perfectly but won't quit running.
One or two of the micro switches have failed, you will need a professional to remedy the situation.
Apr 03, 2012 | Jenn-Air Microwave Ovens
Cuisinart DLC-8S Food Processor: On/Off Switch not working
Replacement of the switch would be a likely repair unless other damage makes replacement impractical.
Apr 14, 2017 | Cuisinart DCC Food Processors
How do i set the clock on my yamaha v star 1300
Turn key to on, hold select switch up for 10 seconds, and hold reset switch for 5 seconds while continuing to hold select switch. Hours should be flashing. Push select switch down to change hour. Push reset switch to select minutes. Push reset switch to finish.
God Bless and ride safe :-)
Oct 14, 2011 | 2007 Yamaha V Star 1300
Car was rinning perfect. One day it would not start. there was nothing, no clicking ,bell and guages were working. Jump start was nothing. Installed a new battery there was nothing. Went bact back 2 hours...
It sounds like you have an issue with your PassLock security system. I had the same with my 2002 Impala. Key turns OK, but won't start, won't crank. Wait 20-30 minutes, and car starts normally. There is usually a clue from the Battery and Security lights.
The problem starting to happen once a month, and eventually 1-2 times a week.
There are several write-ups on this problem for several GM cars for 2000-2006(?). Search this website, and search the web.
The official solution is to replace the ignition switch. The best solution is to bypass the Pass Lock system. I went ahead and did a full bypass, which involves cutting wires and adding resistors to the ignition circuit. I have not had a problem since.
Aug 19, 2011 | 2004 Chevrolet Impala
'91 LS400, trunk will not open. key will not turn, electric latch switch clicks but won't open. valet lock in open position. Tried 1) disconnect battery, reconnect battery, use switch, push down on...
If you hear the sound of the electric latch switch, then it's working but stuck somehow. Just put the key in the switch and turn it to the right and then pull up the trunk or ask someone to help you. it will open. I tried it today and it opened with me. It was stuck from inside by some kind of a broken plastic pieces. Just removed it and now it's working fine. good luck
May 26, 2011 | 1991 Lexus LS 400
My 2004 ford expedition was runing perfect when I got home and parked it in the driveway few minutes later I tred to start it and it looked like it was running out of gas started to shake and the engine...
Hello You will have to reset your fuel pump switch located passenger side right foot kick panel when you press it it should stay down if this does not work your probably looking at a fuel pump not working.
Jan 06, 2011 | 2004 Ford Expedition
Dyson animal, have to hold ON switch for it to work
Pull the wand out of the Vac. Need to use a small Torx bit to take out 2 screws hidden behind the wand storage. Once screws are out, there are 4 push-clips which need to be un-latched. Pry the power panel off and you will expose the two switches (one for power, one for the brushes). Push the power switch down and it should "release" and go back to clicking when pushed. Re-assemble. Took about 5 minutes to fix.
Aug 06, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Oster 5965 Electric Kettle Logo
365 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
