Question about Sony ICF-SW77 AM/FM/SW Radio
Quit AM. FM distorted...After a while switching OFF and ON starts working but usually sensitivity is low...Please respond...Marek
  • Rod Wallberg
    Rod Wallberg Feb 24, 2012
    Your receiver is in need of electrolytic capacitor replacement, please contact me for I am able to work on these radios. Rod email me .... poikaa(at)yahoo(dot)com
The FM function starts off great but loses reception after a couple of minutes and now the AM function has so much static you can not hear
AM FM TV Reception Guide and Directory ยป FM Reception ...
www.amfmreception.com/fm-radio/fm-reception-guide
Coax is a source of loss of signal from the FM antenna to the FM receiver and can also .... I believe the FM sound quality would strictly be a function of the tuner when ...It picks up the least off the side, but it does pick up some of the side. ...... THE ELECTRONICS so as not to short anything or to start the Great Chicago Fire of ...Missing: video
How to Avoid Distortion in Audio/Video Transmitters ' eBay
www.ebay.com > ... > Audio/Video Transmitters
An audio / video transmitter, or AV transmitter, is a wireless device that sends audioand ... As with all wireless signals, one can experience distortion or signal loss. ... AV signals are usually transmitted via wideband FM (frequency modulation) ... that of indoor transmitters, but the range drops off significantly the moment an ...
Jan 17, 2016 | Audio Players & Recorders
Fisher receiver 800-c serial no, year made
Specifications
Tuning range: FM, MW
Power output: 30 watts per channel into 8? (stereo)
Frequency response: 25Hz to 25kHz
Total harmonic distortion: 0.7%
Input sensitivity: 3.3mV (MM), 230mV (line)
Signal to noise ratio: 80dB (line)
Channel separation: 50dB (line)
Year: 1964
Feb 26, 2015 | Fisher Washing Machines
Isuzu trooper 2001 battery replaced and key fob does not work with door locks but responds with 5 beeps when lock button is pushed. What might be the problem here. Thanks RJ
possibly it still thinks a door is open check out rear cargo door switch this is usually the culprit because its seperate from the rest of the doors. turn on rear cargo light to doors ,make sure it works then shut rear cargo door and see if light is still on. if light is still on theres your problem.
look at switch usually they get dammaged/distorted over time.
Feb 21, 2011 | 2001 Isuzu Trooper
Sony ICF ICF 77 Receiver has intermittent Low Frequency distortion burst when tune exactly to the center of an FM frequency, say 102.5 mHz. When radio is tuned .5 mHz. + or - of the main channel frequency...
Usual problem of these receivers is faulty capacitors. Recommend replacement of all surface mount capacitors and alignment. Contact me .... poikaa(at)yahoo(dot)com
Jan 13, 2011 | Sony ICF-SW77 AM/FM/SW Radio
Samsung syncmaster 204b not turning on- My monitor's problem was when it switched off, the only way to make it work was switching off main power, and turning on again, then it would come back on...
in near your monitor u find any metallic product than you please remove the the monitor and plug in another side if your problems is steel not solved than you please contact samsung service center regarding this issue...........
Dec 17, 2010 | Samsung SyncMaster 204B (Silver, Black)...
My 2010 Ultra Classic with 200 miles has cd skip. Store bought home made and mp3 all skip. Bike was ok for first 50 miles. Sometimes it switches to the weatherband. Plugged in ipod as alternate and...
Radio switching to weatherband is an indication that the weather alert function of the CB is turned on. If the weather channel transmits an alert signal, it will switch to weatherband. Speakers cutting out may be your VOX setting is too sensitive or the squelch setting on the CB is too sensitive. Lower both the VOX and squealch and see if that works. If the issue continues, contact Iron Cross Audio for more help. www.ironcrossaudio.com
Sep 03, 2010 | Harley Davidson 426290 AM/FM Radio
CD player quit working after battery installation
Some of these new systems are very finicky, to reset you need to disconnect the negative battery cable wait a few minutes then reconnect, new electronics are sensitive to the difference.
It's possible the low voltage caused by the dying battery actually damaged your CD player, digital electronics are great but they have some serious weaknesses too.
Find out what brand and model your CD player is then go online and do a search for a service manual for your player, you may find an easy fix that way.
Best of luck!
Jun 06, 2010 | 2005 Jeep Liberty
Drivers side window wont work and power locks dont work ,mirror works, passenger window works
I have the exact same problem. Fuses look good, I have no idea what the problem is?
Jan 16, 2010 | 2005 Chevrolet Colorado
JL Audio 1000/1 hook up to alpine type x
it is all up to the user, you can start by turning the input up slightly, I would not go over halfway because it usually starts to distort, then the bass boost up till they distort a little then back down a quarter turn.
Mar 10, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Blaupunkt MP74 compatible CD Changers
Specifications
Amplifier
Output power: 4 x 18 watts sine
at 14.4 V and 1%
distortion factor at
4 ohms.
4 x 26 watts sine
in accordance
with DIN 45324
at 14.4 V at 4
ohms.
4 x 50 watts max.
power
Tuner
Wavebands:
FM : 87.5 - 108 MHz
MW : 531 – 1 602 kHz
LW : 153 – 279 kHz
FM frequency response:
20 - 16,000 Hz
CD
Frequency response:
15 - 20,000 Hz
Pre-amp out
4 channels: 4 V / < 1 kω
AUX input
Input sensitivity: 1.2 V / 10 kω
Above are specs for the LA mp74 digiceiver
This is where I found the pdf information for cdc ao71 changer, only problem is it is in other languages.
http://fe0wap79.bosch.de/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/EUR/BeAT_ServiceDocuments-Start;sid=xMwY5KjfON3gIuDbMbhKGKdU-8dWMZg3sZ0=?Language=FR&search_query_name=cdcao71&SellerId=CM_DE
I will keep looking.
Apr 15, 2008 | Car Audio & Video
Sony ICF-SW77 AM/FM/SW Radio Logo
85 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
