Question about Whirlpool Duet GHW9150P Front Load Washer
I can not get it to start all the lights are on and nothing!! its just blinking the time for the wash and that is it.. you cant even shut it off or cancel it.
    Problem Solver:
  • 5 Answers
Unplug unit remove top there should be a diagnostic manual folded in top or at bottom of unit.before using plug washer in and see if problem clears, control may be in a latch loop. if you are not using HE detergent you must!!!!! this unit can suds lock.
hope this helps.
Posted on Sep 28, 2010
Clean light is blinking, when you shut door and push start cycle nothing happens
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Mar 21, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Dishwasher lights up when Normal Wash is pushed, also heat dry - but when start is pushed all three lights (Normal wash, heat dry and washing) blink then go out and nothing happens. This occurred after a 2...
What is the make and model so we can better assist you? In the mean time shut power off to the unit briefly, then turn it back on and try a normal cycle. Will be watching for a make and model here.
Jan 20, 2010 | Dishwashers
I have a GE QuietPower3 dishwasher... the normal wash, heated dry, hot wash and hot start buttons are all flashing... can you tell me what is going on please?
try this, I was researching and found that this solution worked. While all the lights are blinking, close the dishwasher door and let the machine run through the cycles. This actually happens pretty fast. Then it will stop and quiet down and all the blinking lights will shut off. Then just press the buttons you want and hit start and the machine will start. The time it takes for the blinking light to shut off is about 1 to 2 minutes. It worked for me.
Aug 09, 2009 | GE Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
Jan 21, 2009 | Marantz SR6001
Clean light keeps blinking and I can't start a new cycle
That is a comon problem with that model. It is not sensing a temperature change in the water.
Push i believe it is heated dry and sani rinse going back and fourth between the two to clear the code and see if you can get it to complete a cycle. If it doesnt call sears and schedule service there is a service flash repair that should not cost you anything to repair the unit.
Nov 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
CL keeps blinking
shut down electric to dwasher to reset board
May 31, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool Duet GHW9150P Front Load Washer Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
