Question about Kenmore Elite Oasis 27052 Top Load Washer
Keeps giving me F1 code. i have to stop and start several times to by-pass code
  • 15,935 Answers
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 28, 2010
Testimonial: "thanx extremely helpfull info"
Every time I drive my motorcycle (07 Kawasaki ZX6R) won't pass between 6-8k rpm no matter what gear I'm on it won't pass the rpm and give me power. Also I have the FI light on, checked it and I have c
Two reasons you get the F1 code:
http://ocmoto.com/index.php?topic=31498.0
The fuel injector and timing problems could keep your revs low...check it out.
Jan 04, 2013 | Motorcycles
I have an AEG 6955 washing maching about 14 years old. Recently the program has stopped on many occasions with code F1 usually on first fill. Other times it works OK. The manual says this is no water....
Yes changeing the valve will fix it . around £30. On one occaision only I have come across the detergent dispensor top being blocked up enough to slow down the fill. on your machine it allows 5mins if this is exceeded F1 is displayed and prog stopped.
Nov 15, 2010 | AEG Lavamat 88840 Front Load Washer
The washing stops 3 times when you first start it with the codes F1 on display then 3 more times with 19 min. left with the codes F1. What is F1? Everytime it stops I press the stop button then start...
This F1 Code is a Communication disconnection problem between the Control Unit and the Electronic Curcuit Box. First Check the Connection and reply me with the make and model no.
Sep 21, 2009 | Washing Machines
Machine stops several times shows F1 code
this is a main control board failure and needs to be replaced
Sep 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F-1 code keeps comming up on my Kenmore Gas Range
The information I found today says to replace the keypad or the clock assembly. The ket pad is around $60.00 and the clock I can sell for $245.00. This will give an idea on cost.
May 13, 2009 | Sears 61301 Gas Kitchen Range
F1 error code
The F1 error code indicates a primary control failure or pressure signal out of range. Once the pressure hose & air dome have passed testing, the control board will need replaced. Good Luck And Please Rate FixYa!
Dec 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
How do you open a Kenmore Elite Oasis top-loading washer?
I just finished installing my new control unit for my Kenmore Oasis and my F1 problems are GONE! I ordered it from Sears Direct Parts. With shipping and taxes it came out to about $174 for the part, but our issues are gone and now we can wash a load of clothes without having to reset it several times.
Mar 18, 2008 | Washing Machines
Kenmore Elite Oasis 27052 Top Load Washer Logo
543 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
