Question about SanDisk Sansa Clip MP3 Player
Grrr! I have a Sansa 1GB Clip, it worked perfectly the other day then it just -CRASHED- It didnt even the the 'Low Battery' message or anything. When i plugged it into my computer, it was still recognised but i couldnt delete anything off of it. Some of my Techno remixes (extremely addictive to listen too) are on here and now i can't support my music at any events. I NEED YOUR HELP - MY JOB IS SLIDING AWAY!!!!!
  • ju412west May 26, 2008
    yup,i have the same problem.my pc recognizez it sometimes but it hasnt been workin for weeks and its been chargin for about a month!!!!!!!
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 28, 2008
My Sansa Clip MP3 Player is almost new, however the battery only last about 3-4 hours from fully charged. But now it appears to be completly dead which my computer will not even recognize it to start the...
Hey, greatings from lithuania
i have the same problem. Couple days ago i changed the battery from another sansa clip ant it worked fine, pc recognized sansa again :/ i think that the battery is dead , detailier the microchip wich is on the battery..
Oct 26, 2010 | SanDisk Sansa Clip MP3 Player
I cant charge my sansa clip 1Gb fully and when i unplug it i cant turn it on
probrably because ur sansa battry has run dry which means u need to dend it to sansa for a new battery
Aug 08, 2009 | SanDisk Sansa Clip MP3 Player
Not working 1gb sansa clip
What does that mean - "music db" ? I put all of my music on my 1 Gig and it works great. I put all Harry Potters audio books on my 8 GIG and still have 1.5 gig left for music.
Feb 03, 2009 | SanDisk Sansa Clip MP3 Player
My SanDisk Sansa Clip MP3 Player does turn on but does'nt work.
this should fix it, a tiny software that fixed mine just fine
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Nov 20, 2008 | SanDisk Sansa Clip MP3 Player
Unable to play all songs downloaded on sansa clip
You have to resyhnchroize within Rhapsody itself to make the message go away.
Oct 19, 2008 | SanDisk Sansa Clip MP3 Player
My Sansa clip player was hang & shutdown, its not working right now what i do?
Your Clip never turns on at all? Even when you plug it into the computer?
Oct 04, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip says i must free 4mb then switches off
You should format the device using windows media player or the device itself..that should fix the problem you are having..remember formatting will delete all the date you have on the device..
I hope that helps
Please rate accordingly
Thank you
Computerrep
Sep 19, 2008 | SanDisk Sansa Clip MP3 Player
Combo of: "reading", "writing", "disconnected", "low battery", turning off by itself
why doesn't anyone ever call the hotline?
-Tha Mp3 Doctor
Jul 13, 2008 | SanDisk Sansa Clip MP3 Player
Charging SanDisk Sansa
Go ahead and do this, in case the DB is corrupted:
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 28, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
