Infoprint 1585 The paper is getting jammed at the photoconductor. I changed the photoconductor but it is still jamming. I am also now getting a 201.00 error code. What could cause this type of error?
  • 2 more comments
  • twingfiel341 Sep 28, 2010
    Would the error code indicate that you would need to change the rollers or would that be another problem alltogether?
    Would the roller kit that I need be the 40x0954 feed roller kit?
    All 6 feed rollers were changed and it made no difference. The paper is jamming going into the photoconductor.
    Thank you
  • 3,083 Answers
Error code 20 is a paper sensor error, and the paper sensor should be checked, and the paper rollers replaced if cracked.
Errors in the 200 range indicate a paper jam somewhere that should be checked for.
I couldn't run down any precise information on error 201.00, so you might contact Lexmark support to try to get some insight on that precise error.
Here is their support site:
http://support.lexmark.com/index?page=localeSelect&jumppage=home
Good luck, and hope this helps.
Posted on Sep 28, 2010
    Genius:
  • 1,478 Answers
Among the most common problems with any make of machine are paper jams. A machine will jam for any number of reasons: It's dirty, the wrong paper type is being used, or the rollers on the machine that feed the paper through its pathway are worn down. While cleaning the machine periodically and using the correct paper type are easy fixes, also, if all this are done and the machine still jam, you will need to replace the rollers on the machine, once this replaced, the problem should be fix.
Take care.
My Lexmark c534n printer keeps jamming. I have changed the rubber rollers and the photoconductors. However, the paper will not even go up into photoconductor area. The rollers do try to push the papers...
The fuser rollers might be damaged. Check if the fuser rollers are damaged because if they are they can cause the paper jam, and might need to be replaced.
Nov 07, 2012 | Lexmark C534N Printer
Constant paper jams
Open the printer and with a blower clean it thoroughly.
This resolves the paper jam issue many times.
Nov 16, 2011 | IBM Infoprint 1332 Laser Printer
Printer does not feed paper and display keeps saying paper jam
This is most likely cause by a paper jam in the printer. Simply open the printer up and remove and paper jams then reassemble the computer. I hope this helps and have a nice day!
May 03, 2011 | IBM Infoprint 1312 Laser Printer
Paper jam in tray 2 but there is no paper jam?
check the pick roller from tray2.
try to change the pick rollers tire in the tray.
it worked for me many times
stefan
Apr 14, 2010 | IBM Infoprint 1532 Laser Printer
After changing photoconductor kit and toner, paper jam light stays on and will not go out.
First Make sure you follow the instructions in this link to properly replace and reset your Photoconductor Kit http://bit.ly/9mfe3G.
The if the error light is still on then there might be a piece of paper somewhere in the printer blocking a sensor. Make sure there is no paper jammed in the printer and if there is no paper then a paper sensor is probably damaged.
Jan 07, 2010 | Lexmark E250dn Laser Printer
How do I fix a paper jam cef for epson aculaser cxn11nf?
Diagram of doors should be above control panel of printer.
Lift ADF/Scanner up. Open door "C" just below it. Lift orange photoconductor lever up to release photoconductor. Lift photo conductor up towards you. Inspect for jammed paper and remove if necessary. Replace photoconductor, close lever and door "C".
Open door "E" on rear of printer and look for jammed paper and remove. Close door "E".
Last place to look is in paper tray. Take stack of paper out and look for paper jam. Removed as needed.
These are the three places i have had jams and you will only find the jam in one of them. Most likely it will be in back in Door E
Aug 12, 2009 | Epson ACULASER CX11NF All-In-One Printer
Infoprint 1634 repeatedly jams
It may be time to replace the Fuser.
There is no certified way to repair a Fuser with purchasable parts, the assembly it self must be replaced.
May 22, 2009 | IBM Infoprint 1634 Laser Printer
Paper continually jams
What is the error code from page 69 and 70 of the E-232 manual?
Here is the webpage to download anything that you may be missing. The manual has a very complete section on complete clearing of jams.
http://search.lexmark.com/printer/US/en/22S0200
Dec 22, 2008 | Lexmark E232 Laser Printer
IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Aug 19, 2008 | IBM Infoprint 1332 Laser Printer
199 people viewed this question
k24674
jasbo
jasbo
