Question about OKI MICROLINE 521 Matrix Printer
I the printer is not printing the top of letters instead it is dragging that ink across the paper
  • OKI Master
  • 4,340 Answers
Look at the print head for jewel failure. AFTERMARKET ribbons lack requried lubrication for this style of printer. If you see wear, replace the head. There are remanufactured heads available that have a lubrication wick installed that helps this issue.
Posted on Sep 28, 2010
My printer misses lines when printing.
Definitely a partial clog. Remove your ink cartridge and take it to your microwave. DO NOT PUT IT IN THE MICROWAVE. Fold up some paper towels and apply enough water to the towels to get wet and damp but not dripping. Heat the wet towels in the microwave to get very hot (about 30 seconds). Now, place the cartridge on the steamy hot paper towel and let the steam and hot water dissolve the dried ink. After the towel cools drag the ink contacts across the wet paper towel and look for a smooth and even line of ink. One smooth wide line for black and three smooth lines for the color . Try the drag test on some dry paper towels for the final test. If necessary repeat the whole process again. For stubborn and very old cartridges let set on the wet towel for several hours and recheck. Good Luck.
Dec 29, 2014 | Canon PIXMA iP1000
When printing, print is has irregular & has white streaks through letters. Have tried "Print Head Cleaning" & "Print Head Deep Cleaning" several times and now printer won't...
you can flush the printhead on running water.
and have a mixture of ammonia and water solution. Soak the printhead and leave it overnight. This will unclogged residue in the printhead.
it will work again as good as new.
Jan 18, 2011 | Canon PIXMA iP3500 Printer
HP842C continues to print with nothing on the paper but a line across the top of letters and numbers. The orange light will not go off. There was a paper jam which I removed then paper continued going...
Check your Catridges, they might be dried up if new, or empty, Remove them shake them to feel a presence of ink or tap them on a piece of paper to verify if ink will comeout if not then they are empty and need to be replaced they they have a bit of ink you need to shake and try printing again if this persists change the catridges, also make sure that the Printer is Clean, verify the Catridge Carrier for any dry ink deposits.
Dec 03, 2010 | HP DeskJet 842c InkJet Printer
Why do my pictures look faded with up and down stripes?
Check the paper to make sure you are using the correct paper type for the project. If the paper is too fibrous, the ink applied by the printer might not fully cover the print surface.
  1. In the program being used for printing, click File , and then click Pring . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Press and hold the asterisk (* ) and pound (# ) buttons on the product control panel.
  1. When the control panel reads *******#######, release the asterisk (* ) and pound (# ) buttons.
  2. Press the 3 , 2 , and 9 buttons, in that order.
  3. Press the right arrow button (c00420524.gif ) to select Special Reports , and then press OK .
  4. Press the right arrow button (c00420524.gif ) to select Print Cartridges , and then press OK
Aug 12, 2010 | HP Officejet J5780 All-In-One InkJet...
This is my 3d iP90 in 18 mo. w/same problem: not dragging paper
That is a fairly fragile printer, if you pack them in luggage they put other bags on top which bends the frame of the printer so that paper can't pass thru anymore. The only repair is to replace the entire print engine which costs more than a new printer.
Oct 09, 2009 | Canon PIXMA iP90 Mobile Printer
Printing black horizontal lines below text/on top of pictures
Check the waste recepticle under where the ink cartridges rest in the home position. Over time, ink sprayed into this cup during cleaning cycles builds up to form a small mountain of congealed ink. If this gets too high, it makes contact with the printhead and drags ink across all your prints. If there is a ***** of ink present, scoop it out with a spoon or a popsicle stick.
Dont get it on you, its messy...
Jun 22, 2009 | Dell 924 All-in-One InkJet Printer
I have a HP Photosmart C5180 printer. It is not printing purple-instead what comes out is blue. I have done a print test report and it showed the Light magenta and magenta with missing bars and streaks. I...
If your color improved slightly when running the printhead option then doing more should help get better results. Sometime the printheads get really dirty/clogged and running the cleaning option more then once is needed.
If you get a slight line running across the page (from left to right) usually the indicates dust build up on the printhead or ink carriage. The dust acts as a paint brush being dragged across your paper as the carriage moves across the page during printing. You can clean the bottom of the carriage with a Q-tip or purchase some cleaning paper for your printer.
Apr 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
Photosmart C6300 pictures are printing very wet and grainy. printer is also very loud - almost as though the parts were scraping and banging.
Sounds like you have the wrong paper setting in your print properties. I would use photo or high bright 24lb paper and set the paper type in your printer properties prior to executing the print job.
Regards,
Worldvet
Nov 12, 2008 | HP Office Equipment & Supplies
Left & right streaks when printing
Hi, it sounds that your printer may require service to clean the printhead thourouly.
Tirzo
May 09, 2008 | Epson Stylus CX7800 All-In-One InkJet...
MFC-3240C
The printer may not be scratching your printout but you may have a clogged printhead. A clogged printhead will constantly miss a spot creating an effect of a scratch printout. Please run an all inks printhead cleaning routine (2 or 3 times) and create a test page. Best Regards
Aug 20, 2007 | Brother MFC-3240C All-In-One InkJet...
OKI MICROLINE 521 Matrix Printer Logo
66 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
