Question about Rowenta Professional Luxe DM880 Iron
My Rowenta steam iron is now spitting out brownish water when I use the steam setting....what should I do?
  • Rowenta Master
  • 43,501 Answers
I would try the white vinegar...
Also check out this tip...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
Posted on Sep 28, 2010
My Rowenta Expert steam generation iron (seperate tank for the water type) is starting to spit ever so often brown water out. I only use filtered water. How can I clean the actual Iron, the water tank is...
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Mar 16, 2011 | Rowenta DG-980 Iron
We have Rowenta DM 890 steam iron. It dumps water. Also Why not use distilled water?
The following web blog about Rowenta steam irons has some tips on maintaining the iron:
http://www.nasa1.org/iron%20rowenta.htm
The following web blog explains the issue of not using distilled water:
http://ths.gardenweb.com/forums/load/laundry/msg011421358265.html
I guess the bottom line is that it takes a higher temperature for distilled water to boil. It also explains that will cause the unit to spit, drip, and leak.
Try affordable spring water, and you should get better results.
Jan 27, 2011 | Rowenta Irons
My rowenta iron shuts off in the middle of ironing & spits water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Jun 09, 2010 | Rowenta Powerglide DE011 Iron with Auto...
DG 5030 steam generator-first time used and after...spits water
Common problem if you have the temperature or steam setting set too low (not enough heat/steam to vaporize water droplets or the unit is not up to full temp. I would have a clean towel alongside the iron to give a burst of steam prior to your first press...
May 29, 2010 | Rowenta DG-980 Iron
When the iron is set for steam it spits volumes of water
heatman101
Apr 11, 2010 | Rowenta Power Duo Iron
Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Oct 06, 2009 | Rowenta Irons
My iron is spitting water when i put steam on???
It is overfilled with water. There's right measure for
your iron. It is specified in your manual. If no manual,
just fill it halfway and set your thermoswitch at a little
over half also.
Oct 05, 2009 | Rowenta DG-920 Iron
Dz9080
A pint of white vinigar in the reservoir and steam it thro will clean it up a treat. Steam some clean water through afterwards before using it on your clothes. Best Wishes Rick
May 08, 2008 | Rowenta Steam Generator DG050 Iron
Rowenta Professional Luxe DM880 Iron Logo
1,179 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
