Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
The screen froze and everything tuned a pinkish hue. We called the vendor and he had us unplug it for a few minutes and then it worked fine. Is this something we need to worry about or need to get it fixed?
  • 130 Answers
Hi
no nothing to be worry about some component are very sensitive to static change
and needs to resets sometime
Posted on Sep 28, 2010
My picture is pinkish and glossy
If the overall picture has a pinkish hue to it and skin colors appear to have pinkish blotches. White scenes have a pinkish hue to them then it is is likely the main display board, 6871QCH029A. This board is located next to the Y sustain board. Need to remove the tv from the stand to get to the main display board. I just fixed my Z50PX2D that had the pinkish hue to it by replacing the main logic board. Check ebay for boards.
Jun 23, 2012 | Zenith Z50PX2D 50 in. Plasma HDTV
Acer netbook AO751h screen does not work, external monitor works fine.
Hello !
Since an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
Sep 20, 2010 | Computers & Internet
For the past week my on my colot tv, everything has a pinkish hue to it . i have played with brightness, contrast, color hue,etc; but cannot get nice color; can see colors but background is washed out and...
It looks like degausing problem. You have taken some pocket radio or magnet near your TV. Mostly in the corners it will appear.
If so,
Try your TV in a different orientation. East to West or............
Try switching on the Tv in this position . Do not use remote. Switch off wait for thirty minutes. Again repeat. The auto deguasing will remove this. But you have patiently do this.
Apr 01, 2010 | Televison & Video
I changed the inverter and the screen still won't stay on completely... it keeps coming on for a few seconds and then turns right off. I can use an external monitor though and everything works fine... what...
If you have replaced the inverter board inside the LCD display with a known good one then the most likely cause for your issue is a bad or failing LCD bulb. An easy way to tell if this is the case is in the few seconds that the backlight is working see if you notice a slight pinkish hue in the light. This means that there is a mico-fracture in the bulb itself, as the inverter board supplies power to the failing bulb it heats up and shuts off. LCD bulbs in laptop screens can be replaced but this is not something I recommend for anyone but a VERY advanced user with the correct tools are his or her disposal. I needed, I can provide you with a step by step explanation. If you do not feel that you can handle a bulb replacement then the easiest thing you can do is replace the LCD itself.
Feb 20, 2010 | Dell Inspiron B130 Notebook
MY screen will stay on for 30 seconds, then goes black.
you Screen has a Soildation problem take it to near by electrition he will resolidate your screen and it will then work fine..
Aug 27, 2009 | Proview PL 566s 15" Flat Panel LCD Monitor
Replaced LCD Inverter, now screen comes on and bright but choppy
Does the external monitor display a normal image?
If the images is OK then the video card is OK.
The inverter supplies high voltage to the CCFL lamp which provides the backlighing and does not jumble the colors on the screen. If you get a pinkish hue or a flashing screen then this would indicate
the CCFL lamp is faulty.
From the description of the fault, it indicates that the fault could be a faulty video cable or video connector. Try reseating the video cable/connector on the motherboard.
Jul 19, 2009 | Dell Inspiron 6400 Notebook
IBM Laptop A2629 LCD Problem
sounds like your video is going out wheather its your card or lcd not sure but kinda sounds like the screen
Dec 24, 2008 | IBM ThinkPad A20 2629 Notebook
Not a typical backlight issue
Hi!
You can check the brightness with AC in the BIOS and match it with running in battery or else, when you plug the ac adapter, the lcd goes dim, press and hold the FN buttong and tap the up arrow then reboot and try to see if it will still do it. But still the best way to do it is going to the BIOS by pressing F2 at the Dell logo startup.
Hope this helps!
Thanks,
Karlox™
Jul 30, 2008 | Dell Inspiron 1150 Notebook
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
63 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
