Question about Canon PIXMA MX320 Color USB InkJet Printer
Canon pixma mx328 error 5100 - Canon PIXMA MX320 Color USB InkJet Printer
  • Canon Master
  • 4,737 Answers
This error is one of the most common issues with Canon printer. Let me share my experience and how I used to fix this error.
First, turn off the printer, unplug the usb cable and power cord. Now, also turn off the computer (it needs to be restarted since the error is showing on the computer and will never go until you restart the system).
I hope you are not using longer usb cable other than the one that came with the printer. Sometimes long and defective cable causes this problem.
When you turn on the machine, open the lid (front panel door) and help move the cartridge carriage with your hand so that it'll move sideways. Sometimes when the carriage stuck, this happens.
If the above tips don't help, you need to call Canon and ask them your problem. If you are in the U.S. use this number to call Canon "1-800-OKCANON" or you can write using this form (Click here)
Good luck.
Thanks for using FixYa.
Posted on Sep 28, 2010
jaggujoshi
  • 119 Answers
SOURCE: canon pixma mp540 error 5100
dear,
Error 5100 points to a "carriage jam"
The carriage is the assembly that contains the printhead and cartridges.
This error can be difficult to solve because various things can cause it.
Since this is a new printer, maybe there is some packing or packing tape that is obstructing the carriage.
Verify that the carts and printhead are installed properly.
Check the gears as best you can for any obstructions.
If the carriage moves to a center position when you open the cover as if to change cartridges, try a reset to clear the error message :
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Sometimes you have to try this a couple of times, if you've never done it before.
If this does not work, unplug, wait 3-4 min, then re-plug in. Enjoy..
Posted on Sep 21, 2009
Testimonial: "Really understandable answer, but unfortunatelly, it seems that my printer is dead. thx. L."
  • 412 Answers
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
SOURCE: Service error 5100 on my canon Pixma mp110
Had the same problem, i just replaced the black ink cartridge which was finishing at that time and resetted the counters. No problems after that. Not sure whether this will help though.
Posted on Aug 31, 2008
IB4G2008
  • 3587 Answers
SOURCE: canon pixma mp600 error code 5100
try this solution..from fixmyprinter.com
Posted on Mar 02, 2008
pineworks
  • 4041 Answers
SOURCE: Canon pixma mp170 error code 5100
Hi You can Try
Seen lots of ths errors
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
Error 5200 of canon pixma mx328. i already tried turning it on and off several times and even got the cartridges and returned them back but still when i tried to print a page error 5200 still...
Error no 5200 is caused by its temperature high.. to solve your problem follow the instruction given below::
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 23, 2011 | Canon MX300 Office All-In-One Printer
How do i scan a document to my computer with the canon mx328
Install the Canon scanning software, and use "MP Navigator" software to scan your documents.
Canon PIXMA MX328 software download @ http://support-my.canon-asia.com/P/search?model=PIXMA+MX328&filter=0&menu=download
Hope it helps.
Aug 10, 2011 | Canon PIXMA MX310 All-In-One Printer
HI, HOW CAN I INSTALL MY CANON MX328? MY CD INSTALLER WAS LOST.
You can download the Drivers for Canon MX382 from Canon Official Support Site.
Visit the above link, choose the Operating System and download the divers and software.
Hope this helps! Good Luck!
CreativeTECH
Jan 07, 2011 | Canon PIXMA MX310 All-In-One Printer
Download driver canon printer pixma mx328
Please try the official link for the drivers:
www.canon.driversdown.com/???Canon-driver-list/s_15_???1.shtml
www.canon.com.my/p/EN/120-All-In-One/211-Inkjet/???995-PIXMA-MX328
Sep 29, 2010 | Office Equipment & Supplies
How do I change the ink on the Cannon MX330? I cant find where the cartridge is
I am writing this to enquire in regards to Canon Pixma MX320. I bought a Canon Pixma MX320 about 3 weeks ago, and I have brought it over to overseas. I am wondering if it is possible to change from the general ink cartridge that this particular printer use, which is PG510 and CL511 to another similar ink cartridge, which is PG810 and CL811. This is because, where I am living right now, doesn't have the particular Canon Pixma MX320, but instead Canon Pixma MX328 and MX338. The Canon Pixma MX328 and MX338 uses the PG810 and CL811. So, is it possible to substitute from PG510 to PG810 and CL511 to CL811 for Canon Pixma MX320? Thank you for your help.
Aug 29, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Error U163 appear how can i fix this printer problem on my canon mx328
When this error appear in the lcd control panel of your printer, do this.
1. Press and Hold the STOP/RESET button and wait until itself restart.
2. When the printer restarted release the STOP/RESET button and wait until it fully initialize.
then try printing again.
Please rate this answer. Thanks for using Fixya.
You can also view and rate my helpful tip for this kind of error in Canon Pixma MX328 all-in-one printer
Aug 16, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon MX328
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
error 5100 :
1. clean **** strip film
2. clean **** strip film sensor (back of head carriage)(use contact cleaner)
3. fix purge unit
Apr 24, 2010 | Office Equipment & Supplies
Canon PIXMA MX320 Color USB InkJet Printer Logo
2,434 people viewed this question
old marine
old marine
