Question about HP OfficeJet 7410 All-In-One InkJet Printer
When A/C adapter is plugged in the display shows the initial logo & will not change & there is no sound of anything cycle or initiating. any way to enter a diag mode or initialize printer? Thanks, Joe
    Scholar:
  • 107 Answers
Hello, this problem your having may have multiple solutions, first easy one is to change power supplies, if you have another one, next, take out ink cartridges, if you can. if not able to do any of these, then you may want to take to a printer repair place if there is one near you. the rest of the possible solutions will require you to take machine apart. i always try the easy things first.
Posted on Sep 28, 2010
How to program the zoom 3030 pedal back to factory setting
From the Owner's Manual:
1. disconnect the AC Adapter to the 3030 (Make sure amp volume is all the way down)
2. While holding the STORE key down, reinsert the AC adapter to power back on. (..AL.. will flash on the display, indicating that the 3030 is standing by for the 'All Initialize' operation.
3. Press the STORE key again. The All Initialize function will be executed, and the Play mode returned. To cancel All Initialize function, press EDIT key. This cancels reset, returns to Play mode.
Sep 05, 2014 | Music
Ecs 945gct m3 v h motherboard ver 3.1
Your motherboard keyboard controller is not initializing completely. The three LEDs shows the keyboard is powered and initializes, but the motherboard keyboard controller looks to be bad. I assume the keyboards work on other computers. Make sure there are no jumpers on the motherboard for the keyboard. You said the video screen is stuck on CMOS BIOS logo and is trying to continue with a missing keyboard or keyboard error. So since it got to the BIOS screen, pretty much everything else came up.
Jan 13, 2014 | Computers & Internet
Error code: 0xc18a0001
This error code indicates that you have an 'Ink system failure'. The problem is caused by air the ink feed tubes. If you either use all of the ink down to 0% or you use poorly refilled ink cartridges it can cause the printer to **** air into the feed tubes instead of ink. We have a step by step guide to purge the feed tubes of air on our site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/ There are 2 different versions of the procedure find the one for your type printer and follow the guide and within about 10 minutes you will be printing again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 29, 2010 | HP Photosmart C6180 All-In-One InkJet...
Acer aspire 5050 won't power up. have tried charger on different laptop and it works,
What you need to do is remove/replace "Bits" one at a time, ie: The hard drive, then the DVD, swap out the RAM... until it boots? or at least shows the initial screen. A laptop should display video with, just power adapter, RAM & NO Battery, HD, or DVD connected, although it obviously will not boot as such. If this still doesn't boot/show initial video after this you may find the Motherboard is faulty
Mar 08, 2010 | Acer Aspire 5050 Notebook
Message states: the following ink cartridges cannot be used after device intialization, and must be replaced
Try the following steps to resolve the issue,
1.) Press & hold the * key
2.) press the # key & release both the keys.
3.) Display should say Enter Special Key Combo - Press & release in sequence 1,2 & 3 buttons.
4.) Press and release the right arrow button (or the right arrow icon on touch screen displays) to look for the System Configuration Menu then press OK.
5.) Press and release the right arrow until the Ink Initialization status is displayed.
6.) Press and release the OK button.
7.) Display should say Ink Initialization status: Clear. Press OK to set it.
8.) Press and release the OK button ONCE. (This is very important; do not press the OK button for a second time).
9.) Press the cancel button three times to leave the support menu.
10.) Unplug the unit from the power supply and wait 10 seconds.
11.) Plug in the unit, Follow the on-screen instructions, the unit will initiate the initialization cycle.
Thanks,
Fame..
Oct 23, 2009 | HP Photosmart C6280 Printer
My motherboard have four leds in red light, d0 dled2,dled3 and don`t start up
Hi ntamayo,
Here is the description of what the four leds indicate:
d9c5d26.gifSystem Power ON-The D-LED will hang here if the processor is damaged or not installed properly.
1d08ad7.gifEarly Chipset Initialization
14ff182.gifMemory Detection Test
- Testing onboard memory size. The D-LED will hang if the memory module is damaged or not installed properly
1719312.gifDecompressing BIOS image to RAM for fast booting
1cab634.gifInitializing Keyboard Controller
3b994fe.gifTesting VGA BIOS
- This will start writing VGA sign-on message to the screen
2b36bf2.gifProcessor Initialization
- This will show information regarding the processor (like brand name, system bus, etc...)
f53faac.gifTesting RTC (Real Time Clock)
9ec1db5.gifInitializing Video Interface
- This will start detecting CPU clock, checking type of video onboard. Then, detect and initialize the video adapter
4f7c881.gifBIOS Sign On
- This will start showing information about logo, processor brand name, etc
6a25253.gifTesting Base and Extended Memory
- Testing base memory from 240K to 640K and extended memory above 1MB using various patterns
1bef2e1.gifAssign Resources to all ISA
e664b69.gifInitializing Hard Drive Controller
- This will initialize IDE drive and controller
c3b6c58.gifInitializing Floppy Drive Controller
- This will initializing Floppy Drive and controller
3afd28f.gifBoot Attempt
- This will set low stack and boot via INT 19h
24b95b0.gifOperating System Booting
When your motherboard is stuck on any of these signals, that's a clue that something is wrong with that particular device on the board. Replace it and try again.
Good Luck
And don't forget to leave a rating,
Thanks
Mark
Sep 16, 2009 | MSI MB INTEL E7520|E7520 Master-S2M RTL...
Only displays initial power on screen (SANSA m240 1.0GB)
try changing the battery...it works sometimes....
Aug 11, 2009 | SanDisk Sansa m240 MP3 Player
keep the hold switch to right side and connect to pc...then format the player or try updating the firmware..tht must do...
Jun 17, 2009 | SanDisk Sansa m240 MP3 Player
Outside display screen will not show anything but the motorolla logo
Does anything show on the external display if you go to take a picture, but before you acually take it, close the phone and look on the external display as if you were taking a self-portrait?
To make fully sure, while the phone is closed, press a volume button - does anything show on the display? If so, the external display functions and it would be a setting that may have been overlooked.
Go to Menu > Settings > Initial Setup > Display Timeout
or:
Menu > Settings > Personalise > Home Screen
Nov 01, 2007 | Motorola Mobility RAZR V3
Can't Initialize/Finalize
I dont have a solution, but the same thing is happening to me.
I've recently had an operation and I had before and after pictures,
And because finalize didnt show up I tried initilizing it and all the images got deleted!
Message me back if you find out how to do it!
Thanks!
x
x
Sep 10, 2007 | Canon DC210 DVD Camcorder
HP OfficeJet 7410 All-In-One InkJet Printer Logo
50 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
