Question about Sharp Microwave Ovens
R-426HS purchased Feb. 05 makes loud buzzing sound, whole unit get hot,elec smell.
  • Sharp Master
  • 9,098 Answers
One of the high voltage components has failed, and my suspects (in order) are the high voltage transformer, magnetron, or possibly the high voltage diode.
You can probably replace this oven for less than $150 now, so it may not be economical to take to the shop.
If you or someone you know wants to look into a self-repair, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view and order parts by entering your model number here. Sharp parts are usually less expensive here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/diode.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 27, 2008
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Kenmore Over the Range Microwave making buzzing sound and not heating
This is a strong indicator the magnetron is fried, also! this is the most expensive part to replace in the microwave oven, and in most cases cheaper to replace the whole unit.
Jul 18, 2012 | Microwave Ovens
Microwave makes a loud buzzing noise and emits a burning plastic smell
This indicates the magnetron has failed, buzzing sound and odor are classic symptoms. It is cheaper to replace than have it repaired.
Apr 03, 2011 | Kenmore Microwave Ovens
I have Danby microwave, the food does not heat and there is smells like some thing is burnt. I have opened it and the high voltage transformer does not look burnt.
What is happening is that the magnetron is shorted, causing the high voltage transformer to overheat. That is what you are smelling is the insulation getting hot. When the magnetron shorts out, it makes a loud buzzing sound. Replacement magnetrons costs almost as much as a new oven so it rarely makes sense to fix.
Mar 09, 2011 | Danby DMW902 Microwave Oven
Heat element not working
Well, if there is not heating the food and making a loud buzzing or humming sound when it is on, then the magnetron has failed. It typically shorts out and fails. The magnetron for this cost $140 plus the cost of the service call, you're better off buying a new oven. Hope this helps.
Jul 07, 2010 | Frigidaire FMV156EM Microwave Oven
Making loud buzzing sound & smells like wires burning.
That is the Magnatron or the Hi-Voltage transformer. If I could smell it I could tell the difference. The transformer will produce smoke more so than the Mag.
Eric
Dec 25, 2009 | Microwave Ovens
Not working plmv169dc
HI, the sound you herd was the noise filter and running diode. these important components have failed at this point. you will need to replace these components asap, if possible. this will fix your issue.
The Magnetron Cut-off fuse will need to be replace as well. this will blow if there is a malfunction within the unit.
Jul 22, 2009 | Frigidaire PLMV169DC Microwave Oven
Makes a loud buzzing noise and does not get hot
Have seen this many times.
Sounds like a bad CAP since a bad diode would blow the fuse and a bad mag would likely do the same thing.
Since yours is making the loud 60hz buzz you need to replace the capacator that will likely fix the problem. A $10 fix
Jan 06, 2009 | Kenmore 62622 Microwave Oven
Advantium 120 makes low buzzing sound all the time
this is the transformer that is doing it and it may end up failing soon , and should be replaced before any other dammage is done,
Nov 06, 2008 | GE Advantium 120 Convection/Microwave Oven
No Power at all after loud short buzzing sound
sounds Like an electrical fault in the Micro, Sorry but this is broken.... If this is within warranty (do check as some warrantys are for 3 yrs or more) get the manufacturer to replace/repair it for free. you could get it serviced, but it is probably cheaper to buy a new one.
Aug 24, 2007 | Sharp R-1460 Microwave Oven
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
