Question about Garden
Operation Manual for Topcon Digital Transit DT 30.
How seconds converted into decmal degrees
There are 60 seconds in a minute, and 60 minutes in a degree. So, 1 second is 1/3600 of a degree. So as an example, 9 seconds is equal to 0.0025 deg.
Sep 28, 2014 | Topcon Survey Equipment Dt-30 Digital...
What is topcon pipe laser tp-l4 error code 03
ERROR 03 is a grade circle reading error. The grade system uses an etched glass circle, the same as a digital Theodolite or total station uses, to measure it's grade. If there is a problem with the readings of the circle then values have been lost telling the circuits how to read that exact circle properly, or something has become damaged. I've seen a number of them where the circle was intact, however no longer attached to the axis shaft it is supposed to be permanently fixed to.
The user manual says to turn the unit off and back on, to see if it was just a momentary glitch. I would also remove the battery and external power for a few minutes before I turned it back on. Unfortunately, if that doesn't solve the problem the signals are going to have to be realigned, and parts may have to be replaced. In order to realign the signals, a standalone power supply is needed, as well as a digital oscilloscope and Topcon tolling, called "illuminators".
Aug 28, 2014 | Topcon Tp-l4a Red Beam Pipe Sewer Laser W...
How do I calibrate a topcon laser ?
There are detailed instructions in your users manual on how to check and adjust your Topcon laser. You'll need a tripod, 2 vertical surfaces about 50 meters apart and your laser receiver. It's done by marking positions of the beams, on the different surfaces and then adjusting your laser position to the center of the different positions.
The procedure is different for different models, but i have attached some pictures from the manual for the RL-VH4 series. calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-0.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-2.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-5.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-9.jpg calibrate-topcon-laser-xppjbjvrkh5xtizgw5mfou0l-3-14.jpg
Aug 11, 2014 | Topcon Rotating Builders Red beam Laser...
Download topcon link soft were
you will need to contact topcon this is a very bespoke item and its unlikley other drivers or sync tools will work and the link software may need to be licensed
Jun 11, 2014 | Topcon GTS-102N Total Station
Topcon AG-30B Transit manual
The WEB:
Topcon AG-30 Transit - Mohave Instrument Co
www.mohaveinstrument.com/NewFiles/AG30B.html
This is the classic Topcon AG-30B engineers' transit. The AG-30B has glass ... and a photocopy of the owners manual are included, all for just SOLD. ABOUT US ...
Oct 10, 2013 | Measuring Tools & Sensors
I can't turn off the rear wipers on my Ford Transit van
Please check your Owner's Manual for operation of the wiper. Otherwise, the dealer will be your best resource and will fix it for FREE under warranty.
TD
Oct 24, 2012 | Ford Transit Connect Cars & Trucks
USER MANUAL TOPCON CTS-2
USER MANUAL TOPCON CTS-2 pdf
Mar 01, 2011 | GPS
I don't have the owners manual for my 2002 KIA RIO Cinco and i need the weight for the oil and brand to run in the 1.5 4 cylinder 18hp.
Age of vehicle would suggest a Multigrade 15W/30, such a Castrol, with a replacement Extended Service Oil filter.If you are in a cold weather area, and do a large amount of Stop/Start , or Short distance motoring. The OIL and Filter should be changed, after no more than 4ooo miles of operation.
Regards,DT
Feb 15, 2011 | 2001 Kia Rio
Ineed operation manual
You can download the operation manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jun 27, 2010 | Pentax Optio 30 Digital Camera
Garden Logo
446 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
