Question about Lexmark Wheelwriter 3500 Typewriter
When typing it spaces to the next line without hitting the return button. How do I make it stop?
  • Lexmark Master
  • 3,594 Answers
You may be in auto ret mode and typing into the R. margin.
Try code "R".
DickyO
Posted on Sep 28, 2010
Tracfone's instructions for how to text do not work! what's up?
Texting on this model a bit tricky. First pull up name & number of person you want to text to, if it is in your phone. Then hit short dash line under the word 'options'. Make sure #1, 'create message' is highlighted. Hit ok button. Now type message. If you want a 'v', for example, you have to hit the #8 button 3x quickly. If you make a mistake, hit 'clr' button on top right to clear it & retype. So, for example, you want to send the word 'please'. You would have to hit the #7 button once, wit a second for the curser on screen to move to next space, then hit the # 5 button 3x quickly to get to the 'l', wait for curser, then hit #3 button 2x quickly to get to the 'e', etc. You get the drift. This model is not very conducive to sending longer texts. It's too time consuming & annoying. But short ones are ok if you have the patience. IF you need a space in between words, hit the '0' button once (that's zero, not 'o'). This is where text code comes in handy for shortening words, such as "LOL" for laughing out loud, etc.
Once you are through typing note & want to send it, just hit ok button to send. It may take a bit of time for message to go through. If you type a lot, it may take up more than 1 page, if this happens, the phone will ask you 'message is 3 pages, do you want to send now', or something like that. The longer the message is, the longer it will take to send.
One thing to keep in mind, before you start typing, make sure you hit the bottom lower key that has the asterisk & up arrow on it 3x quickly, or else when you type, it will be all garbley goop. If you want a capital letter, you also have to hit that same key once before you hit letter key. It only works for one letter at a time, so if you need to do more than one, say you want to type "DVD", you have to hit asterisk key once, then #3 button for 'D', then asterisk key again, then #8 button 3x for "V', etc. If you need a symbol or punctuation, use the bottom right hand key that has the # sign on it. Hit it once & some symbols come up, you will have to move over to the one you want by using outlined area around the 'ok' button. Once you get to symbol you want, hit 'ok' button it will add that symbol or punctuation to your text & return you to your text area.
If you do not see the symbol or punctuation you want, hit small dash under the word 'next' & it will take you to the next page. I think there are 7 pages of these different symbols & punctuation.
Hope all that helps. Email me at: ldgtreke4@aol.com, if you have any other questions. Put short note in subject box so I know what this is about. Good luck!
Mar 15, 2015 | Tracfone Wireless LG 440G
Do you have a manual for IBM Wheelwriter 50 Series II
press line space button until the light under the number 1 key is lite
Oct 16, 2014 | Office Equipment & Supplies
After typing first line, hit the return key. The carriage would not return to the far left margin...it only moved 12 or so spaces to the left.
The carrier slides on a silver shaft that is about 1/2" thick spray some WD40 on the shaft, if that doesn't do it you have to get some on the carrier motor bearings located under the case in the R. rear corner.
DickyO
Feb 22, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
Tab and return
reset the left margin at 69, or return and then press tab to start a new line
Jan 30, 2014 | Nakajima AE-740 Typewriter
How do I get the automatic return off?
Try adjusting your right hand margin to be set as far across as possible and take the typewriter off proportional spacing and set it at 10,12 or a set spacing,this should stop it from doing this if not let me know
Nov 16, 2011 | Lexmark Wheelwriter 1500 Typewriter
What does RELOC key6 mean on Brotehr GX-6750? Not BOLD and not Backspace1/2. Just plain RELOC?
Relocate, on any typewriter, generally is used to take you back to where you left off typing. Example, you type a line and see an error at the beginning. You back space to correct it, hit relocate and it will return to where you stopped typing.
Did this help?
Mar 26, 2011 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter doesn't type until I hit return button.
On the R. side of the keyboard is a key that says print mode press this key and the dl print on the displaywill go out.
DickyO
Mar 17, 2009 | IBM Wheelwriter 30 Typewriter
E MACHINE T1115. I CAN'T INSTALL AN ALL-IN-ONE EPSON STYLUS COLOR PRINTER. THE INSTALL NEW HARDWARE WIZZARD SAYS THE PRINT SPOOLER IS NOT WORKING, BUT THERE ARE NO DETECTIBALE PROBLEMS, WHEN I CHECK...
Mattazon
I tried your recommendation:
Go to-> Run and type cmd
that should be, (type "cmd") (do I actually put in "type cmd or only cmd?)
Then hit return (when I hit return, a black box came-up-C:\\documents and settings\connie hall-the curser was blinking at the end of this, instead of on the next line) Was it fully loaded?
Then you instructed me to type: scconfigspooler= RPCSS then hit return to reboot the computer. I did this but the computer still didn't load the hardware. I just wanted to make sure i typed the right command. please respond.
Apr 01, 2008 | Office Equipment & Supplies
Lexmark Wheelwriter 3500 Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
