Question about Panasonic Digital Camera Battery Charger with Car Adapter (88516506124) for Lumix DMCFS15 DMCFS15A DMCFS15K
How to load my pictures from my Lumix dmc-fs15 to my Dell computer
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on Apr 07, 2011
SOURCE:
How to slove system error(zoom) of my panasonic lumix dmc-fs15
You can't. it is cause by something blocking the gears or the lens being knocked to the side. Here is the online service form
http://www2.panasonic.com/webapp/wcs/stores/servlet/RequestCenter?storeId=15001&catalogId=11017
Jul 01, 2012 | Panasonic Lumix DMC-FS15 Digital Camera
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
System Error (Focus) ...Lumix DMC-FS15 works, pauses, then results in a white error screen with the following error message:
My camera started bringing up "system error (zoom)" and it was completely inoperable. I would turn it off, but the lens wouldn't retract unless I applied slight pressure to it. I was able to FIX this problem by applying some lubricant oil to a Q-tip and swiping it around the telescoping parts of the lens, being very careful to stay away from the actual lens. I turned the camera on and off a few times so the oil could work its way into the parts, and it fixed the problem. I don't know if it will be a long term solution, but I can at least download my pictures to my computer now!
Oct 08, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
I have a Panasonic Lumix DMC-FS15 when I switch on it says "built in memory card full" even though I have a 4GB memory card in the camera which is not full. The camera doesn't seem to detect...
Hi, Move the internal pictures to your card and then switch it to record to the card...
Here is a tip that may help you with your problem.... I found out that with my cameraI needed to transfer the pictures within the camera to the card and them fromthe card to the computer...
The process for your camera may not be exactly the same, but should be similar.
How toTransfer Internal Camera Memory Pictures heatman101
Aug 26, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
My Panasonic Lumix DMC FS 12 will not take any more pictures it says the inbuilt memory is full. How do I clear the memory?
With no card in the camera, go into the menu and find "format" and follow the on-screen instructions. This will erase all the pictures. You should use a memory card from now on and never go back to the internal memory.
Dec 02, 2010 | Panasonic Lumix DMC-FS15 Digital Camera
My LED screen for my Panasonic Lumix DMC-FS15 has broken, I have seen replacement screens on ebay from Hong Kong. How do I take the camera apart to replace the screen???
the best answer.. very carefully...
becarefull with replacing your screen, if you don't have the right precision tools and other equipment you might further damage your camera
Free quote for this repair at:http://www.teleplancamerarepair.com/manufacturer/repair-camera-model-problems.asp?mo=680
May 29, 2010 | Panasonic Lumix DMC-FS15 Digital Camera
I have lost my manual for my new camera Panasonic lumix DMC-FS15 were can i get another one
You can download the complete user manual by clicking this link
  • You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Feb 25, 2010 | Panasonic Lumix DMC-FS15 Digital Camera
How can I take high resolution photos on my Panasonic Lumix DMC FS15. I sent some photos to Costco to have them made into posters and was told that I needed a higher resolution photo to make a good clear...
All cameras have multiple settings for picture quality. For example if you email a lot of pictures select a lower resolution. If you have "poster" size prints made select the highest resolution you camera will do.
Go into your cameras set up and select the highest resolution you have. should be about 12MP.
You have a high quality print with that.
Dec 22, 2009 | Panasonic Lumix DMC-FS15 Digital Camera
Panasonic Digital Camera Battery Charger with Car Adapter (88516506124) for  Lumix DMCFS15  DMCFS15A  DMCFS15K Logo
Top Panasonic Cameras Experts
rajiv6089
Level 1 Expert
AJMAL KHAN
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
