Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Color convergence s fine but entire picture needs to be moved to the right
Cant figure out how to move picture to the right...about 12" off from center...how do I do this? help!
    Habit-Forming:
  • 55 Answers
Im no pro, but sounds like your mirror is misplaced or your unit is tweeked inside. I had my tv open with convergence fixed and now I am trying to match up the colors and focus to make the picture normal. Anyone have suggestions I would appreciate it also. Good luck!
Posted on Jun 22, 2008
I cant line the red and green crosses up left and right but i can move them up and down. I have two pics in diferent colors
The tv have a convergence problems,it is dead.Tv have colors lines like R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?Yes,than the tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
May 09, 2011 | Philips Magnavox 51MP392H Rear Projection...
Started with a very distorted and jumpy picture. after 20 mins adjust to a constant but suttle rippling action top quarter of the screen. now the entire unit is dead will not power on.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Feb 16, 2010 | Toshiba 50HDX82 50" Rear Projection...
Cant figure out how to access convergence
Your TV most likely has failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Apr 19, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Philips Magnavox 55P8288 Entire picture has green
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 55P8288A Green tinge over entire picture
  • Screen looks 3D
Apr 09, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Samsung HC-P4752W power and/or convergence problems
Sounds like you soldered two of the convergence pins together by accident. If its shorted the TV will shut down.
Mar 29, 2009 | Samsung HC-P4752W 47" Rear Projection...
51MP392H/17 Blue convergence wont move not IC chip
You could have some opened resistors low ohms that are bad go back and ck them around convergence ics.
Nov 20, 2008 | Akai PT4298HD Rear Projection Television
Picture looks 3D
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
Sep 06, 2007 | Hitachi 50GX30B 50". Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
