Question about Ryobi Garden
The owners manual for my Ryobi 210 describes carburetor adjustment but the photos do not show which screw is the idle mixture adjuster.
    Scholar:
  • 71 Answers
The Low speed adjustment screw is the one marked as "L" and would be adjusted during:
1. Idle - to insure running smoothly, and
2. Acceleration - to transition from Idle to High Speed.
The High speed adjustment screw is the one marked as "H" and would be adjusted during:
1. High speed or Wide Open Throttle. Turn about 1/8 either way to gain top RPM's and then back off slightly.
The final screw is an Idle Set screw. This screw sets the actual speed of the Idle and is the screw attached to the end of the throttle cable as it terminates at the carburetor. Turning it:
1. Clockwise - increases RPM's (speeds up motor)
2. Counter Clockwise - reduces RPM's (slows down the motor)
Posted on Sep 28, 2010
How to adjust the carburetor on a 1992 Kawasaki 100
Hi, Brandon for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.kawasaki-techinfo.net/pdf/99920-1901-02_EN_2_05.pdf
Idle mixture adjustment air or fuel screw adjustment
How To Carburetor Idle Pilot Screw Adjustment Honda XR70
Kawasaki kx 125 250 Service manual Download service repair owner...
Aug 01, 2016 | kawasaki Motorcycles
Ryobi s430 will idle but will stall out when throttle opens. This carburetor has one idle adjustment screw and one fuel mixture screw.
Those carbs are a pain. Try arousing the idle screw, turun it to the right, then try to see if it will idle. You will have to tinker with the adjustment screw and the idle screw. Eventually you're gonna need a new carburetor. You can rebuild it, BUT , chances are those cheap carburetors never are the same.
Sep 13, 2015 | Ryobi Garden
ADJUSTING CARB ON A YZ 450 F
Hi, Anonymous the carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt it faces out towards the air filter end of the carb . The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle adjustment bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle adjustment bolt accordingly for 950-1050 rpm if necessary, adjust the air fuel mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your air fuel mixture bolt can acquire without going past 3 full turns from bottom then readjusting the idle adjustment bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Yamaha YZ450F story about fuel screw
How To 4 Stroke MX Fuel Screw Adjustment YZF CRF KXF RMZ FCR Part 1 of 2
Yamaha YZ450F Owner Service Manual
OEM parts for Yamaha
Yamaha YZ450F Owner Manual
Apr 04, 2014 | 2003 Yamaha YZ 450 F
Chokes and Dies when cutting
Adjust the choke or carburetor. In case your chainsaw stalls when the engine is idling, ensure that the choke is set properly. To do so, first try releasing it to adjust it, and then move the plate and tighten all screws once again. To loosen any grit, spray carburetor cleaner spray on the choke's shaft. The carburetor may also need to be adjusted; consult your owner's manual which will guide you on resetting the idle mix screw.
Mar 13, 2014 | Ryobi 940968018 C4620 Label
2003 Honda CRF 150 F carburetor adjustment@
Hi, Anonymous it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
1. The mixture screw may be sealed at the factory with a Welch Plug please review the following video for removal.
https://www.youtube.com/watch?v=wAXcksgvDkM
2. The mixture screw manages a range of 3 complete 360-degree counterclockwise turns from the bottom/closed position.
3. The mixture screw should have a spring and o-ring for tension and sealing integrity.
4. Turn the mixture screw clockwise until it gently bottoms out, this makes the fuel charge very lean and the engine should not idle if it does then the pilot/idle jet is too big and needs to be replaced with the next size smaller.
5. Turn the mixture screw 1 and 1/2 turns counterclockwise to establish a baseline for starting the engine.
6. To fine-tune the idle circuit, adjust the mixture screw 1/4 turn in or out to achieve maximum idle RPM, wait 15 seconds between each adjustment for the idle to settle.
7. Never go past 3 full turns out this will make the fuel charge rich, foul plugs, and produce black smoke out of the exhaust, if the engine RPM keeps increasing past 3 turns the pilot/idle jet is too small and needs to be replaced with the next size larger.
8. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
9. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to tune CRF150F dirt bike other basics
CRF150F service manual repair 2003 2013 CRF150 Download Manuals Technical $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda 2004 CRF150F Owner Manual
Sep 11, 2012 | 2003 Honda CRF 150 F
How do I adjust the carburetor mixture screws on a 2001 yamaha ttr 125L
Hi, Anonymous the carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt it faces out towards the air filter end of the carb. The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle adjustment bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle adjustment bolt accordingly for 950-1050 rpm if necessary, adjust the air fuel mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your air fuel mixture bolt can acquire without going past 3 full turns from bottom then readjusting the idle adjustment bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have wonderful a day.
Stock TTR125 Carb Screw Settings
Ttr 125 Carb Idol settings
YAMAHA TT R125 Owner Service Manual
YAMAHA TT R110E Owner Manual
Apr 30, 2012 | 2002 Yamaha TT-R 125 L
How do you adjust the high speed mixture screw? I have a Ryobi RLH1100a MK III 31cc line trimmer, and after changing the fuel lines, it will start but not idle more than about 3 - 5 seconds before it...
Hi montex124, I will try to help. In the past few years carb makers have been making changes. Some carbs have no adjustment at all, the ports are all fixed inside the carb. Other carbs have only the idle speed mixture screw that can be adjusted, like yours seems to have. Is this screw you mention at the top and completely outside of the carb to adjust the throttle? If it is it's probably the idle speed screw which can be adjusted to any idle speed you want and has nothing to do with the air fuel mixture but If it is right next to the idle mixture screw, it might be the high speed mixture screw but is capped so it can't be adjusted. The low and high speed mixture screws should be marked next to each screw H and L.
The 1 1/2 turns suggested is sometimes just right but other times has to be adjusted, so you can try adjusting it to get your idle but maybe adjust the idle speed screw first to get a higher RPM so it doesn't stall on you. Like I said earlier it just adjusts the throttle, and is like when you are using it, and giving it gas as they say. I hope this helps just a bit. Regards and good luck. Get back to me if you need more help or just let me know how you did. Denis.
Feb 28, 2011 | Ryobi Garden
1990 Yamaha PW 80 air/fuel adjustment
Hi, Stevewright3 it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
7. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
8. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
PW80 oil gas ratio and stock screw settings
YAMAHA PW80 Owner Manual Adjusting The Carburetor Adjusting The Engine...
YAMAHA PW80 Owner Service Manual
Aug 15, 2010 | 2004 Yamaha PW 80
Wont idle
Not knowing if you know anything about idle speed settings, idle mixture, etc., first check to see if all carburetor components are fully in place and are in good shape. A vacuum leak will cause the symptom you are describing. After doing that, adjust the idle stop screw. If it just won't idle even after doing that, take out the idle mixture screw, blow out the screw hole with compressed air, and gently screw in this screw all the way in. (DO NOT FORCE it.) Then open it 2.5 turns. Adjust this screw for a good strong idle while adjusting the idle SPEED with the idle stop screw. Get assistance if you don't know how to do this stuff. Good luck.
Jan 04, 2010 | RTO 110cc Basic Manual ATV # ATD-125C
I have a 27499-85 carburetor on a 1979 harley shovel head and am looking for the idle mixture setting-i haven't taken the carburetor off the bike yet, however i removed the air filter and don't see any...
This is not the original carburetor that came on the bike. The orignial was a Kehien "butterfly" carburetor. This carburetor is a later "CV" version with the large square looking top on it.
I'll tell you how to access the idle mixture screw on each model. The "butterfly" carb had it's idle mixture screw in a "tower" on top of the carb just forward of the carburetor mounting flange. The square topped "CV" carb has the idle mixture screw underneath the carb at rear of the float bowl.
They both came from the factory with an "anti-tamper" plug of about 3/16 inch diameter (5mm) pressed in over the adjuster screw so that the owner could not mess with the idle mixture.
To get access to the idle mixture adjustment screw, you must drill a small hole in the "anti-tamper" plug. Be very careful not to drill too deeply or you will damage the brass screw underneath the plug. Drill just enough to go through the plug with a small drill bit. Screw a sheet metal screw or start a tap in the hole. If you use the sheet metal screw, use a pair of pliers or something to pull the plug out. If you're using a tap, once you get the hole tapped screw a screw into the hole and use the pliers to pull the plug out.
If your bike will idle at all, start the bike up and allow the engine to warm up. If it won't idle, screw the idle mixture in until it just barely "bottoms" in the hole. Back it out 1 1/2 turns on the "butterfly" carb and about 3 turns on the "CV" carb and start the engine. Adjust the screw to obtain the highest smoothest idle. Then use the throttle stop screw to set the idle speed of the engine. Once you're finished, put a small dab of RTV sealant in the hole over the screw. If you don't do this, water will seep down by the fine threads permanently seizing the screw making it impossible to adjust the idle mixture in the future.
Oct 24, 2009 | 2006 Harley Davidson FXDI35 35th...
Garden Logo
812 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
