Question about Curtis Televison & Video
No television channel mode , when i go to source and go to TV it reverts back to DVD. I need to get to set-up to program channels and it will not allow me. If I messed up the initial channel scan how do I begin again????
Ok how long
Posted on Jan 27, 2014
  • 476 Answers
Hello, Try a soft reset, unplug the TV from the AC outlet then reconnect, then power the TV on. You should get some kind of a start up menu. If you don't then make sure you're DVD is operating normally there might be something wrong with the disc player and that is why it is reverting to disc pick up or disc load.
Posted on Sep 28, 2010
How do I get channels on my Emerson tv with dvd? I have tried everything I could think of and I only get channel 23 and that is kinda grainy looking.
I don't understand the question. Why do you need channel settings for the DVD? Are you asking what channel to play the DVD on? It won't be a TV channel, it will be a separate video input source setting, usually found on the remote. The TV may show Video 1 or HDMI for the source in order to watch an external source like DVD.
Sep 27, 2014 | Emerson Televison & Video
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
Olevia 232 s12 Accidentally hit factory reset. now no channels in list. how do I get my channels back?
You'll need to reprogram the channels.
Typically this is found under the settings in some sort of auto program section of the menu.
On most newer televisions, the setting is found under a 'Channel' section.
Just select auto program and your source, whether it be an antenna or a cable source.
When the auto program is completed, you'll have your channels back.
Mar 05, 2011 | Olevia Televison & Video
I need code to activate my tv and channels
You probably need to SCAN the channels.
Connect the signal source to the tv. Either cable or Antenna.
Enter the menu mode on the tv. You can do through the remote.
Scroll down to the signal source. Select the signal source you have connected to the back of set.
Scroll to SCAN in the menu.
SCAN in the channels.
Exit menu mode.
You can now watch available channels.
Feb 09, 2011 | Televison & Video
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
Can only receive cable channels 2 through 13;
Turn the unit off, push the setup button 3 times. Press the seek left/right to switch between cable / antenna tuner modes. When cable is selected, press the channel up/down to switch between cable modes. When the unit turns back on, it will rescan for channels.
Aug 04, 2009 | Audiovox VE1020 10.2 in. TV/DVD Combo
17 in. trutech tv unable to get channels except 2-13
For channel setup you will need to;
1) Connect the signal source to the back of the set.(Antenna or Cable)
2) Go into the TV Menu and select the same signal source you connected to the back.(Antenna or Cable)
3) Go to the auto program/scan menu and run it. This may take a few minutes.
Now the channels may be watched.
Mar 16, 2009 | TruTech PVS31170S1W 17 in. LCD Television
I cannot get my DVR4300 to go in to TV channel change mode while recording a program
Why not simply record a channel tuned into the vcr and use your tv remote to watch a channel tuned into your tv? that is how it is normaly done... don't forget a vcr/pvr/dvd recorder has it's own channels just like a tv does... just no screen of it's own the tv has of course it's own channels and in fact does not even need to be switched on in order for your recorder to record a program neither does the recorder need to be on to use your tv
Oct 14, 2008 | GoVideo DVR4300 DVD Player/VCR
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Receiving tv programs
In the menu theres a channel set up mode. You want to switch from antenna to cable mode, then do an auto search. Then all your cable channels will come in. Your going to need the original remote to go into the correct menu. good Luck
Aug 25, 2006 | Audiovox FPE1078 7.8 in. TV/DVD Combo
Televison & Video Logo
80 people viewed this question
Top Curtis Televison & Video Experts
Martin Murray
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
