Question about U-Line 15R Compact Refrigerator
I accidently punctured the freezer line at the top of the fridge that holds the ice tray, causing the freon to spray out. can this piece be replaced or do I have to buy a new fridge.
    President:
  • 1,430 Answers
It can be fixed but depending on the age,condition, and value of the fridge it probally is not worth repairing. I would say a minimum of $300-$400 US to repair without seeing it.
Posted on Sep 28, 2010
Mcbr360 won't get cold at all hear as it come on and then click off I was busting up the ice in the freezer part and I hit something for liquid to spray out of somewhere needhelp ihave a small baby
oh oh seems like you punctured the freon line and now ur compressor will be out of freon and you will need to also replace the part you punctured, the line that is?
that liquid is what keeps ur frige cold!
Dec 18, 2016 | Refrigerators
My Kenmore side by side fridge isn't cooling hardly. Feeling the suction and discharge lines I think it's low on freon. How do I charge it?
Well I have to go, so I can't wait for your reply for more info. Basicallty what happened to me was the freezer became very good at freezing. The problem with modern freezer/fridges is that there is only one cooling system, the freezer. The freezer chills the other side to chill the refrigerator. Something was blocking that vent into the fridge side. Turns out it was ice blocking the vent into the refer side. It happens when it is humid and the kids to "shopping" in the fridge and leave the door opened for extended periods of time.
If you are blocked by stuff in your fridge, move it away from the vent. If nothing there, you'll need to get ready for a bit of time. Side-by-side freezer/fridges, typically the freezer is on the left. So, open the fridge, somewhere near the back about 2/3s of the way down, just above the vegetable bin, on the left side. Remove the cover, if something is stuck in there, gently try to remove it. If it is ice, like I had, you should remove your vegetable bin and meat bin and unplug the unit (to prevent shock as water will be everywhere. Be sure that your overflow tray (under the unit) is empty. Next is to make quite a bit of boiling water (I ended up using just over a gallon). If you are at the point where you can't get the cover off, you'll have to use a baster to melt the ice that is holding your vent cover on (that is where I started). Then you can start working on the ice. You need to keep putting water in until you get hot water in the overflow tray. Replace your food and don't slam the fridge control all the way to the coldest setting, you could end up freezing your meat and vegetables.
The repairman came and told us, he could do this for us for $200 or we could do it ourselves. He would have done the exact same thing.
Feb 05, 2014 | Kenmore Refrigerators
Water flowing into refrigerator. Ice build up behind freezer back wall. Will clearing ice from drains suffice or do I need a new heater? Foam drains to fridge are open. There is a small hole under...
hello again,
part 2 of the answer,the metal pan is the drain in the center of it is where the drain is blocked,the foam vents are the vents where the air from the freezer flows into the fresh food compartment,GENTLYclear that small hole so as not to puncture the tubing in the coil above it,or you will loose all the refrigerant(freon) an dthe ref, will be dead
Gene
Aug 09, 2011 | Roper RT16DKXK Top Freezer Refrigerator
Where is the drain hole? The refrigerator is defrosting and the condensation is under the bottom drawers instead of the pan beneath the frig. I can't find the place where the water should be draining...
The drain is in the FREEZER. Frost and ice melts off the evaporator coil during the defrost cycle and collects in a tray directly under the coil. The tray is pitched to the drain tube that runs inside the fridge wall to a pan under the fridge - where the water is evaporated by the heat created by the compressor and the fan that cools the condenser coil.
To see these parts, unplug the fridge. You'll need to remove the inside rear wall of the freezer. That means the freezer needs to emptied, ice maker removed, etc. Chances are that the drain is clogged - most likely with ice. Manually defrost with a hair dryer and use a turkey baster filled with hot water to direct a stream into the drain tube. Resist using tools to chip ice - the components are made with soft metal and if punctured will allow freon gas to escape. You can suffer instant frostbite to exposed skin or blindness if it gets into your eyes. Once water is flowing, consider hanging a piece of copper or aluminum wire from the defrost heater down into the drain tube. Make sure the wire hangs down as far as the ice build up did (2 or 3 inches at most). This will help conduct the heat into the drain tube and prevent it from icing over in the future.
I hope this was helpful. If it was, please rate it "4 thumbs up". Thanks!
Aug 01, 2011 | Whirlpool Refrigerators
Top half of fridge not cold
If your refrigerator cooling doesn't seem to be working well, and you have no idea what to look for in troubleshooting your problem, there are some things you can do to try to figure out your problem without paying a serviceman to come into your home. Freezing
Most new refrigerators come with automatic defrosters. Although this is a standard feature the drain hole in the defrosting assembly can get clogged with debris, lime, or even ice. If this happens the defrost will not work and there will be a build-up of ice in your freezer that begins to block the freon from flowing properly and causing heat to react improperly and cause your refrigerator to stop cooling. Freon
Freon systems in a refrigerator are closed systems but on occasion you may need a recharge. Refrigerators use R-134a freon, just like in an automobile. The old R-12 freon is no longer available, so if you have an older model of refrigerator you will not be able to obtain the freon, and it will be recommended that you replace that refrigerator. Seals
The seals that are on the door of the refrigerator and freezer can dry rot with time. When you begin to see the seals cracking or warping, if your refrigerator opens more easily than before, or if you see the the door does not close fully without pushing on the door then the gaskets around the doors will need to be replaced. They are held in place by clips and the replacement is an easy fix. Holes in Lines
Let's face it, many people find ice in their freezer or the back of their refrigerator and will try some self-help without knowledge. They will grab a knife or fork and start chipping away at the ice. This is extremely dangerous. There is a great risk of puncturing a hole in the freon lines by stabbing at the ice. Since freon has the purpose of cooling most ice collects the thickest on the inside of the walls with the freon lines right behind the plastics. A better method of removing the ice is to empty your refrigerator, turn it off and leave the door open. If you want to speed up the process you can turn on a blow dryer and aim it at the edges of the ice. If you aim at the edges you will warm up the ice and create warm water which will flow down and help to separate the ice panel from the wall. Uneven Refrigerator
If a refrigerator is not even on the floor it may not close properly. Rock your refrigerator and see if it seems to topple from one foot to another. The feet on a refrigerator can be adjusted by screwing in or out and leveling each foot individually until they are all even. Non-Problem Warming
If your home is hot your refrigerator will work harder. If you put a lot of food in your refrigerator and freezer, your coolant will have to work harder, and it will seem to take longer to cool. It is just that there is a lot of food that is trying to freeze or maintain cool temperatures.
I hope this will help in solving the problem....
Nov 02, 2010 | Fisher and Paykel Active Smart E522B...
Chipping away ice in magic chef freezer section i punctured freon line in freezer panel can refridge still get cold
No, the fridge will not get cold any more. The coolant goes to the coils in the freezer. The fridge takes a small amount of cold air from the freezer to lower its temperature.
I am sorry to say that unless you can find a way to repair the puncture and refill the system with freon, you are going to have to buy another refrigerator.
Feb 05, 2010 | Magic Chef CTB1922 Top Freezer...
Need freon recharge. punctures freezer coil in
You punctured the aluminum evaporator . In the many years I've been in refrigeration , I have yet to find any way to patch a hole in the evaporator . I've used epoxy , solder , and all different advertised ways to try to patch aluminum . Nothing worked ( for long anyway ) . My suggestion would be to buy another refrig . You will be wasting time and money trying to " fix " this problem . To repair it yourself , you have to have a license to buy R12 , maybe you can buy R134A without a license , you have to look on the " modell , serial number tak to see which it uses and how much to use . Also , the system has to evacuated ( all air removed from the lines ) . Do you have a vacuum pump ? You have to buy a solder on connector ( or saddle valve which WILL leak eventually unless you get a solder on valve ) which will connect to the larger tubing on the compressor or use the access line already on the compressor but is pinched off . Do you have guages for the refrigerant type you need to use ? Once you have these things , reply back and myself or someone else will help you procede .
Aug 19, 2009 | Refrigerators
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice tray sometimes stuck when dumping off ice
Your icemaker tray has an update for the water flowing over the tray.  You will need to call a qualified LG technician to get it replaced.  Also, the tray is twisted because it binds itself against the hinge pin on the left side.  To stop this, spray some cooking spray oil in the left hinge pin and it should unbind itself and return to normal.
Mar 24, 2008 | LG LSC26905TT Side by Side Refrigerator
U-Line 15R Compact Refrigerator Logo
323 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
