Question about Gaggenau EB294/295 Electric Double Oven
The strip insulation attached to the oven door has come loose. I have reglued it, but it doesn't stay on. What need is to replace the insulation with new strips and the name of a new glue or cement which will take the
Our frigidaire range oven is not able to hold temp...if I set it to 350 it may go as high as 550...but it doesn't always rise that high but it never goes to the temp set or stay at it.
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Ovens
The front glass blew out of it! Completely shattered and no one had touched it. Now we need to clean it up. I suppose we need to take off the door and get a new one. OR do we get a new glass plate and...
Hi and welcome to FixYa I am Kelly.
Since you did not include a model number this solution will be from the hip as I can not refer to any manuals to assist you. Most ovens the oven door comes off by tilting the door out to the first stop and then lifting is vertical inline with the position of the hinge at the bottom of the door. Some of them may have retaining screws on the inside of the door to keep the door attached to the hinge area that must be removed FIRST. The hinge itself should stay attached to the oven.
I can probably provide you with a source (Maybe more than one) for the door glass if you respond with a model number,
When you attempt to take the door apart lay it down on 2 rugs so you do not scratch it. Use some blocks of wood UNDER the rugs to prop the door up so as not to damage the handle.
The door glass is replaced by removing the screws from the indide of the door. Sometimes you have to remove the trim pieces in addition to the multiple door panels. Everything is done from the inside of the door. You must take out the inner panel, Then the inner glass, then the spacer, the insulation if any and finally the outer door glass. Reassembly is in reverse order. Outer glass, spacer, insulation if any inner glass, the inner panel and re-install the trim if you had to remove it.
Thanks for choosing FixYa.
Kelly
Sep 11, 2010 | Ovens
Having trouble replacing an oven ignitor
All that means is to take the outside insulating coating off of about 1/2" of the wire... that is stripping the wire and making it bare... then you take the two wires that need to be connected and twist them together,,,, then twist the ceramic nut over the wires til it gets tight...this gives you a good connection... make sure that none of the bare wire is out past the back of the nut where it could hit metal and short out..
heatman101
Apr 27, 2010 | Ovens
How to replace outer galss door
After putting the insulation in the door you start by attaching the base on then sit the glass on the bottom. Next attach the top/handle. Then the side snap on so that no screws are exposed. That's how I do it.
Jan 19, 2010 | Ovens
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Oven door stays open
Hi , the oven dorr needs ajustment , lose some attachement bolts ,then close the clearance will shut , so open gently and tightened the bolts.
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
Kitchenaid oven door will not stay closed
I had the same problem on my parents Kitchenaid KEMS378GWH0 oven, the door would only close enough to keep the light on. They propped a chair against it to cook. My father replaced the hinges and it worked for about a week. He noticed that pulling outward on the door at the very bottom edge often allowed it to close enough to use.
After completely dismantling the oven to get access to the brackets that the hinges slide into, we found it was not broken. We decided to expand on the only near solution we had and find a way to make the bottom of the door 'push out'. Our solution was very simple. Remove the small metal plate that covers the door insulation. This revealed that the insulation is a braided hollow rope that is held in by small clips that push through holes in the front of the oven. We threaded some small metal rods about 3/8 inch in diameter into the hollow insulation pushed the clips back in to re-attach the insulation, replaced the metal cover plate.
It worked!
Nov 22, 2007 | KitchenAid KEBC208 Electric Double Oven
Neff u1721 fan door problem
yes it is a heat resistant adhesive and ive never had any success in regluing them
Nov 06, 2007 | Neff U1721 Double circotherm Electric Oven
Gaggenau EB294/295 Electric Double Oven Logo
91 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
