Question about JVC HR-VP693U VCR
We cannot set it up, menu won't come on as it keeps reverting back to channel 2 instead of 3.............there was a power failure, but usually that is easy to setup but not this time, we had not used the VCR for a couple of weeks as we were on holidays, I asked my daughter if she was playing around with the remote and maybe changed something, she can't remember, anyway, we can't get it to work, any solutions?
  • 579 Answers
SOURCE: VCR doesn't work
The DVD has to be off so that it allows the VCR signal to pass through. Also make sure the VCR's output is set to channel 3 (little tiny slide switch in the back by the VCR's antenna jacks).
Posted on Jan 04, 2008
SOURCE: Basic Set-up
Most VCRs have a simple slide switch, usually on the back of the unit. Just slide the switch towards "4"
Posted on Jan 12, 2008
SOURCE: RCA VR678HF display reads, "LOCK." Nothing will work!
Held down on-off button on remote control for 10 seconds.
Posted on Dec 05, 2008
watsuke
  • 48 Answers
SOURCE: vcr problem
Heres the instruction manual, not sure hoe to myself but if this doesnt help ill read it and try to figure it out too :D
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Feb 04, 2009
  • 6 Answers
SOURCE: The remote isn't working (and, yes, I tried new
I ran into a very similar problem with a TV that I had that did not have a TV/VCR button on it. You HAD to have a remote to change it and the remote for the TV had been LONG lost. The solution was to go to Target or Walmart, and pick up a cheap universal remote. Make sure that the universal remote has a TV/VCR button on it and when you get the right code plugged into the remote it will function just like the original remote.
Posted on Mar 27, 2010
Blue on the screen of the tv
Try to initialize it!
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight "MEMORY INTI", arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Jun 23, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
I pressed the menu button on my remote and went to channels then I went to antenna scan and lost all my channels how do I rectify this problem?
just go to menu and choose turbo/maunal search or go to channels and press right arrow key on your remote it will revert back to its previous settings
Dec 06, 2010 | Televison & Video
Change the aspect ratio
you can set the aspect on either remote. the best thing to do is set the proper aspect on the tv remote for regular (sd) channels, and then again for hd channels. the tv should remember these aspect settings and revert to them when you switch back and forth from sd to hd. if you have satelite, there is usually another aspect on there you can change depending on the program, but i usually recommend leaving it alone. if you are on an hd channel with side bars, switch to the sd version instead of changing aspect so you dont have to keep flipping it back and forth.
May 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
When we have a power bump the unit reverts back to factory settings, Can a ups be added to the control board to eliminate this problem?
Not sure why your unit would reset to factory settings, it's usually the thermostat settings that control the unit and resets when you have a power failure. Most thermostats have a battery in then to power the thermostat during a power failure. They usually only maintain the power from 15 to 30 minutes to maintain your settings, before defaulting back to factory settings. After every power failure you usually have to replace the batteries.
Feb 26, 2010 | Samsung AP500PF Air Conditioner
Rastor needs adjustment on 60v500a
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
Jan 08, 2009 | Hitachi 60V500 60" Rear Projection...
Picture has a shadow (double effect)
Oct 22, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Tv discoloration
Aug 29, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 Red Spot
Aug 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Red color problem
Select a non-used or blank Video input or tuner to get into I2C menu, also make sure the Power LED on the Front of the set is not blinking at all.
  1. Enter the I2C Service Menu, be sure the power is OFF.
  2. On the front control panel, press and hold the INPUT button.
  3. Then press the POWER button for two seconds.
    1. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
    2. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
    3. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
    4. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
    5. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
    6. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
    7. Turn the set off-on and Confirm the picture remains in a good condition.
Jul 14, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
WS-55515 Loss of sound and HD blue screen
First check set for problems by:This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Self-diagnosis error 2-3 indicating deflection failure. Check for shorted or leaky Q5A37 part # 260P818050 located on PCB-Main. If found defective replace only the transistor instead of the Main PCB.
Sep 09, 2007 | Mitsubishi WS-55515 55" Rear Projection...
JVC HR-VP693U VCR Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
