Question about Hunter Ceiling Fan Control Switch
Hunter remote control fan wired through a wall switch occasionally would stick on high speed. Turned the switch off then back on and the fn off,an & light defaulted to fan "off", light "on". Remote then worked all functions properly. Sunday, nothing working. Have power to switch.
  • reid_mcauley Sep 28, 2010
    If I take the receiver (small black box w/red & black wires?) out and wire direct, what run speed will the fan be on?
    Fan has a remote control which has switch for the light, and an off switch & 3 switches for the speeds. No manual switches for light or fan. The sensor is mounted inside the housing of the single light which is just below the fan.
    I am considering cutting the sensor out of the loop and hooking these two wires together. Worst case is tripping the breaker I think. If the fan and light come on, that will verify that the sensor is bad. Right?
  • Hunter Master
  • 17,129 Answers
For a possible solution to your remote please check and see if you can get your remote working with this link for tips;
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Posted on Sep 29, 2010
  • 2,299 Answers
There is a receiver in the junction box where the fan mounts to the ceiling. This receiver has a series of relays in it to turn the fan off and on and the light off and on from the remote. When you said that the fan would stick on high speed, that tells me that he receiver was starting to malfunction. What was happening the relay for the high speed was sticking. When you turn power off, it would release. So you need to either replace the receiver, or wire the fan directly to the wall switch. And just do away with the receiver.
Posted on Sep 28, 2010
  • Rodney Clark
    Rodney Clark Sep 28, 2010
    Does the fan not have a pull chain to select speed on this model? You should be able to adjust the speed from a second pull chain.
How to eliminate receiver/transmitter in hunter 28425
Open the box at the bottom of the ceiling fan, where the switch is. You should find the receiver inside there. You'll find one white wire connected to it, and two black wires also connected to it. Remove the white wire completely or cap it off with a wire nut. Connect the two black wires to each other with a wire nut. Reassemble the ceiling fan. If the problem was the receiver, then the problem is now gone because the receiver is gone.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
Hunter fan remote bypass
This fan uses a "ballast" to run the fan. The ballast (part #272) probably contains wiring for multiple speeds. Here is a manual that discusses the wiring- http://www.hunterfan.com/SupportDocuments/OwnersManuals/42700.pdf.
To use a wall mounted fan dimmer, you need to identify the high speed wires and connect them to the dimmer switch. This method will bypass the other speed windings and is not as power efficient.
Jan 31, 2014 | Hunter 21617 Palermo Brushed Nickel...
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
Remote control is not functioning properly. Will turn on, using "high speed" button, but then drops to "low speed' wil no rmain on 'High speed"
the receiver in the fan is going out, they do all the time with remote set ups, also remember that if the fan has been wired through a wall switch,, this will hinder the remote from working properly
Jul 08, 2011 | Hunter 22435 Sontera Antique Brass Ceiling...
MY HUNTER ORIGINAL RUNS THRU AN ORDINARY WALL SWITCH. IT HAS HI AND LO SPEEDS ON THE HOUSING, BUT EVEN LO SPEED IS A BIT TOO FAST AT TIMES... HOW CAN I CONTROL THE SPEED THRU FULL RANGE... A RHEOSTAT...
Jim,
You have a special fan there. Hunter Originals are my specialty.
There are two ways to accomplish a slower speed with this fan.
1. A wall variable speed control, solid state, rated for 3 or more amps, regular fan controls will not work as your fan draws 2.5amps on high, not even new ones that are labeled for the Original.
2. Retrofit the fan to make it a three speed. If you're good with wiring, it's really simple. What you need is, a standard 3 speed pull chain switch, not a double pole one like cheaper/new fans have that use capacitor speed control, we are using cap. speed control, but not the same way they do. So you want an "SP3T" switch. You also need an 9 10 or 11 or 12 MFD capacitor (depending on how fast you want your low to be 8 is 20rpm, 11 is 75 approximately). You will remove the switch cap to your fan, and you will find your switch has a black, blue and red wire connected to it. Remove all wires, attach the black to L on your new switch, attach blue to 1, then you need 2 extra pieces of wire. Stick one wire in 2 and the second wire in 3. Now, get your capacitor and hook one side of it to the red wire and position 2, then hook the other side to the wire you put in position three.
Remember to get the Single pole switch for non capacitor speed control fans, if you get the double pole, both winding sets in your fan will be activated, which will draw double current and burn your motor out.
2speedorignial.png?t=1296263478
Also, are you aware that your fan uses oil (like an engine) ? and is not permanently lubricated?
Jan 08, 2011 | Hunter Ceiling Fan Control Switch
Hunter 23852,L-black to red-hurricane speed,black to yellow-almost hurricane,black to gray-very slow,hardy moves air,installed westinghouse 6A125vac switch,same speeds,how can i get a comfortable medium...
Howdy,
Sounds like a good ol' American made Hunter Original to me. BEST and most powerful residential ceiling fan (high quality) ever made. The RPM spec is 200-160-50 for the respective speeds, moving 10,500 CFM on high speed. Most ceiling fans barely crack 5,000 CFM. they were built for Brute Force Air Movement and they really don't do well for small spaces. The best solution I have for you is if you have a Wall switch for this fan, to install a Hunter Original Wall control or remote control. http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1313&_nkw=hunter+original+control&_sacat=See-All-Categories
Both controls will lower the Medium speed to about 100-110 rpm, which should be much more comfortable for you.
Because the Hunter Original (I know your fan is an American made unit by your wire colors) draws more current than other fans, the Original controls are the only controls that are designed to work with your fan. Other controls do not have the current capacity for the Original motor.
Also, are you aware your fan uses oil?
Aug 22, 2010 | Hunter 23852 Classic Original Ceiling Fan
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
My Hunter fan will only switch from high to low speed and won't
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
Mar 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
Dryers Logo
95 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
