Question about Heartland Classic Series 421006WB01LP Dual Fuel Range
I need a manual for my Heartland 9000 model. I know need burner caps, knobs for the stove an oven (total 5) and new igniter for stove top
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
  • 530 Answers
SOURCE: Maytag MGR6775 Gas stove. One igniter not working.
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
Posted on Jan 04, 2009
onthejob5130
  • 640 Answers
SOURCE: Stove Top Ignition will not turn off
all ignitors lite thats the way the stove works thats a safty feature..but im thinking your question is they wont go off,,if thats the case replace spark module...if not im here onthejob
jumptrout51
  • 3361 Answers
SOURCE: electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
Posted on Mar 12, 2009
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
3 stove top burners will light with electric ignition and 4th ok with assistance
Sounds like the sparker is in trouble. Get the oven details and ask your appliance dealer or go online to an appliance spares site. Before you spend any money, have a second opinion from an experienced person. You may have to remove the oven top to expose the igniters. Find a handbook, this level of checks is usually in the owners manual.
Apr 17, 2015 | Hotpoint Kitchen Ranges
I'm looking a thermostat oven burner for my heartland gas range 9000 model or someone who can rebuild an existing part?
I think you will need to buy the oven burner assembly that includes the thermocouple (thermostat). Refer diagram on page 31 in the manual at this site.
http://www.heartlandapp.com/media/242493/classic_gas_installation_and__operating_instructions.pdf
The part number is available on page 38 and it also has the contact details for Heartland.
Sep 23, 2014 | Kitchen Ranges
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
We are cranking up this BRAND NEW Vulcan flat top. Weh have the convection oven below up and running, but we can't even see a pilot light for the flat top. Advice anyone? Culinary-yours Chef Geir
older ovens have pilots but the newer machines are electronic ignition,there are ignitors in the oven and electrodes or ignitors on the top burners,when you turn the knob for the burner you should hear a clicking sound and see a spark around the burner,that's what lites the burner,the gas comes in and the spark ignites it,i don't know much about your machine but it can't be any different from other stoves.if none are sparking there should be a spark module in there or they could have separate modules,if you send the full model number i can look it up for you
Oct 30, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
Feb 04, 2010 | Miele 36 in. KM3474 Gas Cooktop
Ran auto clean for oven and cleaned stove top, not auto lighting
One. DO not use self clean on ranges unless you want to replace parts.
Two. Replace the thermal overload fuse.
Three. The manual should be in the console head.
Feb 22, 2009 | Kenmore Kitchen Ranges
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Heartland Classic Series 421006WB01LP  Dual Fuel  Range Logo
188 people viewed this question
Top Heartland Kitchen Ranges Experts
Dan Webster
Dan Webster
Jim Goldsmith
Jim Goldsmith
Are you a Heartland Kitchen Range Expert? Answer questions, earn points and help others
