I purchased a Linksys WET11 used and cannot communicate with it to set it up. Any help?
We were able to determine the IP address of the WET11 by sniffing. Problem has been solved.
de WB4FSU
Posted on Oct 01, 2008
    Champion:
    Scholar:
  • 209 Answers
What is the IP address of your router? Have you tried to reach it from IE?
Posted on May 26, 2008
I am using 3g wireless router buyed from wifi digisol company. can anyone please help me to tell is this product is right for internet communication. for more details related to this product visit htt
Sir
Using 3g wireless Linksys Routers is best router you use for inter net connection,
For customers using the AT&T 3G MicroCell and a Linksys / Cisco router model WRT54G2 or equivalent, the following settings should be made to the router.
NOTE: Changing the broadband router / modem / gateway settings may cause other applications to stop working, and / or change the broadband router security settings for outbound data transmissions. Please see the router / modem / gateway instruction manual for more detailed information.
Procedure
1.Open Internet Explorer and navigate to the router setup page at http://192.168.1.1
2.Enter the User name and Password, click OK
3.Verify the following settings:
Automatic Configuration - DHCP
MTU: Auto
4.
Select the Security tab, verify IPSec Pass through is set to Enable
5.Click Save Settings
I Hope Your Router Linksys Routers Problem Is resolved By now:
In case you need online Linksys Routers help then follow us on for:
Linksys Router Support
Apr 02, 2014 | Linksys Computers & Internet
I'm looking for the defauld user name and password
For the WET11 you should be able to use a blank username, and the password for admin.
Mar 06, 2011 | Linksys 802.11b Wireless Ethernet Bridge:...
I want to add a laptop - wireless to my current system. I have a linksys G 3.4 GHz. I need help.
Do you know the current wireless card settings that are working on your current system.
All you need to do is to configure these SSID and encryption settings etc on the wireless card on this laptop so it will communicate with the router.
If you have enabled MAC address filtering on the Linksys then you need to add the MAC address of this laptop to the MAC address Filter table in the Linksys wireless settings.
Let me know if you need further help.
Nov 09, 2009 | Linksys Wireless-G Broadband Router
Using linksys wet11 to connect to internet through linksys wireless router, working before, suddenly, not working, trying to setup again using static IP, not working, using DHCP, not working, run...
it's because you need to change the ipaddress in you linksys
make sure the ipaddress from you modem it's not 192.168.1.1
if you have the same ipaddress on the modem try changin the ipaddress on the linksys to 192.168.1.1
Oct 15, 2009 | Linksys 802.11b Wireless Ethernet Bridge:...
Trying to use belkin router with linksys adapter cards..do i need new drivers
You need to configure the Belkin router with a SSID and WAP or WEP encryption, Then install the Linksys adapter driver in the computer and then configure the Linksys adapter with the Belkin router settings (ie. the SSID and encryption) before the Linksys can communicate eith the Belkin router.
Aug 02, 2009 | Linksys (WIFIDESKTOP) Wireless Adapter
Connecting new linksys n to our brother mfc685cw wireless printer. Printer will not read new linksys n router
For isolation purposes, you may want to test the printer through the Linksys router via Ethernet cable and see if you can print if it is wired to the router. From there, configure the wireless printer to match the settings on your Linksys router. Once done, try printing again wirelessly.
Tips:
1. Make sure that they are on the same LAN segment. By default the IP address of the Linksys router is 192.168.1.1. so you may want to configure your printer using 192.168.1.2 for them to communicate.
2. Make sure that the wireless settings on the Linksys router match the wireless settings on your wireless printer. Check the SSID/Wireless Network Name and Wireless Security. All wireless settings should be the same for them to communicate wirelessly.
Jul 12, 2009 | Linksys WRT160N Wireless Router
Driver for linksys wet11
I don't think Linksys WET11 has a driver. However you can configure it by connecting it physically to a router or straight to your computer (ensure the LAN LED is illuminated on the WET11). Beware though that since it doesn't give an IP address, you may not be able to configure it right away. If you connected it straight to your computer, you need to set a static IP on your pc (give it something like 192.168.1.10 so you will be on the same IP range as the WET11). Once done, try accessing http://192.168.1.225. Leave username blank, default password is admin.
Jun 28, 2009 | Linksys 802.11b Wireless Ethernet Bridge:...
Port problem for download site
Check your router setting in Port forwarding.
open the port that your software are using.
your network setting might be set to NAT
linksys support have user manual on how to set ort forwarding.
Mar 20, 2009 | Linksys Wireless-G Broadband Router
Unable to connect to the router
Ok make sure the following is done:
Use the Linksys CD to do the network set up.
Set up the SSID in router settings.
Set up the admin password on the router.
Set up WEP encryption and an associated password.
Make sure in network settings that Vista networks type is set to 'Private'
Oct 21, 2008 | Computers & Internet
Help with my wet11
Can you connect to the built-in Web server or configuration screen?
Aug 07, 2006 | Linksys Instant Wireless Wireless Ethernet...
Computers & Internet Logo
David Payne
David Payne
