Question about Kenmore 78733 Gas Kitchen Range
Kenmore gas range, burners are working fine. Stove is not working, front panel, clock/timer..panel is off...
  • Kenmore Master
  • 3,051 Answers
Hello there:
Please read the entire solution i have provided it doe4s cover things that you have said has already been checked but there is more to it
It won't bake or broil If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring. Note... If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these, call a qualified appliance repair technician. The clock stopped The non-electronic clocks on gas range/ovens often don't last long. That's a problem, because the clock is essential to the self-cleaning and timed-bake features. Clocks are rarely repairable--you usually just have to replace them. Electronic clocks have been more reliable. But, they're often integrated with several other features of the range/oven. So when the clock develops a defect, it often renders the entire oven and broiler inoperative. The electronic clock is usually integrated with a circuit board, and the touchpad that holds the buttons you press is often a separate component. If your electronic clock is defective, you may need to replace the touchpad, circuit board, or both. Although these may be expensive, they aren't usually very complicated to replace.
Posted on Sep 28, 2010
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
GE Stove tope range not working
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
Sep 04, 2008 | Kitchen Ranges
We were given an electric smooth top kenmore range. When it was initially plugged in, the digital panel came on. When the stove was pushed into place, the digital clock/timer went off and the oven won't...
The electronic timer/clock must be working and be in manual mode for the oven to work. Try turning the power off and on and see if it resets. If is doesn't you might need a new timer unit. If you don't need the timer and clock it can be easily by-passed at the rear by joining the active and load wires and the oven will work.
Feb 26, 2011 | Kenmore 9535 Electric Range
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Sears Kenmore Elite Oven 790.99123405 Caught Fire!!!
The PF indicates a power failure.
The range experienced a loss of electrical power.
This code is usually cleared by pressing the CLEAR/OFF button.
If you continue to get this code, you may need to unplug the range and check the wiring connections of the power cord on the back of the range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 12, 2009 | Kenmore 99123 Electric Kitchen Range
Kenmore oven stopped working and clock/timer is dead
Try and knock off the oven , leave it for about 10-20 minutes then turn it back on , if its still the same go to the manufacturer or where you bought it... Hope i helped
Dec 30, 2008 | Kitchen Ranges
Bake and Broiler do not work
it sounds like you have a bad eoc which is electronic oven control that is the only thing it could be if your top burners are open
Dec 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Control panel out
it very well could be have you pushed clock like your going to set it
Feb 15, 2008 | GE JGBP28 Gas Kitchen Range
Kenmore 78733 Gas Kitchen Range Logo
304 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
