F22 error code on washer its not even a week old
  • 6 more comments
  • Anonymous May 24, 2008
    door locked error F 28
  • jpnal Jul 23, 2008
    Washer a week old. Now won't start. F-22 Code. Tried unplugging and re-trying. Tried different cycles. Tried circuit breaker. Doesn't work.
  • janellerea Sep 01, 2008
    My washer is flashing F22 and the door is locked and not able to open it to get the washed clothes out. What does this mean?
  • HJean Oct 11, 2008
    was delivered 5 hours ago; ran the empty load with refresher solution fine; now very first load will not go; f22 is all we get. But we have MHwe 300 VW
  • Ticked Off2 Jan 24, 2009
    Mine is not even a month old. Only ran it about ten loads and F22 is on - clothes are inside - door is locked. No service man available today. Result - my clothes are sour - my laundry is still piled up - I'm out $2000 - no help.
  • panfyre Apr 01, 2009
    Same dog gone issue. Model GHW9150P. 1 month old.
  • Gary Davd
    Gary Davd May 11, 2010
    WHAT IS YOUR MODEL AND MAKE?
  • Gary Davd
    What are your makes and Model # ??
SOURCE: F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Posted on Sep 09, 2008
  • 98 Answers
SOURCE: whirlpool duet steam F22 error code
it needs a servicing as .the parts are getting blocked and not able to move frequently.
also check for the motor.
also try to clean it externally and see it should work.
and if not then calling a tech is advisable.
check out this link for more help
http://www.applianceaid.com/washers.html
thanks.
Posted on Oct 12, 2008
  • 85 Answers
SOURCE: whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Posted on Dec 14, 2008
jonniewalker
  • 1031 Answers
SOURCE: error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Posted on Mar 14, 2009
TheMobilian
  • 8220 Answers
SOURCE: error codes "f1" "f22" etc. and washer stops at different times
Replace water inlet valve or clean water inlet screens. Remove the water inlet hoses and take a look see. Just guessing.
Posted on Jun 14, 2009
Whirlpool Duet Washer F22 Error Code Follow-up
1) F22 mean DOOR LOCK ERROR , this problem can be a) switch for open or defective b) loose wires or broken wires, test by continuity VOM .
2) adjust the Door vs switch very well for propely closed, and test the closed switch.
3) see if the color are missing and put in the WRON terminal.
God bless you
Jun 28, 2012 | Washing Machines
I am getting an F22 error code on my washer. Can anyone tell me what this code means.
Look at the information below and it should clear up your mystery.
F22
DOOR LOCK ERROR
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes/Procedure ??  Door lock mechanism is broken or removed from door.
??  Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU)
Feb 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F22 code ?? duet locks but will not run
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
Thank you !!
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool WFW9200SQA12. F22 light
"F22" is a Door Lock error code. This is an indication of a door latch failure and/or interconnecting wiring problem. The first step in troubleshooting the problem, however, is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of your washing machine. Sometimes these error codes are erroneous and can be easily cleared by resetting the CCU. If the error code reappears following a CCU reset, then you have a genuine problem. In addition, if the door latch remains locked following this procedure, there is a manual release you can use to open the door. The following link explains:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If you still have the error code displayed, inspect the door latch mechanism for any broken, loose, or missing components. Next, opne the top panel of the washer by removing the three screws in the rear of the washer that hold the panel in place. With the screws removed, the panel will slide back, then off. Locate the door latch on the right hand side behind the front panel. Inspect the wiring harness from the door lacth the to CCU. The CCU is located directly behind the wash tub in the top rear of the washer. Make sure all the connectors are snug and not loose or broken. In the majority of cases, a persistant error is a failed door lacth. If all these preliminary checks are unsuccessful, replace the door latch. The next link explains how:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
NOTE: "Fdl" is the same as an "F22" error code. This error code appears on older models.
I hope you find this information helpful. If you have questions please let me know.
Apr 12, 2009 | Whirlpool Washing Machines
Error code f22 whirlpool duet wash cycle
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F22 code machine won't work! What now?
F-22 USUALLY MEANS LONG DRAIN,,IF IM NOT MISTAKEN,, REMOVE BOTTOM 3 SCREWS FROM PANEL ,U SHOULD SEE PUMP .,, REMOVE CLOCKWISE AND CLEA OUT PUMP,, JUST REMEMBER STILL HAS ABOUT 3 GALLONS OF WATER EVEN THOUGH LOOKS EMPTY
Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F22 Error Code
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite top load washer
error code with this? f11 or f22 are control board related commucation errors.
Jun 02, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
848 people viewed this question
Top Washing Machines Experts
