Question about HP Photosmart C5180 All-In-One InkJet Printer
Message telling me my carriage is jammed. I see nothing wrong when I open it. how do I unjam it?
    Scholar:
  • 107 Answers
Hello, you might want to pull carriage from the right to the left, check to see if there is some paper in the right hand area, clear it out, then try again.
Posted on Sep 28, 2010
  • djgillstudio
    djgillstudio Sep 28, 2010
    so when you pulled the carrige over from the right to the left, did you find any paper under the cover on the right side. you have to look from the left side of machine to the right side.
  • David_T1967 Dec 24, 2010
    You are awesome! I looked all over the HP site and at videos and nothing. I thought I had looked everywhere in the printer, but sure enough... If you move the carrige over to the left, then look back behind where it was on the right side, I found a wad of paper crumpled up there. It's where the sponge and brush is. Removed the paper and Tada!!! Printer is back in business... Thanks!!!!!
My hp printer 5525 shows carriage jam how can i fix this?
If you lift the lid to get access to the cartridges, there should be a diagram showing you how to unjam the carriage. I have a 564, & it has that feature.
Aug 05, 2016 | HP Photosmart 5520 Multifunction Inkjet...
How do i clear a carriage jame an ,sg find nothing wrong
Click the link below to go to the hp printer support page for your printer paper jam. Pay special attention to the rear door , as many people miss that detail when clearing paper jams.Also , you can click on the troubleshooting link at the top of that page, followed by "solve a problem " in the drop down box to get answers for other problems,
Clear carriage jam and press OK to continue Error Message Appears for HP...
Feb 14, 2015 | HP OfficeJet 7310 All-In-One InkJet...
I get a message carriage jam and told to clear jam. However there is no paper jam. It tells me door open and it is not open. It seem the door does not go all the way up. I keep getting the message that...
It seems you mistook Carriage Jam as Paper Jam, but they are different issues. Carriage jam means the carriage that carries the cartridges is jammed which needs to be moved or be cleared manually after opening the door.
Please follow the instructions mentioned here (Click Here) [source HP Support].
Good Luck.
Let me know if you need further help.
Thanks for using FixYa.
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Jammed Cartridge
You need to clean the encoder strip, the clear strip behind the carriage. You can wipe it carefully with a damp Qtip because with too much ink on it the carriage thinks it's not moving.
Oct 29, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Printer says carriage jam, but I cannot see what the problem is.
I had a "carriage jam" error message.
My son gently wiped down the metalic strip that tells the carriage where it is. It worked for a couple of days and then the "carriage jam" message came back.
I took my 7210 apart, took the drive belt off/put it back on (not easy), and found nothing wrong with it. So, I put it back together. I noticed that if I pushed the print carriage all the way to the left, closed the lid, and pressed "OK", the print carriage would move a couple of inches to the right. It did this repeatedly. I figured the motor was working, but there was too much friction on the carriage. I put some 3-in-one oil on my finger and put a thin coat on the front, top, and back of the rod that the print carriage rides on. I then ran the carriage back and forth about 20 times. I closed the lid and it works fine.
I had the same problem with my DVD player. The head was hanging up on the two chrome plated rods that supported the head. I put some 3-in-one oil on the rods, ran the head back and forth, and it has worked ever since.
You might also check the belt to make sure that there is nothing that might cause it to hang-up.
Kevin
Nov 29, 2008 | HP Officejet 7210 All-In-One InkJet...
Carriage jam
My son wiped down the metalic strip that tells the carriage where it is. It worked for a couple of days and then the "carriage jam" message came back.
I took my 7210 apart, found nothing wrong with it and put it back together. I noticed that if I pushed the print carriage all the way to the left, closed the lid, and pressed "OK", the print carriage would move a couple of inches to the right. It did this repeatedly. I figured the motor was working, but there was too much friction on the carriage. I put some 3-in-one oil on my finger and put a thin coat on the front, top, and back of the rod that the print carriage rides on. I then ran the carriage back and forth about 20 times. I closed the lid and it works fine.
Kevin
Aug 13, 2008 | HP Officejet 7210 All-In-One InkJet...
Printer shows Carriage Jam, but I can't find it.
many reason coses carriage jam bout i think that the in coder belt faulty
Mar 23, 2008 | HP Photosmart C4150 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
