Question about Brother MFC-8220 Fax
I have a brother MFC 8220 on sleep mode. I do I get it off sleep mode?
  • 286 Answers
SOURCE: brother mfc 8220 gives error message check original
I assume you're getting this error when sending a fax?
Check original is not a paper jam error. This can happen in the winter due to bad noise on the phone lines. When you send a fax, you can get this result from the receiving machine due to noise. The receiving unit will transmit the error back to the sending unit.
The unit is basically asking you to check the quality of the original document. 90% of the time, there is no problem and the receiving unit actually got a good copy. However, sometimes due to noise on the line the receiving unit will get a poor copy of the fax. In this case the fax should be resent. Of course, since there is no way for you to determine how good the copy is at the receiving unit, in most instances you will have to resend the fax to make sure it goes though.
If, however, you are getting this message while copying (very unlikely) you can do a simple test of the document scanner that should reassure you that there is no serious fault, or pinpoint the actual fault.
Press the following key sequence within 2 seconds: MENU, *, 2, 8, 6, 4. If your unit has a FUNCTION key, use it in place of the MENU key. This should take you to maintenance mode. The display should say MAINTENANCE and all the lights should be flashing. If not, try unplugging the unit, press and hold either the MENU key or the FUNCTION key (depending on which your unit has) and plug the machine back in. This will also take you to maintenance mode.
Now, just press 5 5. This is the scanner area setting command, and if there is any problem with your scanner it will show up here as an error. If there is no fault with the scanner, the unit should return to maintenance mode in a moment. Once done, press 9 9 to exit maintemance mode.
If you are constantly having this error, get a phone repairman in to test your fax line.
Posted on Feb 06, 2009
  • 116 Answers
SOURCE: The paper keeps jamming in the drum of my Brother
replace solenoid
Posted on Aug 10, 2009
cene765
  • 787 Answers
SOURCE: How I clean Drum of Brother MFC 8220 Fax machine
If you mean drum reset
1. Open the front cover, and then press Clear/Back.
2. Press 1 to reset.
Posted on Oct 28, 2009
  • 159 Answers
SOURCE: I have a Brother MFC 8220 incoming fax problem
Here are a few possibilities:
Does it still say "FAX" on the display? If it says "TEL" it won't answer the phone. Changing it is just a matter of pressing the MODE button, which cycles through four settings. FAX is for dedicated fax lines. If you share the line with a phone, check your manual for info about the other two settings.
In your menu settings is a place where you can set the number of rings before answering. If it's set too high, the sending machine will give up while your machine is still waiting for that 9th ring. I know you wrote that nobody's messed with it, but it's worth checking.
A glitch in the memory may be disabling reception. We can reset it in the Maintenance Mode:
From the Ready state, press these buttons in rapid succession:
Menu
* [the star on the phone dial]
6
If you did all that in under 2 seconds, the display will show MAINTENANCE. If you were too slow, you'll just be in the menus somewhere. Press Stop and try it again. You have to ignore all the error beeps while you do this; it's designed to be nearly impossible to do accidentally.
Once you have MAINTENANCE on the display, simply touch 91 and wait. The machine will clear all its memory, except your stored phone numbers. In a few seconds it will return to MAINTENANCE. Press 99 to exit the mode. The machine will go through it's entire start-up, as if you'd just plugged it in.
You don't need to use another fax for initial testing. Call it from another phone - even a cellphone - and see if it answers. If it squeals horribly in your ear, you've probably fixed it. Now try faxing to it.
If that function 91 didn't help, try something harsher. Go through the same routine above to enter Maintenance Mode, then, instead of touching 91, touch 01. That will clear all memory to the sate where it was when you first unboxed it.
If nothing above helps, it almost certainly needs a new Main Board. Replacing that on a non-warranty machine may not be worth it, but use Brother's website to find your nearest servicer and find out.
Posted on Jan 27, 2010
  • 1218 Answers
SOURCE: Brothers fax MFC-8220
Brother printer error code 7a occurs when the main motor fails to synchronize properly with the reference clock.
http://www.fixya.com/support/t5660619-7a_error
Posted on Sep 22, 2010
I'd like to transform a Brother MFC 8220 from USA to AUS power
Probably cheaper to buy an auto transformer from 240 to 110 volts.
Mar 24, 2017 | Brother Mfc-8220 Laser Multi-Function...
Hi, my printer Brother MFC-9320CW enters in sleep mode every 30minutes. Any cloues how to clear the timing?
try fixing the SLEEP menu.
Follow the steps I found:
Enter Menu and navigate to General Setup. To enter press OK. Use up or down arrow buttons to go to Ecology and again press OK. Enter Sleep Time menu and enter 0 if you don't want your brother to enter sleep mode. Press OK and exit printers menu.
May 06, 2012 | Brother MFC9320CW All-In-One Printer
Brother multifunction laser printer, model #8220 : can you use color ink cartridges with this model or black /white only?
Welcome to FixYa!
The MFC 8220 is a Laser Printer. It uses Toner Cartridge. Product #TN540 or #TN570. It cannot use the regular ink cartridge.
See full details in this link: http://www.brother-usa.com/MFC/modeldetail.aspx?PRODUCTID=MFC8220&tab=supp
Thank you for using Fixya. Jas247
Apr 03, 2011 | Brother MFC 8220 All-In-One Laser Printer
HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
Brother FMC 8220 manual
You can download/read the manual here (click here). If I am right, you printer model is Brother MFC 8220 instead of Brother FMC 8220 :-).
If I am wrong and need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 03, 2010 | Brother MFC 8220 All-In-One Laser Printer
I need to replace the ADF Document Support piece on my Brother MFC-8220 fax machine. Do you know where I can purchase one?
I finally located a phone numbe for the Brother-USA Sales Dept. (888-615-9119). The part was $4 plus shipping and handling ($10 total). It took a bit of doing for them to identify the part and determine the part number. I had to fax them a machine parts diagram from the MFC-8220 manual. Go figure.
Oct 01, 2009 | Brother MFC-8220 Fax
Reinstalling driver for Brother MFC-8220
Hey,
The brother drivers and software require for the machine is available at
http://www.brother.com/E-ftp/info/index.html
Let me know if you need anything else.
Thanks,
Ekse
Aug 01, 2008 | Brother MFC-8220 Fax
Brother mfc-8220
Usually you can touch any key on the keypad to wake it up. You might want to look in the owners manual to see how to adjust the enery star or sleep settings.
Jun 30, 2008 | Brother IntelliFax-2820 Laser Fax
Brother MFC-8220 Fax Logo
324 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
