Question about Kenmore Elite HE4 Electric Dryer
Window dryer Elite model 110 95089401 front load. The concave plastic window is cracked and I need to remove and replace.
  • Kimshusband May 25, 2008
    Thanks, Mr. Bean. Perfect assistance.
  • 5,911 Answers
Okay...thank you for the feedback. This repair will be much easier if you remove the door from the dryer. Just loosen the screws on the hinge where it connects to the dryer door opening. That is...remove the door with the hinge still attached. CAUTION: Make sure you support the weight of the door as you loosen or tighten the door hinge. Lay the door face down on a soft surface like some towels. Locate the screws on the door interior. There are a series of them that go around the perimeter of the door. Removing these screws will enable you to disassemble the entire door. The interior door facing will come off, allowing access to all the remaining parts. Just make sure you remember how they come apart. If you get confused, you can go to searspartsdirect.com. Type in your model number and locate the "Door Parts" heading on the next page. There should be an illustration on how the door is assembled. I hope this helps you. If you need further assistance, please post back and let me know.
Posted on May 24, 2008
My gas dryer runs but with no heat
Most likely you need to replace the heating element that ignites the gas.just turn off the gas line unplug the dryer and remove the front cover then you will see on the bottom right there Is a heating element bolted to the gas valve with one single quarter inch bolt.You can either remove it and inspect it for little hairline cracks or check for continuity with a multimeter.If you see a crack or have no continuity replace the ignighet
Apr 15, 2014 | Kenmore HE5 Steam 7.5 cu. ft. Electric...
Kenmore elite he3 gas dryer, how to fix blower assembly?
take it it's a front load, well remove the top panel, this will allow you to get to the screws to remove front panel. remove bellows pad (rubber gasket around door) remove with a screw driver carefully there will be a metalic ring, remove it fold bellows pad back.Now you can remove front panel and access the blower motor
Sep 19, 2013 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Model 110..71082000 Gas Dryer wont stay on to dry clothes
If the dryer lights and then goes out, you will need to replace the flame sensor. Here is the part to order.
Nov 06, 2012 | Kenmore Elite 45986 Front Load Washer
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore electric dryer series 70, on the inside of my dryer there is a plastic white ring that is cracked and brittle, clothes get stuck on this ring and tear, can I replace this white ring?
Yes, you can replace that ring.
I believe you have a front loading machine, if so then you will need to remove the front of the machine to expose the ring, drum and belt.
Try this website and see if they can supply the part you need.
Good luck, I hope this helped
http://www.partsselect.com/
Oct 03, 2009 | Kenmore 73952 Gas Dryer
NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
I have the same dryer doing the same thing. Open the door and take the two screws out and lift the top. Remove the two screws that hold the front on. Remove the front. On mine both the plastic parts that stay on the front when it is removed are cracked and needing replaced. I found over 20 buttons that the dryer had pulled off clothes stuck in the front door. I'm sure if it will be cost effective to buy both these parts or not.
Jan 13, 2009 | GE DBXR453EV Dryer
Front door plastic face plate of washer HE3t
yes. there aretorque screws around the inside frame remoive them and the 2 pieces will seperate. you can replace it then. be carefull if you remove the screws from the hinge the whole door will fall off. only six or so screws need to be removed
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3 front loader door cracking and broken latch problem
there around 300.00 1 ideal to share buy service smart agreement from sears all parts &labor will be covered up to 500.00 i have warranty it payed off big time
Nov 02, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Kenmore Elite front load dryer
Probably a thermal fuse. You'll need a continuity meter to check it, though. Once you get one, unplug it. Remove the lower panel on the front. Beneath where the lint filter sits is your lint duct. Remove it (screws at top left and right and clip at botom center) Behind it is a white peice of plastic with 2 blue wires. Unplug them and check across the two prongs on the white thermal fuse to see if it is good. Replace if nessciary. If it is bad check your vent (dryer to wall and wall to outside) for restrictions or blockages.
Apr 21, 2008 | Kenmore 45081 Front Load Washer / Dryer
Kenmore Elite HE4 Electric Dryer Logo
100 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
