Question about Ovens
CONTROL PANEL HAS STOPPED WORKING, CAN YOU SUPPLY A REPLACEMENT?
  • wcworthley Sep 28, 2010
    Montgomery Ward Microwave, Model # KSA8273A, Serial # 112339
    Control panel needs to be replaced
  • 1,711 Answers
Here in Fixya we don't sell anything, but you can let us have your Brand name and model so we can give a sagestion link where you can get hat you want.
Posted on Sep 28, 2010
  • espressonist
    espressonist Sep 28, 2010
    Your model seems to be an old model and it does not shown in list however they have compatible one the link
    http://www.apwagner.com/index.php?main_p...
    you can also email them or call them to confirm your model and the parts are matching, they will be more than happy to help you.
    1-888-279-2463
Oven all of a sudden stopped working. The clock face on the upper right hand side of control panel is illuminated and I'm not sure what this is for. Is it related? Do I buy a new oven, or try to fix?
Microwave ovens are not to be messed with. Get an approved Sanyo technician to replace the control panel or ASDA; 29 pounds to replace it.
Oct 22, 2014 | Ovens
Frigidaire stove oven problem
Sounds like the control board needs to be tested for any communication errors and possibly replaced.
Aug 24, 2012 | Frigidaire Ovens
Kitchenaid superba double oven, stopped working everything dead, breakers not tripped. does not respond to any control.
Open the lower oven door and remove the 2 screws on the left and right trim pieces. Be careful not to drop the trim pieces and bend them. Locate and remove the screws on each side of the control panel and push up on the panel gently to get it off the hangers. Behind the control panel is an over heat fuse that has popped. It plugs into a harness on the back side of the panel. This trips/breaks it's connection from either the oven over heating the cleaning cycle or just from age.? Once fuse is replaced you're good to go. Hope this helps.
Aug 23, 2012 | Ovens
Hi Guys I have a Stoves 720EF Double Oven and Grill. Whilst halfway through cooking some sausages on the grill this evening, the grill suddenly stopped working (plus the LED for the grill knob showing...
If the element and the indicator light both stopped working this suggests a problem with the power supply for the grill control. Either the grill control has no power going to it or it is faulty and requires replacement. If you are not sure what you are doing you'd better get a tech. to look at it, it can be fairly complicated for the untrained person.
Feb 24, 2011 | Stoves 720EF Electric Double Oven
I have a new control panel that was just put in 2 weeks ago. I pressed the button start to long & the "Loc" came up on the display & it won't go off no matter what button I push. I've...
Did you replace the panel yourself? If it was a repairman it should be under warranty. Anyway I would think that after the supply has been turned off overnight the timer would reset itself. If that doesn't work and you don't want to keep mucking around with control panels and you can do without the electronic clock the control panel can be easily bypassed by a repairman. This will then enable manual oven operation.
Feb 16, 2011 | Ovens
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jun 20, 2009 | GE JKS05 Electric Single Oven
Oven control panel out
not likely a bloiwn fuse, you would have to gain acees to the control panel itself and check for incoming power supply, if your geting power to the clock the n youll need to replace clock. in the cabinet somewhere will be a wire diagram/trouble shooter. to aid you along
Apr 29, 2008 | Ovens
Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Digital screen goes off oven will not work stove top is working fine
The "digital screen" is connected to the electronic control board which controls the oven (the surface elements on the stove top will not be affected by this problem). The "flickering on and off" could be any connection that feeds the electrical supply of the control board. Like something in the wiring harness that feeds the relay board, or the wiring harness that goes from the relay board to the electronic control board. It could also be the relay board or the electronic control board themselves. To isolate the problem you would need to check electrical supply to each board at the time of the "problem" when the "digital screen goes completely off." This would tell you where you "have" the voltage and where the voltage supply is lost. If it is a loose or burned wiring harness replace the harness or individual wire causing the problem if it turns out that it is the relay control board or electronic control board replace them. The relay control boards are typically around $75.00 and the electronic control board $150.00 and up. Might be cheaper to purchase another used oven or bite the bullet and buy a new range.
Nov 29, 2007 | GE Profile JTP18 Electric Single Oven
Electrical Jenn Air Oven control panel ..
theres no fuse. the display needs to be replaced. this is a common problem on maytag and jenn-air ovens
Nov 26, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
78 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
