Question about Royal 160MX Shredder
The overload signal keeps appearing on the shredder. What does this mean and how can I fix it? Thank you.
    Genius:
  • 1,218 Answers
The oveload signal means too much paper was being shredded and the machine jammed. Put the machine in reverse and see if the paper will "back-out" of the cutting teeth...if there is still paper sticking in the throat try to assist by pulling it out as you put it in reverse.
Posted on Oct 07, 2010
Where is the reset button on Elna6004 6004, overload message keeps appearing
The message means that the motor is drawing too much current. Could be a mechanical bind or the motor itself is worn out.
Hope that helps.
Aug 19, 2016 | Sewing Machines
Keeps stopping with overload light on. How can this be fixed
The most likely cause is that the shredded paper, has tightly wrapped itself in the blades. One possible cause is by shredding labels (like Avery Labels) or any paper which has adhesive on it. (Causes it to attach the cut pieces to between the cutters.) It reaches a point where there is so much bound up on the blades that even a single sheet of paper will cause an overload. The fix is simple to describe, but difficult to accomplish. You must go in and manually remove all of the paper bound up in the blades. It's not easy, I found that using a needle nose pliers worked best. Lot of digging and tugging (paper will pack between the blades very tightly). Sometimes a small, slotted screwdriver will aid in being able to pry out bits and pieces (it's not going to come out in anything but small chunks; at best). Don't forget to unplug your shredder before you start; those blades are sharp. This happened several times with my last shredder *Royal), but not once with my current shredder (Fellows). I tend to believe that the better quality shredders are worth the extra money. But any shredder will become a problem if you shred labels (like Avery) or paper products that has adhesive on it. (Another common mistake is shredding junk mail that has any kind of adhesive associated with it. Best to open and check first.) One other thing, ALL shredders need to be oiled on a regular basis. They make special oil for this, you can usually find small bottles of it at Wally World or the like. Best practice is to squirt some shredder oil in a serpentine pattern. over a piece of paper to be shredded and run it through. Do this whenever you empty the shredder bin. (Important for the life of your shredder.)
Aug 29, 2014 | Royal 150MX Cross-Cut Shredder
Model SPL-TXC15A. Why doesn't it operate?
The shredder may have gone into thermal overload as a result of trying to shred something unsuitable, such as a credit card or as a result of prolonged use. Sometimes operation resumes after a "cooling off" period. At others, the thermal overload shutdown is permanent.
Jan 17, 2013 | Office Equipment & Supplies
This shredder was given to me couple years ago and this is the first time the overload light came on. Could you explain what it means? Thank you
Have you ever emptied the container that contains the shredded documents? If not, then do so.
Or, are you feeding too many pages in at one time, thus "over-loading" it?
When the rollers that pull the paper into the shredder-blades are detected as not spinning as fast as they should be spinning, you have a "jam".
Put the rollers into "reverse" and eject the unshredded pages.
Then put the rollers into "normal" mode, and feed 1/2 of the bundle of pages.
Feb 24, 2011 | Office Equipment & Supplies
Overload light keeps coming on but there is only 1 piece of paper at a time
Have you ever "oiled" the machine...get shredder oil and put some into the cutting blades and run the machine in reverse..then put some of the oil on some paper and run the paper thro" the machine.
Nov 18, 2010 | Royal VF1012mx Shredder
Royal CIA12 crosscut shredder overload light came on.
Unplug immediately and wait 20 mins to see if motor will "cool-down"...when plugged back in hopefully the Overload light will be OFF....unless you have it completely jammed up in which case try running it in reverse if the overload light is OFF.
If the overload light wont go out you may need pcb...contact Royal at 1-800-524-0799 for further parts assistance.
Nov 24, 2009 | Royal Office Equipment & Supplies
My QuikFinish ShredderShark Shredder Overloaded
I resolved the problem by opening it. They only problem with that is that I had to break the warranty seal. So I no longer have a warranty but it did fix my problem. So that would be up to the individual to choose what to do.
Jun 24, 2009 | Banner American Products QuikFinish ...
SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
Shredding paper partially
Your cutters have spread apart this could be caused by overloading machine to many times or something may have cracked internally that held them in place.
Jan 02, 2008 | Shredder Secure Shred Shredder
Royal 160MX Shredder Logo
142 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
