Question about SmartDisk (USBFP120P) 120 GB Hard Drive
No current driver for Smartdisk 120 GB HD, needed for Vista Ultimate 64bit
    Brigadier General:
  • 10,406 Answers
Any external drive uses a USB connection, and Windows Vista will recognize this "plug-and-play" device, using the built-in device-drivers.
What problems are you having?
Exactly what error-messages are you getting?
Posted on Sep 28, 2010
  • 3 more comments
  • rodjenkins Sep 28, 2010
    no error message, no registration on computer allowing access to hd
  • ikkenom Sep 28, 2010
    Try connecting a different USB device to that USB port, to prove that the USB port is working correctly.
    Try connecting the unit to a different computer, while listening to the noises from the disk-drive inside the case while making the connection. You should hear a few clicks, as the "table-of-contents" is read from the disk, soon after applying the power causes the disk to spin.
    If not, then you probably have a problem with the disk-drive inside the external case.
    If the unit is still under warranty, exercise the warranty to get a free replacement.
    tried all those, different USB ports different computers, different operating systems, XP Pro and Vista Ultimate, HD is cyclying up with no registrations, this SMARKDISK HD is **** and headed to the trash.
    Open the case, and disconnect and remove the disk-drive.
    You can buy a new disk-drive (with compatible power
    I'm not sure if my REPLY got posted -- you can disassemble the casing, remove the 'dead' disk-drive, swap-in a 'new' disk-drive, with similar 'power' and 'data' connections, and reassemble the casing, to produce a 'new' external disk-drive.
    Also, you can have fun disassembling the 'dead' disk-drive, to extract a 'refrigerator-magnet', and to learn a bit about the 'guts' inside a disk-drive.
Please help
I would assume that, as long as the hard drive is still good, and that the interface is sATA that any current enclosure would do - the main difference between enclosures is the read/write speeds that can be sustained. Here is a simple one: enclosure link.
Jul 18, 2013 | SmartDisk (FWFP120) 120 GB Hard Drive
Where to get audio and video drivers??
Usually Windows 7 will apply the drivers. You have looked here: http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-46258 If this is a OS upgrade, it's a common issue, if you open the Device Manager do you see Unknown Devices? What drivers do you need , 32 or 64bit? Often you can use the Vista drivers, modify the Vista driver and change compatibility to Windows 7.
Apr 19, 2013 | IBM ThinkPad T40 2373 Notebook
Need driver for SmartDisk FireLite 40 GB Hard Drive
I found drivers at this URL: http://www.xpdrivers.com/usb/smartdisk/_3_2585.cfm
You should go there and be able to find what you need for the 64-bit Vista OS.
Good luck,
-a.
May 26, 2012 | SmartDisk FireLite 40 GB Hard Drive
Trying to connect my old Smartdisk USBFLB120 to my Toshiba Laptop with Windows 7 64 bit - can't get drive to recognize as drive - Lapop sees device but says it is unavailable
Change you usb port or replace the smartdisk's usb cable, probably the current one if broken. Also restart the pc whilst the smartdisk is connected. It shd be recognised now.
Jun 06, 2011 | SmartDisk FireLite USBFLB120 120 GB USB...
SmartDisk FireLite XPress 120 GB USB External Hard
Hola!!!
I have this external drive and the truth is that it is very good. But I have a s e doubt that the digital display does not turn me, and I do not know if it is broken or is it because only you connect the USB cable and did not put the current transformer 5Volts. I need someone to help me and tell me what has to be repudiation. Thank you very much!
My Email: @ gmail.com rodolfo.gomez1990
Mar 24, 2010 | SmartDisk FireLite® XPress 120 GB USB 2.0...
Vista OS. USB detects device. Does not display
Vista and Win7 lite versions dont have all the drivers and functions of the full version, so some issue will always keep coming up....
if u can install XP then do this
if u know how to partition ur main internal HD then install XP and Vista in different partitions...
when windows starts..choose XP to load.
then try if ur Ext HD works in XP...
else let me know i will guid u the next steps...
Dec 21, 2009 | SmartDisk FireLite 40 GB Hard Drive
I just built a computer with 16Gb of DDR2 RAM. What OS should I put on this baby so that I can actually USE all 16GB of RAM? I was going to go with 2008 Server but someone told me Windows 7 would support...
Thanks for using Fixya.
Wow, 16gigs of RAM... thats alot!
Well, for you to be able to get full use of your 16gigs ram. You need to be using a 64BIT OS. Windows Vista and Windows 7 has 64bit versions. The main problem that you will encounter with using 64bit OS is driver compatibility with your devices. Hopefully all your components have 64bit drivers. I hope this helps.
Thanks and have a nice day.
- HotRatchet
Nov 04, 2009 | Cars & Trucks
Smartdisk Firelite 120 GB wont delete
Try to reformat the external hd thru the disk utility.
Sep 03, 2009 | SmartDisk FireLite USBFLB120 120 GB USB...
Board of step note nc 1510
THE CURRENT ISSUE OF LABTOP MAGAZINE HAD AN ARTICALE ON UPGRADING YOUR NOTEBOOK AND OPTION, YOU MANUFACTURE MAY HAVE THE INFORMATION ON MOTHERBOARD UPGRADES, HOW ABOUT BOIS UPGRADE INSTEAD, UNLESS YOU NEED MOR RAM CAPACITY, BUT THAT CAN BE DONE BY SOFTWARE UPGRADE SAY FROM WINDOWS 98 TO VISTA FROM 256 MB TO 1-4 GB RAM,
VEDIO MOST LIKELY SHARE VEDIO IF YOU GO TO 4 GB ,1 GB VEDOI THAT LEAVE 3 GB FOR SYSTEM OPERATION, SEE.
VISTA 64BIT LIMITED OPERATION SYSTEM SOFTWARE AND EVEN SOME GAMES AND OTHER SOFTWARE OFFICE PROGRAMS WILL NOT WORK PROPERLY WITH 64BIT SYSTEMS SO THAN YOU HAVE TO HAVE 32BIT ALSO OR STAY WITH 32BIT OPERATION SYSTEM VISTA PROFESSAL THE BEST, SPLIT THE DIVE IN HALF 1/2 32BIT AND 64BIT OPERATION SYSTEM, OR BUY A LABTOP THAT CAN UPGADE TO 2ND HD DRIVE HAVE SPLIT BOOT SYSTEM FOR YOUR COMPUTER IS ALSO OPTION AND THE BEST OPTION.
BUY NEW SYSTEM MINUIM EQUIPMENT, UPGRADE THE RAM YOURSELP, BUY USB HD 1-1.5 TERABYTE HARD DRIVE I SEEN 1.5 TB HD AT FRY ELECTRONIC FOR ABOUT 140.00 DOLLARS AND YOU CAN STORE ALOT OF MOVIES PHOTOS MP3 MP4 OR WHATEVER YOU NEED IT FOR, BUY USB FLASDRIVE 16GB FOR 34.00, FLASH DRIVE INCREASES PERFORMANCE OF THE COMPUTER SYSTEM. TRANFER RATE INCREASES FOR DATA AND ACCESS SPEEDS ALSO WILL INCREASE ALSO
BETTER PERFORM ALL AROUND FOR LITTLE MONEY SPENT.
IF YOUR MODEM OR IF PC CARD OR EXPESS CARD AND IT HAS A MEMORY CARD SHOT BUY THE 2-4 GB MEMORY CARD IT WILL HELP WITH DOWN LOAD OF PHOTOS DATA TRANSFER, SEARCH PAGES ON THE INTERNET,
OVER ALL PERFORMANCE FOR LESS THAN YOU THINK
CANDYMANGANDY
MORE THAN YOU WANTED RIGHT
Feb 02, 2009 | Everex StepNote NC1500 Notebook
Software compatibility for TV-USB U728
well here is what i was looking for online but couldn't find who make's that. if i was you i would go to the website of who make that tv-usb u728 and see if they have an update for the drivers. If not you can try changing the compatibility of the program it uses not the driver you can't change that go to the program folder that you use and right click it open properties this should open a window now click on the compatibility tab check the box next to run this program in .... make sure it sayes run it in windows xp service pack 2. then hit apply and give it a try. If this doesn't work and they have no new driver's for you i'm sorry but it will not work on vista 64.
Oct 27, 2008 | Microsoft Windows Vista Ultimate Edition
SmartDisk (USBFP120P) 120 GB Hard Drive Logo
61 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
