Question about Elan VIA!dj-S MP3 Player
The unit will not boot-up. Static message on screen reads: ViaDJ Starting ... I suspect, based upon research that the hard drive has failed. I can hear the hard drive spinning, but nothing happens. Also, the installer is out of biz and did not leave a boot disk which I've come to learn is an Elan policy for its distributors. In anticipation, thanks Jerry
  • Zebra Spots Oct 18, 2010
    What model of DJ do you have?
Ok, my Elan Via!dj unit was doing the exact same thing. This is how you fix it. Take an aluminum baseball bat and in an over-the-head, ax swinging, motion, strike the unit from the top 4 to 6 times. Dispose of unit in dumpster. Fixed. - John Wilcox of San Diego California
Posted on Dec 04, 2010
Which part is failed on my iMac with white screen?
Did you read the Apple support page on this problem? they are really good in helping: Troubleshooting My computer won turn on
Nov 25, 2014 | Apple Imac Alum. 20" 2.4ghz Intel Core 2...
I tried to restore my sister laptop..but i got a message saying restore failed..so when i tried to restart the computer...i just got a black screen with the message NTLDR IS MISSING...Press ctrl+alt+Del...
Hi there, I did a bit of research on this for you and this is what I found:
First off, there are numerous causes which could be giving you this message. Odds are it's because reformatting wasn't completed properly, which means something on your computer hasn't been set up properly.
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and/or NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32. New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS.
Jan 06, 2011 | Acer Pink 101 Aspire One AOD2602571...
Black screen with info that pops up immediately upon booting up
Hi:
That sort of message comes up when your computer is unable to boot to the hard drive. Those messages basically mean that it is trying to boot from a network, (which it isn't hooked upt to). Your hard drive could have failed, or your boot sequence could have been inadvertently changed too.
First, make sure your thumb drive is not installed in the laptop, as this can cause the problem too.
You can check your boot sequence by rebooting your computer, and entering the BIOS, usually by hitting F1 or F2 on start up. Tab over to the Boot section, and see what the boot order is: Usually it should be: CDROM drive, Then Hard drive, then removeable drives.
If this is ok, check and make sure that your hard drive is showing up in the BIOS on the main page too.
If not, it might be bad....
Hope this helps!
Apr 23, 2010 | Toshiba Satellite X205-SLI1 Notebook
Start up error message issue: floppy disk fail
if im correct, you havent installed a floppy drive yet...
while the comp is booting press esc (on some comps its F10 it should say on the screen) and access the boot sequence..in there there is a list of boot items...they always list floppy drive as the first boot drive in case you need to recover your comp...remove floppy drive from your boot list making sure that your hardrive (C) is first drive to boot.
After you get your comp set up, you may want to change that sequence in case you ever have problems with your HDD
add a comment if you need more help
Jun 22, 2009 | EliteGroup K7S5A Pro Motherboard
On boot up screen reads "Loading PBR 2...done"
As the notebook is starting you see the Dell 'Splash' screen. Press F2 to go into the BIOS setup. Check to make sure two things: first that your cd/dvd and hard drive are being recognized and identified, second that your boot order has the cd/dvd first and internal hard drive second. Your machine may be trying to do a USB device boot or network boot when these options are not available. Next try pressing F8 immediately after the splash screen disappears to try to get into Safe Mode. If it still fails to boot, I would try booting using a Windows XP installation disk and then going into the repair console to check if the hard drive is damaged or corrupted.
Dec 15, 2008 | Dell Inspiron 6000 Notebook
Error Message Upon booting up
go to bios and load defaults. if still same thing happens after reboot. Boot from OS cd, on windows etup page, choose "R" to run recovery console. Choose OS. Run CHKDSK /R.
Feb 16, 2008 | Compaq Evo N610C Notebook
Hard drive problem
Every 4/5 days my laptop fails to boot and I get message "no operating system found"----my drive is only a few months old. However, I have found that if I take out the drive and replace it there will be no problem for a week or ten days. Thus I suspect the problem has something to do with a build up of static. How can I prevent this and save all the hassle?
Dec 14, 2007 | Computers & Internet
Elan VIA!dj-S MP3 Player Logo
569 people viewed this question
Top Elan Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Elan Audio Player and Recorder Expert? Answer questions, earn points and help others
