Question about NetGear WGR614 Wireless Router
Should a Linksys Wireless Adapter function with a Netgear Wireless Router? How would you make it work? Thanks. Vernell
    Brigadier General:
  • 10,406 Answers
If the adapter uses the 'G' protocol, and the router uses the same protocol (or accepts both 'B' and 'G'), then the two devices will be compatible.
Access the LINKSYS web-site, and download the device-drivers for your specific wireless adapter, and install the device-drivers.
Posted on Sep 28, 2010
  • 779 Answers
Yes, Most adapters will work with most routers - and comply with the 801.11 standard - The only issue will be if you have an "N" adapter only The router is compatible with 802.11b and g
Making it work - you should be able to detect the signal from your router and enter the wireless security key (often written on the bottom of the router)
Netgear wirless - installed on toshiba satellite a45 - S151 will not connect to internet router = comcast - linksys also causes conflict with connection of other wireless computer
Presumably, you have configured your wireless router:
* SSID (your "network name")
* encryption-level ('WPA' or higher security)
* password for your network
With that information, any wireless device (iPod Touch, iPhone, NetGear wireless adapter) should be able to connect to your wireless router.
Exactly what error-message are you getting?
Feb 21, 2011 | NetGear WNA1100 Wireless-N 150 USB Adapter...
Just installed a Netgear Wireless-N 150 router and my other desktop - which has a Linksys Wireless-G PCI adapter (model WMP54G) continually toggels between Acquiring Network Address and Not Connected. Are...
if your useing a G network (the router is a G?) then the adapter will attempt to connect via N you have to tell the adapter to connect via G mode only, it cut the speed in half but it should work.
if you have an N router check to make sure the router will accept an N connection. via the network configuration page. depending on the router that may be at http://192.168.1.1 or http://192.168.1.255
Jun 10, 2010 | Linksys Wireless-G WMP54G 802.11g/b
Link the netgear wgr614v10 to linksys wireless adapter
First you will need to check the wireless settings of the router. Do you have any computer connected to the router ? If not then connect the computer to the router and open the set up page of the router, check the wireless settings of the router.
Once you have all the wireless settings of the router then you can try to connect to the wireless network on your wireless computer.
Apr 17, 2010 | NetGear WGR614 Wireless Router
Netgear wg111 - I am connected to wireless network
i have seen issues with wireless USB adapters. Can you try another USB port on the computer? Also delete the adapter and let it br reinstalled. If this does not help, I would suggest returning it and getting a Linksys adapeter.
Jun 15, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Netgear Wireless Router won't work with my Linksys wired router.
As asked above, why would you want the wired router and the wireless router on the same network?
The direct answer to your question(s) is found on Netgear's website. http://kb.netgear.com/app/answers/detail/a_id/965/kw/wpn824/r_id/166
The key is to turn off the Netgear DHCP, and give it an address that is unreachable by the Linksys DHCP ie if the Linksys gives out IP addresses starting at 100 or 101, you set your IP address to 99, turn off the DHCP, and plug it into the network NOT using the WAN port, ever. We tend to start at 251 or 221 just for clarity's sake.
The point is you answered your own question. The Netgear wired and wireless works fine. One piece of equipment and better reporting statistics....what are you missing?
Carl
Apr 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
PC works fine with Linksys USB card, but laptop's NetGear won't.
It looks like you are either using TKIP or AES just put the wireless to use MIXED and it will solve your problem.
Mar 19, 2009 | Linksys Wireless-G WRT54G Router
108mbps?????
In order for you to maximize the 108mbs speed from this router you also need to get a wireless adapter from Netgear that suports 108mbs speed because that is a propietary to each manufacturer like Netgear, Linksys and other wireless networkking manufacturer....
Hope that helps...........
Sep 17, 2008 | NetGear RangeMax WPN824 Wireless Router...
Hooking up my gaming router
There is a 90 % possibility that the wireless settings on the gaming adapter and the router are not the same. Try to reconfigure this again. Remember that the gaming adapter's wireless settings needs to synchronize with that of the router to make the gaming adpater works. Call netgear and verify the settings on your wireless connection and reverify the settings you have on the adapter. For manual instructions, see user guide at www.linksys.com/download
Oct 15, 2007 | Linksys Wireless-G WGA54G 802.11g/b...
NetGear WGR614 Wireless Router Logo
37 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
