Question about Uniden BT-108 Bluetooth Headset
I somehow unpaired my bt108 headset from my nokia e71 phone and can't get them to recognize each other again. I tried 1234 and 0000 as my pin and am away from my manual to check if it was anythin else. Any suggestions?
Try completely deleting the BT1-8 profile from your cellphone, turn off the cell and the bluetooth, turn the phone back on and then the BT108 and set it to pairing mode and they should find each other again. One other note, make sure you don't have another unpaired, bluetooth capable cell phone nearby that's turned on or it could be interfering.
Posted on Dec 02, 2010
I cannot connect ot my bluetooth headsed.....help
Well, I posted these generic tips about bluetooth headsets some time ago.
Really hope they might be useful to you, somehow. Otherwise, please, tell your bluetooth headset's model and maker. I'd do my best to fetch specific informations about it for you.
Regards, Carlos
Jul 25, 2011 | Nokia E71 Smartphone
My nokia E71 got locked and asked for PUK number. I entered 71248768 and then it asked for New PIn code. I entered 12345 but not working. I even tried 00000....same result. Please help
Be sure to double check the PIN code and the confirmation or re-type PIN code is match.usual PIN code entered is just 4 digit.Try to enter 1234 and re-type it again. Better turn your mobile for an hour and remove the battery then try it again.
Good luck,,,
Jul 08, 2011 | Nokia E71 Smartphone
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Uniden BT-108 Bluetooth Headset
I just bought a new phone and want to use my old bluetooth,Do I unpair it from my old phone So I can pair it with my new phone?
You don't need to unpair it. Turn off the headset. Hold the power/call button to make it discoverable. Add it from your new phone. It usually uses pin 0000 or 1234.
Jun 13, 2011 | Jabra VBT185Z Bluetooth Headset
My uniden bt108 bluetooth headset would not pair with my new Iphone4. My Iphone 4 couldn`t even recognize my bt108.
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 17, 2010 | Uniden BT-108 Bluetooth Headset
Want to use noise ***
This comes set from the manufacturer. For your BT-108:
Good luck!!
Oct 18, 2010 | Blueant Z9i Bluetooth Headset
Won't connect to my samsung phone , blue light comes on but no sound
After pairing them (and entering the default '0000' password), you should find the headset (BT108) listed in your Trusted Devices list. You'll then have to select the BT108 in the list and choose 'Connect'.
Jan 04, 2010 | Uniden BT-108 Bluetooth Headset
Pairing problem BH-168 with E90 nokia
Finally i solved the problem ....
So, to pair this device you need to do "Long Press" on device button until your mobile phone detect it.
That's it
Jul 17, 2009 | Nokia Bluetooth Boom Headset Headset
My nokia E63 wont find bluetooth headset
I had a similar problem with my headset.. but found the solution.. I am using Jabra 2010.. ok.. so just switch "off" the headset...go to the pair menu on e63.. then switch on the headset.. and then look for new pair devices option.. voila it came up. hv been trying for almost 3 weeks before i got the sequence right.. somehow if u had switched the headset on beforehand.. it wouldnt recognise it only.. the solution is here at jabra website .. although.. they dont hv e63 listed .. but the same procedure for e71 worked fine for my handset..
Jul 13, 2009 | Genius BT-03A Bluetooth Headset
Cannot pair Nokia N70 to Jabra BT150 bluetooth headset
turn on cell phone. activate bluetooth. press right button to search for bluetooth devices. Then press the on button and the volume UP button at the same time on the Jabra headset. The cell phone then finds the device. put in the password/pin (usually 0000). and voila! it works
Dec 07, 2008 | Jabra BT150 Wireless Headset
Uniden BT-108 Bluetooth Headset Logo
186 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
