Question about Kenmore Refrigerators
My bottom freezer rather new kenmore knocks a lot. Really loud. What is causing this and What should I do
    Problem Solver:
  • 19 Answers
Could be a couple of things, but it's most likely related to the refrigerant system. With the unit running, take the toe grill off the bottom front of the freezer. You should be able to see the condenser, which is a flat rectangular object made of black steel tubing. Try moving the condenser (gently) up or down and see if that makes any difference in the noise.level. If it does, take a piece of folded up cardboard and wedge it between the condenser and the floor...that should make things quieter.
If that dosen't work, your problem could be the compressor, which iis a lot more serious. Compressors aren't DIY friendly. and I'd advise against going any further.
If the unit is less than a year old, it should be under warranty. Check your owners manual for details.
Good luck!!
Posted on Sep 28, 2010
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
Kenmore bottom freezer fridge making loud noise not cooling
What is the complete model number of your unit?
Where is the sound coming from?
Dec 04, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
I have the Kenmore refridgerator with the freezer on the bottom, and lately it has been making a loud noise when it comes on. It has been doing this for a week or more, today I noticed that the temperature...
You need to check for the refrigerator level, drain pan, condenser fan, evaporator fan and inspect the compressor mounts for the cause of noise. Any popping or hissing sound is normal on frost free refrigerators.
Good luck
Jul 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our Kenmore side by side refrigerator(#106 5682 603) has developed an occasional knocking sound - fairly loud. I obtained a new water filter from "filtersfast.com" and have recently changed this filter...
If it sounds like it may be coming from the back of the freezer, it is the refrigerant "popping" as in feeds into the evaporator. Some models have this issue and there is a "fix" for it. (yours may not be this one though). Although the sound is annoying, it doesn't really hurt anything. That's not to say the icemaker isn't making the noise, or something else. But I am not sure where it is coming from.
Dec 31, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerator runs loudly - stops when I put pressure on doors
older fridges used fiber glass insulation(didn't carry sound)...new fridges use hard foam(much better insulation but carries sound a lot more)when you push handles you dampen the sound... not to worry it's normal just keep all coils clean
Aug 13, 2009 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Coldspot 69182990 - knocking noise
check te rubber mounts at the bottom of the compressor
the rubber rots after some time and the compressor moves on shutting down as the knocking could be that noise
May 20, 2017 | Kenmore Refrigerators
Loud banging/thumping during spin cycle on my kenmore front load
this sounds like this could be the bearings,to check for this,open door and with yourhand lift the inner chrome drum and let it fall then lift again and if you feel a knocking sound and a lot of play in it then its the bearings,i know there should be movement in the drum but this will feel more of a knocking.
Jul 06, 2009 | Washing Machines
Kenmore Coldspot freezer is buzzing loudly
See if pressing on the back panal makes a difference and see if anything is putting pressure on the panel. If its vibration it is trial and error to get it positioned to quiet it down. If it is the bearing replacement is the cure.
Eric
Jul 03, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refridgerater shuts off with a bang
When you look at the compressor of a refrigerator, what you see is actually just an outer case. The compressor is inside that case, supported on four springs. If you give a compressor a shake (even a new one) you will hear the inner compressor part knock on the outer case. Sometimes, if a spring brakes or gets weak, when the compressor stops running, the momentum will then cause it to strike the outer case, causing a loud knock or two. Most refrigerators will work fine for many years if this condition occurs. It is a bit annoying, but the only fix would be to replace the compressor, which is generally prohibitively expensive if the unit is no longer in warranty. Please don't bother rating this solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Mar 15, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
