Question about Cycling
Occasional, unexpected LOUD metalic "snap-snap-snap" as if something metallic is hitting the fan inside. Can feel it in left handlebar when it happens. Happens every 20 mins. or so and seems to come out of nowhere, but is very loud.
  • 1 more comment
  • farabaug Sep 28, 2010
    This is a Schwinn Airdyne exercise cycle, I wonder if you had gotten this additional info. I'll try your possible solution, have a mechanic coming over this evening. Noise is definitely coming internally, so wouldn't know what to spray on externally. A small noise comes from pedal/rear area before this loud snapping coming from forward happens. THANK YOU!!
    I find this very helpful.. Thank you!
  • farabaug Sep 29, 2010
    Had mechanic come by last night. He said if it had been a bearing, it would have been more than occasional, intermittent noise. More like a jack-hammer and more continuous. He discovered the chain was loose. Lubed, tightened chain, doublechecked that spokes were not loose too, and this has fixed the problem.
  • 2,272 Answers
As per the noise it indicates towards the bearing.When the bearing goes dried up or rusted or out of its alignment then it will make such noise. The bearing has to be lubed a bit with grease/oily material and let it remain their for few minutes then check out.You can also spray wd-40 from where the noise is coming,let it remain for few minutes then recheck.If the noise comes again,please keep updated.Also give more details about the brand and exact model number.so if any part required,then exact detail can be provided in that case.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Sep 28, 2010
  • raj somaiya
    raj somaiya Sep 29, 2010
    Thank you very much,for keeping us updated and letting us know the cause of problem.
    Thanks.
Why it make loud sound like fan is thatching some metal when i plug in?
check the fan blade to make sure it is tight on shaft. also check to see if any of the fins are bent could be that they are hitting the housing of the fan motor.
Jun 07, 2014 | Turbo Air MUF-48 M3 Series 2 Door 48"...
Loud metal to metal coming engine
Hi there.
You havent giving us much to go on but you say metal to metal from engine? that could be fan blades hitting radiator or water pump problem or alternator problem[bearing worn] there s a lot of things under the bonnet so could you please give me more info.
May 22, 2014 | 2003 Renault Megane
2004 chevy tahoe poping noise under front end driver side
is it 4wheel drive if so cv joints if not fan could hitting something
Mar 30, 2012 | Cars & Trucks
I'm experiencing occasional arching from the center of the oven i.e. out of the spindle that rotates the metal rack and glass turntable. I cleaned thoroughly and it seems to have minimized the proble
Its unlikely to be associated with the tuntable motor. Units are tuned to prevent arching. Therefore it appears something may have changed inside the unit. Be sure there are no loose items or bits of foil or other mateallic items inside. Also check metal turntable.
Dec 31, 2011 | GE Advantium 120 Convection/Microwave Oven
Why is my 1987 300e Mercedes making a loud clanging noise at start up?
I would think the honeycomb ceramic "Brick" inside the Catalytic Converter has broken up, makes a terrible rattling when this happens.
Nov 26, 2011 | 1987 Mercedes-Benz 300-Class
I was driving one day and everytime i hit the brakes, i heard a clank. Then i made a sharp left turn, then i heard something snap. So again i hit the breaks and the car made a metal to metal sound, so i...
The control arm mounts to the frame you need to buy a new control arm or bushings.You get these at www.rockauto.com for about $50.00-80.00 or you can just replace the bushings for about $12.00 plus labor.
Apr 20, 2011 | 1994 Chevrolet Cavalier
The handle of my quinny buzz has jammed with one side higher then the other. the button to adjust it doesn't seem to be working any more. Help! Is there anything I can do to get the handle to move?
Your handlebar adjustment button has snapped inside and will need replacing. Dorel UK 01842 763 281 (Mon – Fri, 8:30 am to 4:30 pm) are the sole suppliers of parts for Quinny and can send you the part. It's a bit fiddly to fit though. In the meantime, on the underside of the handlebars, down either side are a row of holes with a small metal peg sticking out of one either side. These pegs are what the grey button retracts to make the bar slide up and down. You can push these pegs in manually with something like a key, and move the handlebar up and down. A bit tedious as you have to do one side at a time and 'wiggle' the handlebar up or down.
May 10, 2010 | Quinny Buzz Three Wheel Stroller
Audi a3 Snap on Fault diagnosed as drivers side crash sensor
if this vehicle is a 2005 then your fancy snap on machine is a complete and utter waste of time ,The software is encrypted so your snap on thingy could show anything ------ Your snap on reader is about as obsolete as me an old dinasaur or as obsolete as 5inch floopy disk.Dealer only via encrypted internet connection to authorised dealer IP and fingerprint recognition of the operator
Oct 17, 2009 | 2005 Audi A3
Refrigerator making loud noise and fan: help!
take raer panel off inside freezer and check there is no ice build up which is hitting the fan
Jul 18, 2008 | Hotpoint HTS16HBR Top Freezer Refrigerator
Cycling Logo
83 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
