Question about HP OfficeJet 6110 All-In-One InkJet Printer
It keeps saying paper jam: clear jam and press enter but there's no paper in there. I took everything apart to make sure?
    Scholar:
  • 107 Answers
Hello, i got one better than that, but for now, your problem. well on the left side of the carraige, there is an optical sensor, if your good at taking apart you machine, take this unit out, and clean the electronics, then reinstall, if still not working, replace that optic sensor. but at same time check the encoder, and clean. oh and for the problem i'm having with my customers machine, it was a bad ink cartridge, causing the electronics to go haywire, causing a normal power cycle to take 5 min. and a print test from control panel to print in well i didn't time it, i canceled after 10 minutes. pretty good one.
Posted on Sep 28, 2010
My Xerox phaser 6180 keeps saying there is a jam at exit. Open door A. I have taken it apart & cleaned/cleared everything I can. Any suggestions?
This could be some paper still stuck in the fuser, so check that.
The usual cause of this, is the 'paper out' sensor arm (in the fuser) being broken.
I'm fairly sure that this is NOT available from Xerox as a spare part, so the quickest, easiest solution is to replace the fuser.
Jul 21, 2015 | Xerox Office Equipment & Supplies
Says printing but nothing is coming out
If it says it is printing and no paper is being fed, and you are not getting any paper jam indicators, thats not good.
To get this reset you may have to do a RAM CLEAR. This will mean all documents in memory and all programming in the machine( date, time, quick dial numbers etc, etc) will all be lost, and will have to be re-entered.
If you want to try the RAM CLEAR do the following....
Press Program, *, 3.....display should say All RAM Clear ( enter/cancel).....to perform the Ram Clear press ENTER
To finish without doing the Ram clear press CANCEL.
Apr 27, 2010 | Muratec F320 Plain Paper LED Fax
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Cannon MP370, says clear paper jam, none seen
i know that happens to me check that everything it as it sould and resated
Dec 29, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
Paper Jam and i do not have one. Help
Hello sir; On the paper exit unit there have a paper exit senser got to be stuck or out of track. loose it or put it back in right position.
May 18, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Phaser 860 screen says "paper jam - open front cover to clear"
I posted a problem with the phaser 860 paper jam. I found 2 broken sensor flags and am ordering the parts.
Mar 19, 2009 | Xerox Phaser 8400 Laser Printer
Paper jam
try to remove all ink cart. and re install again...
Aug 27, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
100 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
