Question about Palm TX Handheld
Jack problem - no sound
My palm TX dosen't play sound, sometimes it works when I plug some headphones but the speaker doesn't works (it is problem with jack connection, not with speakers) .
Is it possible to repair that ?
Regards,
Thomas
  • 1 more comment
  • Paulprn Jun 01, 2008
    I've been a Plam user for many, many years and feel this T/X is my last! My external speaker hasn't worked since a month after the warrenty expired (7 months old) and now it constantly resets itself in an endless loop. It has become, unfortunately, an unrealiable device with the WORST costumer support in the industry. The Oalm software is terribly unstable and querky on the best of days and useless on others. As much as I hate to lose my contact list, I'm going to either a Window's Base (WITHOUT the Palm name attached) or iPhone!
  • Anonymous Mar 09, 2009
    My speakers quit working unless I use a plug-in earphone. Does anyone have a "fix" for this?
  • dozap Apr 28, 2009
    My husband has moved on to a Treo & I just started using his old palm tx in hopes of having a single calendar that was mobile. I figure out how to sync and get my Outlook calendar on the palm, but without the sound the alarms don't help much. I have to remember to look at the palm to see the ! flashing. If I could remember to do that I would not need the portable calendar. It work fine with a headset, but nothing without. I tried the WD40 and no luck.
  • 2,794 Answers
I have this problem too. It is probably the jack in the TX. Mine only plays through one channel. It can be repaired as well.
Another option you can try is getting drivers to run a bluetooth wireless stereo head through it. It's some dough to do it but it takes care of the jack issue.
Posted on Jun 09, 2008
Looking for old Logitech S-100 driver
These are analog speakers and do not need a driver. First, make sure they're plugged into the speaker/headphone jack and not the microphone jack. Second, make sure the computer's sound output is enabled and set the headphone/speaker jack. Third, verify that the sound output is working by plugging in a headphone set or a different pair of speakers. If the computer sound checks out, the speaker cable is bad or the power supply is not working.
Nov 14, 2017 | Dell Computers & Internet
Panasonic Stereo Colour TV Model TX - 76PW10A Has frequent intermittent problem of no sound. Typically takes multiple tries to get sound working. Sometimes nothing comes on. Sometimes sound will...
i think there are no problem with your tv sum wire is missing it place
did u put headphone to TV sumtime if u plug a headphone in tv headphone jack again u short out your problem
Oct 19, 2008 | Panasonic Televison & Video
No sound from internal speakers after using headphones
The headphone jack has a switch in it to disable the speakers when the headphones are plugged in. This switch has stopped functionong. Look in the jack eith a magnafying glass to see if there may be lint or some other object holding the switch open when the headphones are not plugged in. Otherwise it's time to replace the jack.
Apr 19, 2014 | HP (153147-001) Sound Card
Hello, I have a Sony STR-D85 surround sound system. I need to connect my phone to the system so that my phone's music plays through my surround sound speakers. The front of the console has a headphone...
Headphone jack is an output not input jack. Your going to need a cord to go from your headphone jack(output) of your phone to audio input on your receiver. The cord has a mini stereo plug to the phone and RCA plugs of left and right to your receiver auxiliary input. Good luck..
Jul 15, 2011 | Sony STR-DE485 Receiver
I have a Latitude D600 laptop. When I plug in my headphones, the sound still plays through the built in speakers. When I twist the plug in the jack I can sometimes get sound in the headphones but it still...
I dont think the JACK is the problem, I suspect a bad headphone wire (intermittent) or an incorrect driver, headphone jacks in laptops are software controlled, (no mechanical switch inside) if you hear sound in both the headphones and the speakes it is a driver issue, try updating the driver, if the headphone wire is erratic it can fool the software that controlls the input and do crazy things also...
May 26, 2011 | Dell Latitude D600 Notebook
Brand new. No sound from any speakers or headphone. Headphone indicator is on without headphone jack inserted
try to reinsert the head phone jack there is small switch in side while moving or play the system and try to insert
Nov 17, 2009 | Onkyo TX-SR876 Receiver
Headphone Jack Problem
Go to the icon tray and double click the speaker icon. Have a look in the Advanced controls to see if you have taken the mute off the pc speaker. There might also be an option to play sound on the pc speaker simultaneously with the headphones. If so, uncheck the dual play box so the sound will not play through the pc speaker when you have the headphones plugged in.
Aug 06, 2009 | Acer Aspire One D150-1587 Netbook
I purchased a used Palm it works fine but I have no sound for calendar alerts. I can't even play the alerts to see which one I want. Can this be fixed.
If you plug in headphones, do you have sound in them?
If so, then the problem is either the built-in speaker or the headphone jack.
If it's the speaker, then you're in for a pretty involved fix involving soldering little tiny wires. Do-able, but not for someone just learning how to use a soldering iron.
If it's the jack, then you might get lucky and fix it by inserting and then removing your headphone's plug.
I've had this style of jack get a bit of dust in it before, and basically think headphones are plugged in even when they're not.
Let me know if you've got sound in headphones, and we can take it from there.
Jul 16, 2009 | Palm Tungsten E2 Handheld
No sound in my palm centro
I had the same problem, you probably were using headphones with it and the phone still thinks they are pluggeg in you can bring it to the store or plug the head phones back in give the phone a second to recognize what is plugged in and then remove the headphones slowly. if that doesnt work throw it into traffic.
Apr 07, 2009 | Sprint Palm Centro Smartphone
I have also had the same problem, and I discovered that it may be caused by a little sensor in the headphone jack which enables the external speaker. Sometimes it gets stuck in the "off" position. Try plugging in and removing the headphones, that should solve the problem.
Jan 27, 2008 | Palm Tungsten E2 Handheld
Palm TX Handheld Logo
143 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
